05-26-2013, 12:27 PM | #3697 | |
Rep 1,892
I have not had any issues with the adaptive lights after coding. They still auto-level and pivot during turns and the auto-high-beams still work. |
05-26-2013, 04:10 PM | #3698 |
Rep 144
frogman,
thanks for clarifying, I too got the same error whenever trying to code "fem_body" . how do I test if my adaptive head lights still work? I tested by parking in the garage with the head light on, I was able to see the lights turns as I turned the steering wheel; however I tested again this morning and the light didnt turn. so now im confused.. |
05-26-2013, 06:56 PM | #3699 | |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
05-26-2013, 08:28 PM | #3700 |
Rep 383
I'm looking to start from scratch and make my whole car as if I just bought it. Do I just open esys, activate FA, and right click on each ecu and click code? Will that return everything to stock? Thank you!
05-26-2013, 08:30 PM | #3701 |
Rep 40,972
You can VO Code the entire car one module at a time, or you could use Ctrl-Right-Click and select multiple ECU's to Encode, or you could even Right-Click at the Top of your SVT where your VIN is showing, and encode the entire SVT (all ECU's). If you try and encode DME Module, or the entire SVT (which includes the DME module), the car can not be running during the encoding process.
05-26-2013, 09:14 PM | #3703 | |
Rep 40,972
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Ctrl-Right-Click on all ECU's (the ECU's themselves not the underlying CAFD's) except DME => Select CODE. This of course assumes you never altered your FA (VO) and wrote it to the car. If you did that, then you would instead load original FA (VO) in place of Read FA.
05-26-2013, 09:44 PM | #3704 |
Rep 383
I did alter 6nh to 6nk. Would I just edit it back and once that's done just follow your instructions above?
Also, when you say above "read fa(vo)", why do you out vo? I would just click on read FA and then activate FA like normal, correct? Is there a differenc between read FA and read fa(vo)? Thank you and sorry for all the questions, |
05-26-2013, 10:18 PM | #3705 | |
Rep 40,972
I write FA (VO) just to clarify that FA (Fahrzeug-Auftrag) is German for VO (Vehicle Order), as some are not aware the two are the same thing.
05-26-2013, 10:33 PM | #3706 | |
Rep 144
05-26-2013, 10:38 PM | #3707 |
Rep 490
adaptive head light can be tested rather easily, you just need a wall (or something similar to look at the light)... you can visibly see the light turn right when you steer right (for LHD vehicle)...and turn back to centre when you move the wheel back to centre... just make sure the light switch is set to "A" (Auto)
05-26-2013, 10:59 PM | #3708 |
Rep 286
Drives: 2009 LeMans Blue Coupe
Anyone able to pm me and let me know how to download the E-sys program? I am trying to code for xenon's in my 2013 F25. Thanks
05-27-2013, 12:17 AM | #3709 |
Rep 131
Garage List 2018 BMW i3 Rex [0.00]
2016 BMW F20 M135i ... [0.00] 1999 BMW Z3/E36 - 1.9i [0.00] 2004 BMW Z4/E85 - 2.5i [5.00] |
Hi all,
What is the code to disable stopping the car when driving backwords while opening the driver door ? gr K. |
05-27-2013, 07:15 AM | #3710 | |
Rep 383
05-27-2013, 07:24 AM | #3711 | |
Rep 40,972
I said to ignore DME because I wanted you to have the engine running to ensure proper voltage, and you cant code DME with the engine running, and I was 99.99% sure you never FDL Coded DME to begin with, so it did not need to be reset anyhow.
05-27-2013, 08:59 AM | #3713 |
Rep 383
Shawn- everything reset successfully. However, I spent some time putting my settings back and coding. However my cat acts as if I didn't do any coding. When I bring it up in esys, it shows my changes though. Any suggestions would be appreciated.
05-27-2013, 09:31 AM | #3714 |
Rep 40,972
I assume you mean CAS? What FDL Coding is specifically not taking?
05-27-2013, 10:04 AM | #3716 |
Rep 40,972
When you save the changes, and write them back to the ECU, and then read the ECU again, were the changes saved, or did they revert back to their original settings?
05-27-2013, 02:49 PM | #3717 |
Rep 1,130
Drives: '16 340i AW MSport
hey shawn,
Would you happen to know of the top of your head if a '13 F25 X3 can be coded with the same cable and software as my F30? I'm assuming yes? Thanks! |
05-27-2013, 04:11 PM | #3718 |
Rep 383
Immediately after resetting everything back to stock, I started coding. I'm going to be checking shortly to see if the changes saved after connecting to my car...
