07-16-2014, 01:56 AM | #1 |
Rep 64
Advice on summer tires and fitment for my 2012 335 Sport Line?
Hi all,
I'm looking for recommendations on summer performance tires. What non run-flat tires would you recommend? Any size recommendations? I'm wondering if should I stick with my standard 225/45/18 setup or get a different size? Also, I live in Montreal and constantly drive on plenty of broken roads (potholes, etc.). What can you tell me about ride quality if I go with a different size? By the way, my current tires are 18" Continental Pro Contact run flats (225/45/18). They came with my F30 on delivery. Greatly appreciate any advice. Last edited by Joopster; 07-20-2014 at 06:28 PM.. |
07-16-2014, 04:07 AM | #2 |
Rep 5,140
I would suggest either 235/45-18 or 245/45-18, it results in slightly more sidewall and rim protection.
The ride quality will improve when you leave run-flats for regular tires, and the handling would improve if you choose slightly wider tires. A possible drawback with wider tires might be tramlining, but I wouldn't expect much difference for tires that are 10 or 20mm wider. Michelin PSS are the reference for summer performance tires on this forum, available in both sizes I mentioned above. |
07-16-2014, 04:43 AM | #3 | |
Rep 3,947
07-16-2014, 05:28 AM | #4 |
Rep 5,140
Yes!
There are many members on the forum with 245/40-19 or 245/35-20 front tires that has the same overall diameter as 245/45-18. These are often mounted on 8.5" or 9" wide aftermarket wheels, the OEM wheel is 8" wide so the risk of rubbing is even lower (if offset is the same). |
07-16-2014, 10:34 PM | #5 | |
Rep 64
Just curious, anyone have on 235/45/18's? How do you like your ride quality and handling? |
07-21-2014, 06:31 AM | #7 | |
Rep 5,140
Just for your information since you mentioned bad roads and potholes in your first post. That's why I recommended 235/45 or 245/45, both with a bit more width and sidewall height. |
07-21-2014, 11:11 AM | #8 | |
Rep 64
The reason I'm considering 245/40/18 is for the slightly better look. I know I'll be getting less protection. Do you think putting tires of this size on my OEM rims will be a big compromise or cause any problems otherwise (rubbing, etc.)? By the way, my OEM rims are style 397 - 18" 18x8 225/45/18 front and rear. |
07-21-2014, 11:58 AM | #9 |
Rep 193
I have 245/40-18 tires on my 2013 F30 with 18 x 8 rims and have not had any problems.
2017 340i M-Sport, xDrive, Estoril, Adaptive M Suspension, 18" Staggered, Increased Top Speed Limiter, AT, Black Kidney Grilles, ZCW, ZDA
2011 X3 35i Sold |
07-21-2014, 01:54 PM | #10 | |
Rep 5,140
I just wanted to make sure that I haven't misled you in one of my previous posts (regarding tire widths vs sidewall height). Post some pics when you have the new tires mounted! |
