BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 LED turnsignals installed
      03-14-2015, 12:20 AM   #243
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Try and push in and then turn (like a safety lid on a medicine bottle). DO NOT TOUCH THE BULBS DIRECTLY
      07-01-2015, 10:57 PM   #244
QuikSilver_
QuikSilver_'s Avatar
Drives: 2016 F36 M Sport
Just received my 50W amber cree LED's from Horizon (UK vendor) today. Took a little bit for them to arrive and a bit more expensive than some of the other options I'm seeing on the threads, but definitely worth the wait and money. They're much brighter than the incandescent bulbs, and the instant ON/OFF function of the bulbs is a huge improvement. They look great! I'll definitely be ordering some red ones for the rear turn signals, and then maybe for the brake lights and reverse lights later on.
Install was actually easier than I had expected, just popped off the little cut-out in front of the wheels and had direct access to the indicator bulbs. Unfortunately, I didn't realize this until I had already removed some screws on the driver side and tried to peel back the fender lining to get to the indicators. After knowing that, the passenger side literally took like 30 seconds to switch out!
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
      07-15-2015, 07:44 PM   #245
ronjon400
ronjon400's Avatar
Drives: 2014 535i M-Sport
Here are my led turn signals. Search out motoring max on eBay. $50-60 a pair. I went with amber front and rear. No problems at all.
2014 328i M-Sport (black grills,CF spoiler) SOLD
2004 325ic (stock)
2010 128i M-Sport (VMR wheels
      07-15-2015, 08:16 PM   #246
M47
Drives: F30 328 xDrive
No need of coding? How about some flickering during start-up and every few minutes?
      07-16-2015, 08:47 AM   #247
thatg20guy
thatg20guy's Avatar
Drives: 2021 M340i
You will definitely need to perform coding even on CANBUS error-free bulbs. The reason for this, as is probably explained on numerous other LED bulbs replacement threads, is because LEDs draw far less current and power than normal incandescents. On the normal bulbs, the car sends a little pulse of current during start-up and every few minutes when driving, to check that the bulb is still working. This doesn't cause the incandescent to light up because it needs more current than what the car's pulse is giving it; however with LEDs, it causes them to flicker rapidly whenever the pulse is sent and that needs to be coded out.
Using E-Sys, the codes that need to be changed for the front two turn signals in are:
(For left bulb)
FEM_BODY 3061 FRA_V_L_KALTUEBERWACHUNG aktiv --> nicht_aktiv
FEM_BODY 3061 FRA_V_L_WARMUEBERWACHUNG aktiv --> nicht_aktiv
FEM_BODY 3061 FRA_V_L_IS_LED nicht_aktiv --> aktiv
(For right bulb)
FEM_BODY 3061 FRA_V_R_KALTUEBERWACHUNG aktiv --> nicht_aktiv
FEM_BODY 3061 FRA_V_R_WARMUEBERWACHUNG aktiv --> nicht_aktiv
FEM_BODY 3061 FRA_V_R_IS_LED nicht_aktiv --> aktiv
      07-16-2015, 10:15 AM   #248
ronjon400
ronjon400's Avatar
Just installed em. That's it. Nothing seems to be going wrong.
2004 325ic (stock)
      07-16-2015, 11:01 AM   #249
QuikSilver_
(For left bulb)
(For right bulb)
Perfect write-up!
      07-16-2015, 11:06 AM   #250
thatg20guy
thatg20guy's Avatar
Drives: 2021 M340i
Are you sure there is no flickering even on starting the engine? I would recommend double checking and at the very least, coding in that the turn signal bulbs are LEDs so the ECU will still tell you if there is a bulb malfunction.
Also, I forgot to add the coding for the rear bulbs which are almost identical to the fronts; only difference is that the ECU is REM instead of FEM. Everything is the same except the beginning phrase which is FRA_H_L instead of FRA_V_L
      07-16-2015, 03:29 PM   #251
ronjon400
ronjon400's Avatar
Ok if there is a flicker, then what do I need to do as far as coding? Who does it? Can I do it? I'm pretty computer savvy.
2004 325ic (stock)
      07-16-2015, 03:59 PM   #252
RarScaryFrosty
Drives: 2013 328i xDrive
There most likely is flickering and you're just not noticing it yet. The easiest solution would be to find a local member in your area and to pay them to do it. I don't have a laptop, but the cost of that, plus an enet cable, sourcing a token for esys, etc is just too much for me. I'd rather pay someone with experience to do it for me.
      07-16-2015, 05:28 PM   #253
ronjon400
ronjon400's Avatar
Ok thank you for your help
2004 325ic (stock)
      07-16-2015, 06:17 PM   #254
thatg20guy
thatg20guy's Avatar
Drives: 2021 M340i
You can PM shawnsheridan, he's the one who hooked me up with the coding software. Or you can just browse around on the Coding and DIY section of the forum for other sources. As for the ENET cable, you can either make one or buy one off Amazon for around $40. All of the installation instructions and steps for activating E-Sys as well as connecting to your car are well explained in the included documentation. After that, all you need to do is apply the changes I mentioned above and you should be good to go
      07-17-2015, 04:49 AM   #255
ronjon400
ronjon400's Avatar
Thanks man. Teach a man to fish.
2004 325ic (stock)
      02-29-2016, 03:08 AM   #256
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
how about these:
http://www.aliexpress.com/item/1set-...502098323.html
do they work instead of coding?
      03-07-2016, 10:47 AM   #257
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
If you're looking for a pair of LED bulbs for the front turn signals I highly suggest going with the plasma LEDs you get that from underground euros. There's a picture of them on my car on that website because we were testing them out when my car first came out and there are no error codes or anything in there an exact match to the halos but my halos were coded to 100% instead of the original I think 50% but when they're on there is an exact match and they are perfect I've had them in my car since the day I got my car or the week I got my car December of 2013 and to this day they are perfect and I wouldn't change them for anything else they are white plasma LED from his website underground euros or if you just do a search for underground euros or something
      07-05-2016, 03:20 PM   #258
TypeOne
Enthuisiast
TypeOne's Avatar
93
Drives: G05 X5
Bringing the thread back from the dead...
I recently installed these in my car and have had zero issues. No coding, no fast blinking or anything. They are crazy bright at night and comparable during the day.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
AW F80 M3 / RAYS / TOYO TIRES / BMS
IG: @hybrid_david
      07-06-2016, 08:04 AM   #259
mateusz0147
Drives: BLACK 2015 BMW 328I XDRIVE
How long have you had these installed? i really want to upgrade to led all around my car but i keep reading all these problems. if u really have no problems i will be buying these today.
      07-06-2016, 09:00 AM   #260
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
While you may not think you have any problems, they are definitely doing the bulb checks and flashing randomly. Also, those are only 25w equivalent.
I got these: http://www.ebay.com/itm/Error-Free-A...-/131243398136
They are 50w equivalent and cree leds. I did code them as well so i disabled the bulb checks and enabled is_led.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      07-06-2016, 10:06 AM   #261
mateusz0147
okey so basically no matter what they need to be coded?
      07-06-2016, 10:48 AM   #262
TypeOne
Enthuisiast
TypeOne's Avatar
93
Drives: G05 X5
When will they be flashing randomly? How do you see it?
Leave the car idling outside and sit and watch? Does it only do it while the bulbs are on?
I literally haven't noticed them blink, give errors or do anything weird. They work just like the halogens...? I also had the car out in the daylight with the hazards on an watched the LEDs vs the OE bulb... the difference was almost not noticeable.
What am I missing?
IG: @hybrid_david
      07-07-2016, 12:28 PM   #263
iki4life
Drives: 2013 BMW 328i SportLine
Hey guys, I just want the Halogen bulbs in clear color that turn amber when signaling. I dont want to do any LED coding or anything...does anybody know which halogen amber bulb to buy for turn signals?
(I ordered USR Depo headlights and plan to put the turn signal in those)
      07-07-2016, 01:43 PM   #264
TypeOne
Enthuisiast
TypeOne's Avatar
93
Drives: G05 X5
https://stealthauto.com/Accessories-...-Bulbs/?veh=30
IG: @hybrid_david
