12-21-2023, 04:10 PM | #1 |
Pasha Dastmalchi
62
Rep 111
Drives: 2019 M240i Coupe 8 Spd Auto
100k Mile Service (Including Timing Chain) - Need Opinions
Hello all,
So I recently purchased a 2015 f31 328d xdrive with m sport package and all the goodies. It had 93k miles, now I've taken it up to 95k miles. At 83k miles it had the EGR cooler replaced as part of the recall. In terms of its carfax, it reports that its had oil/filter changed at 8k miles, 14k miles (owner #1), 47k miles (owner #3), 57k miles, 66k miles, 76k miles, (owner #4), 83k miles, 93k miles (owner #5), and now I am owner #6. As you can see, there were no reported services or oil changes from 13k miles to 47k miles. Owner #1 sold it to owner #2 at 20k miles (March 2018). Owner #2 sold it to owner #3 13 months later (April 2019) but had no service notes documented other than a battery charged at 20k miles right after purchasing the vehicle. Owner #3, then had it oiled at 47k miles, 10 months after they had purchased it from owner #2 (February 2020). I am hoping that there were some at-home oil changes during its time with owners #2 and #3 that weren't documented, but you can never be too sure. That being said, the car is coming up to 100k miles pretty soon, and as I plan on keeping this car for a very long time as my daily driver, I want to make sure it is in peak condition and extremely well taken care of. Because of this, I want to know all its wear parts and fluids maintenance schedule myself, so I was planning on doing the following at 100k miles:
Is there anything else I should take care of? Would it be overkill to replace the timing chain as well? If I do that, are there any other parts you all would advise replacing as well during that procedure (guides, tensioner, gears)? **I should mention too -- I was considering doing a rawtek tune & DPF/EGR/SCR delete for some added performance and sanity, knowing my emissions junk won't fail me (yes I live in CA but there is always a way around smogs, I live in LA)... But now, I am considering going the route of a KermaTDI stage 2 tune & possibly even xDelete for the non-winter time once I complete all the service items, after doing some research and hearing such great reviews about Karma's tune**
Owned: 2019 Alpine White M240i Coupe | VRSF Catless DP | AP Intake | BM3 Stage 2 (Blown at 21k miles)
Own: 2015 Black Saphire Metallic 328d Touring M-Sport Last edited by pashad13; 12-21-2023 at 04:17 PM.. |
12-21-2023, 04:12 PM | #2 |
Pasha Dastmalchi
62
Rep 111
Here is a screenshot from an excel I made to organize the car’s service/maintenance records that I have available, prior to me.
Own: 2015 Black Saphire Metallic 328d Touring M-Sport |
12-22-2023, 04:51 AM | #3 |
Rep 8,520
From personal experience with my 330d, don’t bother with a catch can. They collect very little oil and I suspect it may have been a contributory factor in the early failure of the turbo.
Deleting (coding & blanking) the EGR curcuit is of far greater benefit in terms of a clean inlet manifold and ports (do clean them though, or get them cleaned professionally - they’ll likely be significantly fouled). Getting the timing chain replaced is a good option. The 4-pots, in particular, have a reputation for premature failure. Increasing the frequency of oil/filter changes is always a good idea. I change mine every 7K miles.
12-23-2023, 08:57 AM | #4 |
Rep 906
Hello Neighbor! I made a sheet to spell out the maintenance on the BMW diesel engines. You may want to get a UOA at the next oil change just so you know condition of the engine and establish a baseline after that gap in the history. For drivetrain fluids, include a transfer case and front diff fluid change. There are conflicting opinions on whether to do it or not after 60K. Replace the 12V battery if it's still the factory unit. The timing chain issues were largely isolated to earlier models in the European market, and BMW put in a revised design when the N47 was brought to the states. Also make sure your car had recall 20V-185 to address a defect in the transfer case, a known issue for the pre-LCI cars.
I agree with Watsey about the catch can. FaRKle! own data suggests the stock and KermaTDI stage 2 tunes produce little blow-by. The latter is recommended for CA as they require a stock configuration and preserve the CAL and CVNs, avoiding a smog check failure. At 93K and 8 years, it may be covered my some component-specific warranties. So diagnose and see if you can use it for proactive replacements:
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
pashad1362.00 |
01-04-2024, 01:49 PM | #5 |
Rep 424
Have you gotten a quote to replace the chain. Feel like it is a LARGE expense for proactive maintenance. I have 152k on mine, though with better OCI's and I don't plan to change proactively unless I get a rattle or noise.
Wish or wonder if there is an easier way to test/check for stretched chain/ damaged guides. |
01-09-2024, 02:28 PM | #6 |
Rep 37
Catch can for a diesel? No...
Mr. Noobkiller you would be waiting for forever on that timing chain rattle because almost never there is any rattle. It just breaks. If you are not doing flat out then you might get lucky though and you only need to replace chain. Regarding your list: Oil change OK Oil Filter OK Fuel filter OK Brake fluid change OK Transmission/Diff fluid change OK Intake air filter OK Cabin air filter OK Oil Catch Can Install (thanks for the idea farkle) NO Clean MAF sensor NO Clean carbon & soot out of intake manifold YES also delete the swirl flaps if you have someone to program them out |
01-09-2024, 03:43 PM | #7 | |
Pasha Dastmalchi
62
Rep 111
01-13-2024, 09:35 AM | #9 |
Rep 37
100k miles, 100k service, 2015, 328d, f31, maintenance, repair, service, timing chain |
