Studio RSR
      07-12-2013, 01:39 AM   #4005
MoneyFor
MoneyFor's Avatar
Belgium
25
Originally Posted by shawnsheridan View Post
No. With ER_KEYOUT_AUTOVR = aktiv, you can have the door open, but the seat-belt must be fastened, or it will jump into Park.
Where do i find this code ? under fembody or ...?
grts
      07-12-2013, 03:01 AM   #4006
GaLi
Drives: F30 320i
Hi Shawn, me again.
Can you please PM me (can read them now) a link for the latest E-sys, PSdZData, and patch/token please? (For my soon to be delivered 2013 F30 320i).
Thanks!
      07-12-2013, 10:12 AM   #4007
kigkige
Drives: F30/13.04.11 built
Office and Connected Drive may be blocked by L802A National version Korea Country Controller, although it seems strange that Connected Drive would be absent with a factory equipped 6NR BMW Apps car.
You can try coding them:
HU_CIC /HU_NBT => MACRO_PIM = aktiv
HU_CIC /HU_NBT => CONNECTED_DRIVE = aktiv
Above two were already activated when I tried to code them. I think pre-coded data were gone!
(E-sys 3.22.5 PSDZDATA v49.4)
1. Blutooth issue(software version:001.036.002-004.050)
There is office menu on idrive but there are only two sub-menus. One is "contacts" and the other is "notes/voice memos".(*see first jpg file) So I erased my phone from device list and re-connected my phone and idrive. After the pairing, idrive asked me which functions am I going to activate. But there were only two options, one is phone, and the other is audio.(*see second, and third jpg files) So, I activated following;
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
MACRO_PIM
but, still I can't see other sub-menus on idrive. Any tip on this?
2. Connected drive issue
It works fine! Thank you again!
      07-12-2013, 10:17 AM   #4008
shawnsheridan
shawnsheridan's Avatar
Originally Posted by GaLi View Post
I'm not in a hurry, I'll read your PM tomorrow, thank you!
Hi Shawn, me again.
Thanks!
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-12-2013, 10:25 AM   #4009
shawnsheridan
grts
On F10, it is in CAS.
      07-12-2013, 10:27 AM   #4010
shawnsheridan
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
MACRO_PIM
For office, the phone must support Bluetooth MAP Profile. Does yours?
      07-12-2013, 10:41 AM   #4011
kigkige
Iphone 3gs does not support MAP profile. You've got all the answers. Thank you again!
      07-12-2013, 10:44 AM   #4012
shawnsheridan
Buy new phone.
      07-12-2013, 08:02 PM   #4013
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
I am hoping someone can help me out with this..
I have everything installed on Windows 7 running on VM Ware thru a MAC. I have the Yellow exclamation point on the network icon.
When i go to run ZGW SEARCH i am getting the following error.
Component 'MSWINSCK.ocx' or one of its dependencies not correctly registered: a file or missing or invalid
Any help would be appreciated
      07-12-2013, 08:33 PM   #4014
shawnsheridan
You need to register MSWINSCK.ocx with the Win7 OS VM before ZGW_Search will work.
However, you do not need ZGW_Search at all to connect to the car. It is informational only.
      07-12-2013, 08:37 PM   #4015
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
I tried to go straight to E-sys and the VIN portion was greyed out and said no ZGW available or something like that. I figured it would have something to do with it.
What else can i check to see how to get the VIN to pull?
      07-12-2013, 08:41 PM   #4016
shawnsheridan
Make sure your VM Network Adapter is bridged to the host LAN Adapter.
      07-12-2013, 08:45 PM   #4017
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
like this? or is there another place to do it as well?
      07-12-2013, 08:54 PM   #4018
shawnsheridan
I am not a MAC guy, but that looks right although I would expect it to be green not red.
Inside the Win 7 VM OS, under Network Properties, are both your Ethernet and WiFi adapters enabled?
      07-12-2013, 09:07 PM   #4019
UB
Drives: G01
Hi Shawn. Collecting my new F31 328i in 2 weeks. Can you please PM me a link for the latest E-sys, PSdZData, and patch/token? Thanks in advance!
      07-12-2013, 09:12 PM   #4020
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
its usually only green when connected to ethernet and i was inside the house and not connected to the car..but now that i went back out to reconnect i cant even get the network adapter to give me the yellow exclamation point. I thinking my cable may have died but im not sure.. i will have do some tests. Thanks for the help so far.. hopefully its just the cable. will let you know.
      07-12-2013, 09:20 PM   #4021
shawnsheridan
Originally Posted by txconsultant View Post
Shawn,
Can you please send me the information as well? Patrick dot Harwood at hotmail
Thanks in advance
Email sent.
      07-12-2013, 09:24 PM   #4022
shawnsheridan
First, connect to Laptop to Router with Cat-5 Cable and launch Internet Explorer inside VM, and see if you can get a web page to load. This will at least tell you if the VM LAN Port is enabled, bridged properly, and working as it should.
      07-12-2013, 09:30 PM   #4023
shawnsheridan
Need your email, or you have to wait 24 hours until you can receive PM's.
      07-12-2013, 10:08 PM   #4024
UB
Drives: G01
uberdubster at gmail
Thanks again
      07-12-2013, 11:11 PM   #4025
shawnsheridan
Thanks again
Email sent.
      07-13-2013, 07:10 AM   #4026
007bandido
Switzerland
Drives: 2019 G05 30D M
Hello,
I am interested too to receive the link for the latest E-sys, PSdZData, and patch/token. Thanks in advance.
