03-14-2012, 08:25 PM | #1 |
Supreme Allied Commander
3843
Rep 54,362
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Performance Air Filter for F30 328i N20
AFE OE Replacement air filter for the BMW 328i F30 2012 L4-2.0L (t) N20. This filter is available in Pro 5R (P/N: 30-10225) and Pro DRY S (P/N: 31-10225). Constructed with 100% polyurethane, this high flow, OE replacement performance filter outflows the stock paper filter by 28% resulting in improved horsepower and torque.
03-15-2012, 12:16 AM | #3 |
3843
Rep 54,362
Drives: F80 M3
04-07-2012, 12:50 AM | #5 |
3843
Rep 54,362
Drives: F80 M3
04-16-2012, 10:28 PM | #6 |
Rep 127
Forgive me, I've never used an oiled filter. Does it come oiled? Do I need to re-oil it? Clean it? What's the process for cleaning? or do I just replace it? How often? Again, never used an oiled filter so I'm really curious...
04-16-2012, 11:00 PM | #7 | |
3843
Rep 54,362
Drives: F80 M3
There is also a dry version that doesn't require any oil. |
06-07-2012, 06:05 PM | #10 |
Rep 1,285
A few HP over a grubby stock filter.
Many oiled filters actually decrease performance from stock after they have been installed in the car for a while and have gathered some dirt. You are typically better off leaving it stock unless you are going to fastidiously clean and re-oil the filter on a very regular basis. |
06-21-2012, 05:24 PM | #12 |
3843
Rep 54,362
Drives: F80 M3
06-21-2012, 07:28 PM | #13 | |
Rep 72
Does this mean a 28% increase in flowrate at the same pressure drop? What kind of pressure drop across the filter do you get at different air rates?
you are a winner
06-21-2012, 07:40 PM | #14 | |
3843
Rep 54,362
Drives: F80 M3
We measure filters on flow benches and the results are a percentage, see this thread: http://www.e90post.com/forums/showth...ght=flow+bench |
06-21-2012, 10:38 PM | #15 | |
Rep 72
That is exactly what I wanted to know... Thanks
you are a winner
