10-29-2016, 11:03 AM | #1255 | |
Rep 40,752
FlorinQCK-2.50 |
10-30-2016, 11:26 AM | #1257 |
Rep 40,752
You do not have CIC, you have NBT. It is impossible to have NEXT map with CIC. You cannot send or receive PM's yet. Send me one when you can.
FlorinQCK-2.50 |
11-03-2016, 07:34 AM | #1259 |
Rep 40,752
Tools and details are already provided in this thread. I can't imagine what more "help" is needed.
FlorinQCK-2.50 |
11-04-2016, 12:46 PM | #1260 |
Rep 43
Just installed NBT in my car, and probably there is too much data to digest in short period
in order to get Europe Next 2017-1 fsc I have created the DE file through Esys with the following data For NBT (DE File): In the Parameter section enter: 1. Diagnostic Address (hex) = 0x63 2. Click on the Identify button and the Base variant HU_NBT will be populated 3. Application ID for NBT= 0xDE 4. Upgrade Index = 0x1 Is that part right for 2017-1? Because when I proceed to the following I have problem in step 6. I can't find 2017 map 1. Place your XXXXXXX.fsc into your tools directory (same location as the Base64.exe) 2. Open a command prompt (DOS Screen) and go to the tools directory 3. Type "Base64 XXXXXXX.FSC XXXXXXX_000DE001.FSC" and press enter 4. Open BMW-FSC-NBT-Generator.exe 5. Click "Browse" and select the XXXXXXX_000DE001.FSC file you generated in step 3, it should be in your tools directory. 6. Choose your map product from the list (For me it was "Road Map EUROPE NEXT 2015-1) 7. Click "Generate" Thanks |
FlorinQCK-2.50 |
11-05-2016, 10:58 AM | #1262 |
Rep 8
Quick question gents. I had previously successfully updated my 2013 F10 NBT map from 2013 to 2016-1 last year using Kriszty's tool in this thread. I now want to update to the NBT 2017-1 map. Which of the steps can I bypass now since I had already read the FSC and decoded it. Do i just make the necessary changes in the lookup.xml file to reflect the latest map (0xA8 and 0x28 and 2017-1...etc) and jump to the last step to generate and retrieve the new map code?
**Edit** I just went back and read all 58 pages to refresh my memory. I did use Kriszty's tool. I may have used FF to generate my code, so I'll check to see if my prev. code will work for latest 2017 map. If not, i understand I just need to update the xml file and use Patrick's tool to generate new code? Thanks Last edited by turbogate; 11-06-2016 at 08:45 AM.. |
FlorinQCK-2.50 |
11-07-2016, 05:31 PM | #1263 | |
Rep 8
Hope that helps the next person. Cheers. |
FlorinQCK-2.50 |
11-09-2016, 01:05 PM | #1265 |
Rep 40,752
Just use 0x28 0x29.
FlorinQCK-2.50 |
11-09-2016, 02:16 PM | #1267 |
Rep 40,752
I just gave it to you, 0x28 0x29:
SWID_FscShort=00280029
FlorinQCK-2.50 |
11-10-2016, 11:45 AM | #1268 |
Rep 1
Hi, gents!
Can you advise, if it is possible to get DE file with SWID_DE_reader using EDIBAS 7.3 (BMW Stand. toolkit)/K+DCAN cable (USB) on F06? SWID_DE_reader seems to work fine/connected/load VIN/load FSC data- but the length of NNXXXXX_00DE0001.fsc is 63b... |
FlorinQCK-2.50 |
11-10-2016, 08:38 PM | #1270 |
Rep 40,752
Yes.
FlorinQCK-2.50 |
11-12-2016, 09:58 AM | #1272 |
Rep 18
Hi,
Could you please provide me following two sets of SWID_FscShort? 1. NBT / NEXT Europe / 2017-1 2. CIC / Premium EAST Europe / 2017-1 Is there any app to generate the SWID codes? Or any .pdf to consult directly? I am using the DOS generator, is there any Windows app to generate the FSC directly? Many thanks in advance! |
FlorinQCK-2.50 |
11-12-2016, 10:05 AM | #1273 |
Rep 40,752
You shouldn't in that case.
FlorinQCK-2.50 |
11-12-2016, 10:05 AM | #1274 | |
Rep 40,752
2. 0x28 0x29
FlorinQCK-2.50 |
11-12-2016, 10:44 AM | #1275 |
Rep 311
Hey guys trying to generate a code for the newest next maps
Ive changed the lookup file to say the following but the code keeps getting rejected when trying to put into the car Any ideas <SgbmId id="NAVD_000014B9_255_003_240" SWID_FscShort="00A90029" name="Road Map EUROPE Next 2017-1" supplier="NTQ" sop="01.07.2012" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> |
FlorinQCK-2.50 |
11-12-2016, 11:01 AM | #1276 |
Rep 40,752
All that matters is " SWID_FscShort="00A90029" name="Road Map EUROPE Next 2017-1", and that is correct. Your problem lies elsewhere.
FlorinQCK-2.50 |
