04-04-2014, 04:35 PM | #45 | |
Rep 44
I should have taken the car on a longer test drive prior to purchase, but I was too smitten with the rest of the car, I doubt I would have changed my mind. As much as I love getting a 330D next, I am going to wait for the new c class and see if it lives up to the initial reviews regarding its supreme refinement. |
04-04-2014, 04:41 PM | #46 | |
Rep 5,021
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys |
04-04-2014, 06:24 PM | #47 | |
Rep 44
Looks wise you are right, M sport really is the best looking, i still regret not getting it!. The engine choices on the new c class is shocking, no 6 cyclinder option, and still soldering on with the 7 speed autobox when they have the 9 speed. Tyre wise, the 19in will ride on RFT though. Seems more and more manufacturers are trying RFTs like Infiniti |
05-31-2015, 06:26 AM | #48 | |
Rep 12
05-31-2015, 06:29 AM | #49 | |
Rep 12
I'm interested in your permanent solution or did you just leave the rags in place? I too have been struggling with high tyre noise on a 320i - which doesn't have the foam in the door likes the diesels - and interested in how you solved it permanently? |
05-31-2015, 10:10 AM | #50 |
Rep 729
I've left mine with the rags stuffed tightly in place (I check every so often that they haven't come loose) and with the foam stuffed in the vertical gap in front of the doors. It's been like this for a long time now and the engine/tyre noise is acceptable now. I just wish I could say the same about the wind noise from the passenger's side window area. Interestingly the wind noise from the window is markedly reduced after it's rained, due I'm guessing to water filling the gaps and forming a temporary seal.
05-31-2015, 11:22 AM | #51 | |
Rep 12
05-31-2015, 11:33 AM | #52 | |
Rep 32,881
05-31-2015, 11:48 AM | #53 |
Rep 12
I did think about it but didn't want the inconvenience and think the ride quality is good on the Sport. Made a massive difference on my old E91 330i SE though.
05-31-2015, 02:30 PM | #54 |
Rep 729
Replacing the runflats is on my list, but I don't do mega miles so they are lasting annoyingly well. Maybe I need to drive faster, or do a track day
05-31-2015, 02:32 PM | #55 |
Rep 729
I looked at it briefly, but it looks like the inserts are put in during assembly, and would a right b*st*rd to fit with the limited access there is.
08-27-2015, 11:28 AM | #57 |
Rep 1,034
I came across this post and decided to have a look at my LCI 330i. The holes mentioned in the original post in the engine bay are blocked off with some foam type bungs with a plasticised coating presumably to keep it waterproof. I also looked at the gaps in front of the doors between the wings and the body, and again these are filled with foam. So it looks like BMW have been looking at the road noise issue themselves and made some changes.
08-27-2015, 11:31 AM | #58 | |
Rep 9,709
08-27-2015, 01:24 PM | #59 |
Rep 215
That's about right. The road noise in my old F31 was just not funny.
Rich
Current : 2022 G05 X45e Previous : G30 520D SE / F10 520D SE / F31 320 M-Sport Touring / E92 320D SE Coupe |
08-27-2015, 03:40 PM | #60 | |
Rep 8,495
08-28-2015, 04:03 AM | #61 | |
Rep 22
Any chance of finding the part number on these? thanks.
04-12-2016, 01:59 AM | #62 | |
Z4 35is
58
Rep 270
I used wool insulation (used in wooden walls for insulating thermally). What material do you recommend? |
04-30-2016, 02:09 AM | #63 |
Rep 8
Hello
I found parts nr. 29 and 33 missing from my 328i. These parts are on diesel models only i think. Can anybody take a picture from these so I could look if could make or should I buy those. http://www.realoem.com/bmw/enUS/show...diagId=51_8669 |
01-13-2017, 11:08 AM | #64 |
Rep 1,482
So, does anyone have any other fixes to try that have been confirmed to reduce road noise? I plan on undercoating the plastic fender line on both sides and applying dynamat. Its baffling why BMW just had it sitting there exposed to the engine. Even base model VW's have the carpeted fender liner as its the most important source of road noise
01-13-2017, 11:23 AM | #65 | |
Rep 186
