04-28-2015, 04:02 PM | #8538 | ||
Rep 40,752
04-29-2015, 01:15 PM | #8542 | ||
Rep 40,752
04-29-2015, 10:42 PM | #8543 |
Rep 6
camera coding as dash cam
has anybody able to look into or know about coding the available cameras ?
I have started this thread, would be great to have inputs/thoughts. http://f30.bimmerpost.com/forums/sho....php?t=1120868 Thanks ! Jay |
04-30-2015, 10:37 AM | #8544 |
Rep 191
Drives: '17 340i X-Drive M Sport EBII
Need some help, when I click activate FA, it gives me the error "no FP could be generated from FA''.no FA2FP known for entwicklungsbaureihe F032 [858]"
But if I read the ecu and click on a CAFD file it says "file for 'cafd_0000b0a- etc not found" Edit: It seems that the dealer updated my software and now I have the v55 which means I can't code. |
05-02-2015, 04:21 AM | #8545 |
Rep 179
Hope someone can help me with this.
I had some issues to make my own cable (didn't get it to work) So I bought a cable from onestopelectronics. Problem is, I can't get this cable to work either! I don't get any connection between the car and computer. The link light where the RJ45 connects to the computer doesn't turn on.. What's the problem here? Some settings I need to do on my computer? firewall and all anti-virus is turned off. |
05-02-2015, 04:32 AM | #8546 | |
Rep 40,752
PM sent.
05-02-2015, 04:34 AM | #8547 | |
Rep 40,752
05-02-2015, 04:43 AM | #8548 |
Rep 179
05-02-2015, 04:50 AM | #8549 | |
Rep 40,752
Try Resetting Network Adapter (Winsock Reset): Click on the Start button then Programs->Accessories and click on Command Prompt. Press Ctrl-Shift-Enter keyboard shortcut to run Command Prompt as Administrator. Type "netsh winsock reset" then press Enter. Once it’s complete, you’ll see the message “Winsock reset completed successfully”. Type "ipconfig /release" then press Enter. Type "ipconfig /renew" then press Enter.
05-02-2015, 05:01 AM | #8550 | |
Rep 179
05-02-2015, 05:02 AM | #8551 |
Rep 40,752
Just reboot laptop.
05-02-2015, 05:21 AM | #8552 |
Rep 179
05-02-2015, 05:45 AM | #8553 |
Rep 40,752
Not really. You need to try your laptop / cable in another car if possible. Maybe something is wrong with your OBDII Port. If it doesn't work in another car, then you need to swap out cable and laptop one at a time and see if one makes a difference. It's the only way to start narrowing down what the issue is.
05-02-2015, 07:04 AM | #8554 | |
Rep 179
05-02-2015, 07:05 AM | #8555 |
Rep 40,752
I would.
05-02-2015, 07:27 AM | #8556 |
Rep 3
hi all
i have f30 i-step F020-15-03-504 i use e-sys 3.26.1 and pzdsdata 2.54.2 when i coding KOMBI - its OK, but when i coding FEM_BODY or REM or FEM or IHKA or HU or ICM or EGS or ACSM i look error - not found CADF file where i can get CADF's ? |
05-02-2015, 07:31 AM | #8557 | |
Rep 40,752
PM sent.
05-02-2015, 07:39 AM | #8558 | |
Rep 40,752
