BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Rock Guard DIY
      10-31-2018, 10:36 AM   #23
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
Well worth doing now the gritters are out.
Current car.M240i.
Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
      10-31-2018, 10:49 AM   #24
stevei
stevei's Avatar
Drives: 420i M Sport+
How do you get the kidney grills out (F32)?
420i M Sport+
      10-31-2018, 11:00 AM   #25
creepy coupe
1867
2009 335i  [0.00]
When I did my grilles . I took the four bolts out under the rubber strip at the top and the managed to get behind them.
Current car.M240i.
      10-31-2018, 11:06 AM   #26
stevei
stevei's Avatar
Nice one cheers
I might as well swap my chrome grills for gloss black at the same time.
420i M Sport+
      10-31-2018, 11:14 AM   #27
creepy coupe
1867
2009 335i  [0.00]
Nice one cheers
Once you get one out. It's much easier to remove the second.
Current car.M240i.
      10-31-2018, 12:33 PM   #28
Ss66
Drives: F32 440i
Took me about 10 mins to pop the old grills out,without breaking the old one's. I did this with just putting my hands through the slats and slowly working my way round unclipping each clip.
2014 f330d
2015 f335d
2016 f32 440i tanzanite/white merino
2008 Toyota Yaris sr
2005 e46 320d. 1996 316i.
      10-31-2018, 03:44 PM   #29
TiredGeek
Old Fart
TiredGeek's Avatar
Drives: 335dx F31 Shadow EB
I just made sure I did it on a warm day, stuck my fingers through the slats, held my breath and yanked HARD. Both just popped out with no broken tabs.
I think if the plastic is old or cold my method would break the tabs but on a newish car in the warm it's fine
The doctors said it's OK to listen to the voices..... just don't do what they tell me
      06-22-2019, 01:49 PM   #30
carl2990
Drives: BMW 430d 2015
Finally got round to doing this today, but can't figure out how you mounted the lower plastic, there's no X-cross bars to mount to.
How did you mount the lower portion?
      06-23-2019, 01:45 PM   #31
TiredGeek
Old Fart
TiredGeek's Avatar
I put mine on outside but the OP explains how he did it in post #1
It's an interference fit.
      06-24-2019, 11:55 AM   #32
willjames
willjames's Avatar
Drives: G01 X3 3.0d M Sport
The Rock, guarding...top job
      03-03-2020, 05:54 AM   #33
Alscoob
Alscoob's Avatar
Drives: G31 540i M Sport Edition
Digging up an old thread but, discovered this week when in for some warranty work, that at 18K miles my AC rad has stone damage and has lost all the gas. Dealer was quoting £825 all in to replace
So as it's not a cheap job to replace suggest that you guys seriously consider protection as described. The rock guards are available separately from BMW if you prefer OEM
rock guard x2 Part no. 1711 848 5042
left mount Part no. 1711 948 7032
right mount Part no. 1711 947 7033
I was quoted £132 for the above parts from Cotswold inc delivery etc.
Needless to say that my specialist indi will be doing it but it's still a 3 hour job and with complete refill regas, rad & guards, it's still around £630.
Just a heads up, hope it helps.
Watsey6415.50
Tux22.50
      03-03-2020, 07:36 AM   #34
AlwynMike
Drives: F36 440i GC.
Obviously they didn't think it was a warranty job even though there is a problem with the design and there is a OEM fix!
      03-03-2020, 07:59 AM   #35
Alscoob
Alscoob's Avatar
Nope, external stone damage not faulty part.....just faulty design!
      03-16-2020, 01:54 PM   #36
Tux
anyone have any real pictures of these parts and / or install instructions?
      03-17-2020, 04:11 AM   #37
Alscoob
Alscoob's Avatar
So my parts were replaced yesterday (low pressure rad, brackets and rock guards). Didn't need a regas as there is a separate condenser unit and the rad in question is purely to cool the condenser apparently.
I can take some pictures of it on the car for you later but not in such great detail as most is hidden The rock guards are horizontal plastic type units that fit over the upper and lower sections i.e. behind the front grille and lower mesh.
I looked for instructions on how to replace the units and it seemed that you had to remove the standard radiator first to then remove the low pressure one. However, my indi, did it the simple way and removed the front bumper so easy access from the front and didn't have to disturb the cooling system.
Have to say that considering the work / cost of the guard protection, if I hadn't needed to replace the rad part due to damage, I would just do a DIY guard as per the others on here, which I am sure is just as effective as the OEM parts.
      03-20-2020, 04:29 AM   #38
gippy
Drives: F32 440i, pre-LCI, w/MPPSK
i stumbled across this concept of needing a radiator guard after a totally random comment on youtube! jeez!
was already worried about corona, but now i'm REALLY panicking
i'm assuming there's an OEM part for the F32 as well? I'll have a look now - please do post pics etc once you get it done.
      03-20-2020, 04:37 AM   #39
gippy
Originally Posted by Techno 9000 View Post
Having seen the comments about damaged radiators, I realised how many bits mine had accumulated in the few thousand miles I've been running it. I think it must have been renewed just prior to buying it, as it was utterly as new last December, and now looking somewhat secondhand.
I was looking at the BMW rock guards, but decided they;
1. cost a bit
2. took a bit of dismantling to fit
3. didn't cover the whole rad in any case
Sooo, I took a look at the bay of e, bought some mesh [Universal Honeycomb Black Plastic vent car tuning racing Grill Mesh 40x120 cm ( 371513683770 )] for under £20 and have fitted it in front of the diagonal stay bars with a few cable ties.
Hi,
many thanks for this, i'm going to do the same rather than enquire about OEM - your ebay part still exists too.
I was wondering if you could take pictures of exactly where you've put the cable ties?
i know yo'uve described where to put the ties for the top mesh, how about for the intercooler?
thanks
EDIT: You did say "no fixing for this piece" (reading properly now) - ok so it's just sort of been slotted in there 'freely' and wedged in? didn't quite get what you meant by making the piece a bit bigger etc...
      03-20-2020, 05:53 PM   #40
Techno 9000
Drives: 435D Estoril Blue
Hi Gippy,
...to do the area in front of the intercooler...
No fixing for this piece, i just made it slightly longer (wider) than the area available, so that it bows forward to keep it clear of the intercooler and prevent it rattling about. To clarify this piece sits at the base so it cant drop down any further.
This rock guard has worked a treat, no issues at all since fitting.
An update in regard to power available since I have now had a remap.
Attained 363bhp on a rolling road with a custom / live remap to my requirements last Autumn. A pre-map run giving 309bhp so no obvious issue.
      03-21-2020, 01:20 PM   #41
jackstrath
Scotland
659
Drives: 16' F31 340i & 03' Focus RS
i retro fitted the guards to mine not long after i got my car, i didnt go for the brackets as i figured id be able to attach them with cable ties. And i did.
Washing the car before i came offshore last week and there was a decent size stone in between the front grill and my protected charge cooler rad ... needless to say im certain with out that guard id of had a hole int he charge cooler rad! so yeh money well spent and i would highly recommend doing this if you have a b58 engined car.
      03-21-2020, 01:38 PM   #42
un1eash
Drives: M235i
Effects B48 engine cars also, my 2018 F36 has them fitted from factory.
      03-23-2020, 05:03 AM   #43
Alscoob
Alscoob's Avatar
Here you go you can see the nice clean rad behind the guards. The guards are set immediately behind the front grilles and the lower grille, not necessary in between as the bumper protects it.
      01-31-2024, 12:28 PM   #44
RyanCawdor
Top piece I cut to 69 cms wide by 21 cms tall.
The intercooler piece 73 cms wide by 19 cms tall.
Did this to my wife's F20 LCI today. Astonishingly the same part (even the same item ID) was still listed on ebay UK.
Your dimensions were also pretty much spot on for an F20 (I ended up with the bottom piece a little less than 73cm).
Removing the grills was the biggest hassle, harder on an LCI than a standard F20, ended up unbolting the top of the bumper and jamming my arm in.
Thanks for sharing.
diy, f30, guard, rock
