BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > BMW N20 Turbo Coolant Lines Replacement DIY
      08-13-2019, 02:22 AM   #1
jbarron16
Drives: BMW 328I
Hey guys I'm kinda a newbie around here been browsing around for some time now but receptively in dire need of some advice. I have a 2013 BMW 328i with the n20 engine. currently in AZ where the heat and time has ate away at my coolant lines O rings that feed and return to my turbo. instead if only replacing the O rings i decided to replace the whole part
Product Here:
https://www.bimmerworld.com/Exhaust/...-X3-X4-Z4.html
I have been looking everywhere for advice on how to replace or even tips on replacement. i have found some literature that ill link to this post that I will use to guide me throw the removal but if anyone has some light to shed on some key points I am concerned about that would be great.
1) Looking at photos and under my car at the connectors for these lines they peak out where they connect to the turbo but i have not seen where they connect to the rest of the cooling system. diagrams i have posted show it to the engine block i believe but am not sure
Question: Do i have to remove the turbo to replace lines?
Sub- Question: if not how would i get around to the back of lines.
2) if the turbo is coming off will my electronic waste gate have to be readjusted. i looked pretty connected to the rest of the turbo and doesn't look like id have to remove that piece specifically would i have to readjust after?
if i could get some help on this guys i would really appreciate it.
Thanks,
Fellow enthusiast
Dina Turbocharge upgrade instructions:
http://files.dinancars.com/webresour...980939aa03.pdf
Removal of Turbo:
https://www.newtis.info/tisv2/a/en/f...rol/1VncVNIBeg
Understanding of engine components:
https://f30.bimmerpost.com/forums/sh...d.php?t=856528
BWbimmer276.50
      08-13-2019, 04:16 PM   #2
jbarron16
Drives: BMW 328I
Bump
Come on guys anything?
      08-13-2019, 05:00 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Removing and installing coolant return line is in newTis.
      08-13-2019, 07:41 PM   #4
jbarron16
Drives: BMW 328I
Thanks for the reply! I did see that removing the exhaust turbo charger is the first step for that but I also saw other users say it's possible without removing. To be honest I'd prefer not removing it but if it has too I will just wondering if anyone else had done it before.
      08-13-2019, 10:07 PM   #5
Billfitz
Billfitz's Avatar
Removing the turbo is a major PITA, so I can understand not wanting to do that if at all possible. I haven't had to change my coolant lines so I can't say if it's possible or not. BTW, are you replacing the coolant line or oil feed line? Two separate items. Three actually, as there are two coolant lines, in and out.
      08-13-2019, 10:41 PM   #6
jbarron16
Drives: BMW 328I
Yeah I'm hoping to take a look tomorrow on a lift to see if I can skip the removal and it's both the suppling and returning coolant lines
      08-14-2019, 07:28 AM   #7
Billfitz
Billfitz's Avatar
The reason I asked is that the part you linked is the oil line, not one of the coolant lines.
      08-14-2019, 11:32 AM   #8
jbarron16
Drives: BMW 328I
midnight posts!! I put the wrong link. These are the parts that I bought.
https://www.ecstuning.com/b-genuine-...e/11538663516/
https://www.ecstuning.com/b-genuine-...e/11538663517/
      12-23-2020, 03:30 PM   #9
radeohedca
Drives: 2013 320i
Did you ever successfully install these parts yourself ?
One of mine is leaking coolant.
      10-23-2021, 09:45 PM   #10
F34_Crew
Drives: BMW 328i GT xDrive
Same boat, anyone tackle the upper coolant line?
      11-25-2021, 06:35 PM   #11
pcking
pcking's Avatar
Drives: 2014 BMW 320i xDrive
Same here, dripped on the exhaust and I smelled it
      01-18-2022, 10:57 AM   #12
nathanday
Drives: 2016 328i
Currently at the dealership
In for an oil change. (I have a disdain for changing oil) They are getting me an estimate for turbo coolant lines. I'm obviously not having them do it! Have you guys had any luck DIY?
      01-29-2024, 08:35 PM   #13
Grateful_Newt
Drives: 2015 BMW 320i
Seems like lots of people are having issues woth these leaking, but there doesn't seem to be a good write-up on how it's done. I am about to tackle this on my 2015 320i. It doesn't look like it's possible to change the lines without removing the turbo, but I found a good video on YouTube I wanted to share with you guys, since I'm going to try this before removing the turbo.
This guy reasons that the leak is likely coming from the turbo side of one or both of those lines. Since they are situated so close to the exhaust manifold, it does seem reasonable that these gaskets would certainly deteriorate faster, causing a minor coolant leak. In my case I didn't notice any coolant leaks at all. A couple weeks ago, the head of the coolant bleeder screw in my expansion tank blew off on the highway, leaving me stranded. I had it towed home, drained the cooling system, installed a brand new expansion tank, aluminum coolant flange, and since I was right there anyway, did the upper radiator hose, and vent hose (to expansion tank).
When I pulled vacuum on the system to fill it, I could see that there was a small leak somewhere because the guage was dropping. I turned off my compressor to listen, and sure enough, I could hear a tiny pinhole leak sucking in air. I couldn't actually see it, but it was coming from the turbo. What I COULD see was some white residue on my exhaust manifold that I believe is from coolant. Anyway, I'm gonna try it, and here is the video. I'll take pics and report back to y'all after I get done.
328i, coolant, coolant leak, f30, n20, n20 328i
