12-13-2013, 04:56 PM | #1 |
Rep 77
Transmission Possibly slipping?
Hey guys Ive had my 335 f30 running on jb4 stage 2 Map 7 e85 ER down pipe
Automatic feels like my transmission is slipping on 3rd gear roll off 40 revs up up to 4,500 rpm and feels like a choke rpm's keep going up but car goes no where first thought it was a choke but i guess not started happening when I updated the JB4 to the new software I changed it to map 2 and it doesnt happen on this map , I emailed terry sent him a couple of logs and he is taking a look over them hopefully it is not the transmission maybe just a bug
[FONT="Arial Black"]BMS JB4 DownPipe Flex Fuel[/FONT]
12-13-2013, 05:01 PM | #2 | |
Rep 1,975
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
12-13-2013, 05:04 PM | #3 |
Rep 77
Will do
12-17-2013, 02:52 PM | #5 | |
Rep 124
any news? |
12-17-2013, 03:54 PM | #7 |
Rep 4,709
You guys tuning with autos are crazy. The stock transmission is only rated to hold 332 lb ft. With OP's mods, he's definitely making over 400 lb ft.... maybe closer to 450.
/Edit/ Just looked up the ZF 8HP45 torque limit, and it's 450 nm, which is 332 ft lbs. No more than what a MPPK puts out. Last edited by kyleb350; 12-17-2013 at 04:07 PM.. |
12-17-2013, 04:24 PM | #8 | |
Rep 1,591
-JustinNApproved
12-17-2013, 07:20 PM | #10 | |
Rep 4,709
http://www.zf.com/media/media/produc..._DataSheet.pdf http://en.wikipedia.org/wiki/ZF_8HP_transmission Even if the diesel version is in there, 500nm is only 369 lb ft. |
12-17-2013, 10:19 PM | #12 |
Rep 923
Somewhat. Theirs has stronger internals to deal with more torque. Read somewhere that it's around 20lbs heavier...
But doesn't dinan offer a tune that doesn't void BMW's warranty ? It's rated at 355 hp and 400 pound-feet of torque...
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
12-18-2013, 09:15 AM | #13 |
Rep 1,715
Haven't many people been running upwards of 400 ft/lb's with no issues? I though stage 2 was still considered a moderate tune? Im looking to get one and possibly DP to go with my exhaust, but doubt Ill move from map 2, am I looking at any issues?
12-18-2013, 11:13 AM | #15 |
Rep 71
OP, I'm wondering what your fuel pressure may be dropping to in 3rd and 4th. I am running the same setup as you. Map 7, downpipe, and E85. I ran my car in the quarter mile last weekend and had some fuel pressure issues causing the car to bog a little in 3rd and 4th. If this is a fuel pressure issue, you may need to get an inline low pressure fuel pump (LPFP).
What is your PID set to? What is your auto shift boost reduction set to? Attach your logs for review if you want. |
12-18-2013, 01:30 PM | #16 |
Rep 1,647
My e92 6at is holding 450 torque with no problems.
Current: 2021 X3MC
Past: 2013 bmw 335i, 2011 bmw 335i coupe, 2016 bmw m3 |
12-18-2013, 02:34 PM | #17 |
Rep 923
What is the E92 6AT rated at ?
12-18-2013, 09:50 PM | #18 |
Rep 195
My car doesn't want to shift out of 3rd gear (I believe it's 3rd) either at around 60-65mph at wot, it'll go to redline and sit there about what feels like a half a second too long. It doesn't do it every time, but it does it enough that if I want to wot from low speeds I just use the paddles. Running JB4 map 1.
12-19-2013, 10:36 AM | #20 |
Rep 4,709
Went back and looked it up. The ZF 6 speed Steptronic (GA6HP19Z) transmission is rated at 400 nm. Very odd, since that is only 295 ft lbs. I think I'm noticing a pattern of these transmissions being underrated (for the most part). Either way, numbers aside, the F30 transmissions should be able to take a little more than the E90 ones.
12-19-2013, 11:55 AM | #22 |
Rep 195
Why do I wot without manual? Because an automatic should shift more accurately and faster than a human can? But you're right because it's not shifting until redline.
