BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > iND F30 painted bumper reflectors replacement DIY
      12-07-2012, 11:45 AM   #45
J-boogey
J-boogey's Avatar
Drives: F30 335xi Msport
is the installation for the M-sport ones the same as non-msport? and do the rears just pop out on the m-sport?
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
      12-14-2012, 04:04 PM   #46
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
Yes. The placement is different, but you can follow the same steps.
And yes to the question about the M-Sport rears. I've done them on mine and they just pop out.
For those with PDC/Cameras up front... have fun. I just did mine. First one took ~30 minutes to figure out the best angle of attack. I finally got it by going at it near the top (just above the camera/pdc holder). Once you hear it snap a bit off, you can pop them out by pushing the reflector in and holding the rest of the bumper in place.
Remember to remove the tacky, gunky stuff before inserting the new ones. It comes off easy if you roll it off with a finger.
      12-14-2012, 06:30 PM   #47
s1k0ne
Drives: ..
omg this thing is such a B***** to take off. almost ripped off my nails doing this
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM
F80 DCT (18) - Comp - AW
F30 6MT 335i - EBII
      12-16-2012, 12:45 PM   #48
jsedlak
jsedlak's Avatar
I thought the same thing until I figured it out. I cut my right pointer finger near the nail pretty good too.
      12-17-2012, 02:11 AM   #49
s1k0ne
Drives: ..
yea, it's no joke. i would recommend using a heat gun and heat up the area before doing it
F85 (17) - DG/AB
F30 6MT 335i - EBII
      01-07-2013, 04:13 PM   #50
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
+1 - the adhesive they use needs to be warmed up. I tried doing this in the cold (~45°F) and it wouldn't move, even after I got the plastic pry bar behind it.
Took the wifes hair dryer (I mean heat gun) and fanned it over the area for a few minutes to let it get nice and warm. After maybe 2-3 minutes it was super easy. Just started at the top (Msport bumper) and put a nice constant pressure with my thumb while supporting the back with the rest of my fingers (so that it wasn't just deflecting the bumper). Once you start to pull it loose you can keep blowing the hot air directly on the adhesive and it should come off very nicely. Then I just used the L shaped plastic prybar to nicely roll off the rest of the adhesive.
If I would've added heat from the beginning it would've taken 5 minutes. Spent 30 minutes thinking I could just pry it which was a mistake. You could actually see the bumper deflecting under the force of the prybar behind it.
Also be very careful around the outer edge, the paint doesn't go all the way into the hole and as a result it's very easy to chip or damage if you touch it.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      02-07-2013, 05:09 PM   #51
DesertSmokeBBQ
DesertSmokeBBQ's Avatar
Drives: 2014 F30 335i M-Sport
2013 BMW  [0.00]
Is there a DIY anywhere for the M-Sport bumper? (Or is the removal/install basically the same?)
'14 Estoril Blue II F30 - 335i - ZMM - ZPP - ZTP - ZPS -
2TP
Traded 9-1-13 '13 Estoril Blue II F30 - 328i - ZMM - ZPP -ZDY - ZTB - 403 - 465 - 494 - 4DX- LC (Black) - 6NL
      07-05-2013, 02:04 PM   #52
Glideslope
goldmember
Glideslope's Avatar
Drives: 2013 328i
just did mine...
Must also suggrest that you heat up the area with a blow dryer for about 5 minutes. After that, it took me "two thumbs" to pop the reflector out in 3 seconds. No tools needed.
After that, just use some Goof-Off or naptha (Rosignol lighter fluid) to remove the gunk residue, and you're golden.
Easy peesy
2013 328i Mineral Grey / Luxury Line / Technology Package (HUD) / Cold WX Package / Lighting Package / Premium Package / 15% Ceramic Tint / XPEL clear film half-wrap / G17 9mm / GMT Master IIc
      07-22-2013, 03:47 PM   #53
Nate@IND
Nate@IND's Avatar
2868
M-Sport painted reflector DIY
Here you go
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      07-23-2013, 02:53 AM   #54
sainismo
RSN
sainismo's Avatar
Drives: F13 M6
diy pics in high res..what more can i ask for thank you nate!
F13 ///M6 Frozen Black
      07-23-2013, 10:59 AM   #55
Nate@IND
Nate@IND's Avatar
2868
F30 iND painted reflectors on the new site now-
http://ind-distribution.com/ind/bran...reflectors-893
http://ind-distribution.com/ind/bran...reflectors-891
      07-23-2013, 12:46 PM   #56
sainismo
RSN
sainismo's Avatar
Drives: F13 M6
Originally Posted by Nate@IND View Post
I have a question, where can I find that yellow scraper thing you guys used in removing the amber reflector? It made the whole removal so easy that heat gun wasnt even needed.
      07-23-2013, 12:48 PM   #57
Nate@IND
Nate@IND's Avatar
2868
http://www.amazon.com/3-Piece-Non-St...d_sim_sbs_hi_2
      07-23-2013, 05:30 PM   #58
sainismo
RSN
sainismo's Avatar
Drives: F13 M6
Thank you!
      07-23-2013, 07:09 PM   #59
Glideslope
goldmember
Glideslope's Avatar
Drives: 2013 328i
Man, those EBII closeup pictures are sooooo heartstopping, they're almost Pornographic!
      07-23-2013, 08:45 PM   #60
sainismo
RSN
sainismo's Avatar
Drives: F13 M6
my thoughts exactly!
      08-03-2013, 04:06 PM   #61
B-1Pilot
Yankee Air Pirate
B-1Pilot's Avatar
151
Drives: '14 M5 w/CP
Just got mine on today.. makes the look I was going for complete:
2020 ///M5 || 2019 540XI || 2014 ///M5 w/CP || My Epic ED trip report|| || 2009 BMW R1200RT
      08-03-2013, 04:39 PM   #62
Glideslope
goldmember
Glideslope's Avatar
Drives: 2013 328i
Dearth Vader!!!
Love it.
      08-06-2013, 12:20 PM   #63
Nate@IND
Nate@IND's Avatar
2868
Clean
      08-11-2013, 07:27 PM   #64
6MMMT
Drives: 2015 M3 6MT
great call on heat gun, used a hair dryer and it came off piece of cake once you get the first corner up
      08-17-2013, 12:25 PM   #65
sainismo
RSN
sainismo's Avatar
Drives: F13 M6
did the mod yesterday, all i needed was an 8mm socket and my just expired credit card . As for the rear reflectors, how do you take them off?
      08-17-2013, 12:47 PM   #66
Greddy82
Drives: F30 320i
this will be my first mod thx
