02-20-2017, 05:32 AM | #353 |
Rep 69
02-20-2017, 12:53 PM | #354 |
Rep 230
Just a historical side turn: Nothing new under the Moon, something similar has happened just not far back: Mini Cooper (made by BMW ) 2007-2011 had very similar problem with timing chain and tensioners. It took a class action lawsuit to make BMW to recognize the problem and compensate those who suffered. We may expect something similar with N20 next year or so. BTW lawyers made $2.3M on that case, so if someone knows someone who wants to make some money - this may be a clear case.
http://blog.autoworkstx.com/mini-coo...-chain-issues/ |
Spanky_F3042.00 |
03-05-2017, 08:21 AM | #355 | |
Rep 23
03-10-2017, 09:36 AM | #356 | |
Rep 14
03-10-2017, 09:41 AM | #357 |
VIP
41
Rep 151
If you are thinking about that while driving - you should sell your car ASAP
Life is not measured by the number of breaths you take but by the moments that take your breath away...
03-10-2017, 09:43 AM | #358 |
Rep 5,994
There must have been a lingering problem due to manufacturing that finally caused a failure. Maybe a bad link in the timing chain. BMW should honor the fact that it's a defect and cover it. There's a word for that but I can't recall what it is. I myself have the 100k coverage for 6 years.
03-10-2017, 10:49 AM | #359 |
Rep 14
So you don't care about keeping your car running as smoothly as possible for as long as possible? This isn't something that takes minutes to think about. Just anticipate when you are going to take off like normal and take some pressure off the brake pedal a couple seconds before that. Takes no thought at all
03-10-2017, 01:46 PM | #360 |
Big Turbo Boys N Girls
327
Rep 579
ASS has been known to contribute to premature wear on the bearings of the crank shaft and many mechanics recommend to code that off. You can ask your Dealership to code this off for you when you get your next oil change. Also change your oil every 5K miles. 15K intervals are a joke and are designed to make the engine last up to warranty after that its on you. Also it was a cost benefit analysis and a marketing strategy to have low oil changes to justify the high price tag for cars. Yet again BMW Germany states and for that matter any real mechanic will say go up to 5 to 7K at most for oil changes.
Sludge build up is a real thing and lack of fresh clean oil will put more strain on parts and create heat. Oil gets dark not because of age, it's because of metal to metal wear. The darker your oil the more metal it has in it. The new design/update of these components seems to have fixed the issue as we do not hear about it any more from the new models but than again that might be because of the new engine design as well. There is a reason BMW scrapped the N20/n26 is such a short period of time. Last edited by D041987; 03-10-2017 at 01:56 PM.. |
03-10-2017, 04:32 PM | #361 |
Rep 943
Drives: 2012 328i Modern Line
I think BMW used n20 owners as guinea pigs with their first turbo 4cyl.
:wave:
03-12-2017, 08:21 AM | #362 |
Rep 55
My 428i (april 2014) has 60.000km on the clock and last week the oil pump and timing chain have been replaced. I had luck that I heard a high pitched noise the last couple of weeks, which wasn't normal and was I just on time to replace the parts. Otherwise an engine blow wouldn't have been far away...
Luckily all of this (3 days of work + parts) have been covered under warranty by BMW, altough my car is almost 3 years old and the standard warranty is already expired. With the new improvements on this timing chain, this problem should be solved... Crossing fingers... |
03-13-2017, 12:40 AM | #363 | |
Rep 34
Could you report back if the whine noise returns? because I replaced the chains with the oil pump and shafts and the whine returned in a few thousand kilometers |
03-13-2017, 12:48 AM | #364 |
Rep 5,994
03-13-2017, 01:51 AM | #365 | |
Rep 55
I only heard the noise when the engine was cold. |
03-18-2017, 01:08 PM | #369 |
Rep 4
Recently purchased a 2013 328i with 72k miles so as you might imagine - I'm a little concerned. So in reading through this thread along with others on the web about this issue, what exactly fails causing the engine to grenade? To me it looks like it's one of 3 things, but i'm not sure which one?
1) the orange plastic chain guide breaks, perhaps as a result of oil pump failure causing too much friction from lack of lubrication? 2) timing chain snaps because of faulty tensioner and/or defective chain? 3) oil pump chain snaps because of defective manufacturing? 4) combination of above or something else? It seems that BMW recognized one of these was the issue since all the pieces were replace with N20's built after 01/2015. Secondary question, how much should it cost to replace the entire timing chain mechanism? I was quoted 4k by dealer and that did not include oil pump. Given the cost of materials, that adds up to about 3.5k in labor which sounds absurd. Is this something that can be done by a competent mechanic? Thanks in advance. |
03-18-2017, 02:05 PM | #370 |
Rep 962
For this money I would get an extended or 3rd party warranty. It will cost less than proactive complement replacement and will also cover other things. Chances are your engine will be just fine.
03-23-2017, 12:38 AM | #371 | |
Rep 8
04-30-2017, 01:21 PM | #372 |
Rep 5,089
To the unfortunate owners who have encountered timing chain failures, was a check-engine-light and/or fault code triggered before the catastrophic failure?
05-18-2017, 10:03 AM | #373 |
Rep 8
I am having the same issue with my 2013 X3 (I live in Canada). My vehicle is out of warranty with 93 000km. I had the dreaded "drivetrain malfunction warning) and brought it in to my local BMW service centre to get it looked at. I mentioned the timing chain issue but after looking at the car they said all it needed was upgraded software which costed me approx. $900 Included a brake flush). 10 days later the "drivetrain malfunction warning came back" and it turns out it is a timing chain issue after all, they are asking $5500 to get it replaced. I told the service rep. i was aware this was a common issue and he offered me a 10% discount. We went back and fourth for a bit and I'm now waiting to hear from the manager. How was your situation resolved? It is difficult for me to determine what an acceptable compromise should be.
05-18-2017, 10:23 AM | #374 | |
Rep 785
