04-08-2015, 12:22 AM | #45 | |
Rep 341
To be honest I don't see why bmw would pre-wire for that since it seems they have separated these functions on purpose so it can be easily installed at the factory based on the order. 2) I think we will need an extra internal antenna and 3 external antennas. 2 in the side skirts and 1 in the rear bumper. The extra internal antenna goes in the cargo trunk area by the fuse box. 3) I'm not sure I see them. What is the label from the diagrams? Last edited by f30GTR; 04-08-2015 at 12:33 AM.. |
04-08-2015, 12:51 AM | #46 | ||
Rep 1,035
3) Its the bottom of the first pic.... where they showed the exposed door and you can see the inside skins. The module is marked in blue (for driver's side) and is located right by where the door hinges are. The label doesn't really say anything about it. It just shows the location of this thing in the picture. |
04-08-2015, 01:07 AM | #47 | |
Rep 341
3) X28*1B would be the connector that goes from the door to the car. It looks like a hose or must cars would run the wire with no break between the door and chassis. Bmw had a plug to separate the harnesses I guess for easy repairs. We can definitely get to the bottom of this. We have gotten a lot further than before. |
04-08-2015, 01:23 AM | #48 | |
Rep 1,035
I actually assumed X28*1B was the retrofitted latch.... but wasn't sure. I was referring to X108*1B. Thats the part that made me scratch my head |
04-08-2015, 09:16 AM | #49 | |
Rep 341
Aftermarket system work with proximity and unlock your car because it's easier to integrate and no additional hardware is need like in our case we need new door handles. As far as X108*1V that only shows the break down of the cable. Different sets of cables go into different directions. My only concern here is if a new locking mechanism is needed. When I had the door torn apart I checked what goes toward that side and I found 7 cables. 2 were going to the LED and 5 go into the locking mechanism. The 2 cables for the LED did break out before the mechanism instead from the mechanism. The thing that got me thinking is that the 5 cables were in a plug that had space for 7. When I unplugged to see the pins on the locking mechanism there were only 5 pins with no additional holes for extra pins. That doesn't mean that a new mechanism isn't needed or needed. It just means that usually plugs with extra empty holes means more features can be added. Looking at the electrical diagram it does say the locking mechanism is connected to the door handle on pin 1 (or pin 4) and another cable goes into FEM. So I think roxxor is right about additional locking mechanisms needed. The unfortunate thing is that realoem shows the same part number. Not to disappoint but if new locking mechanism is needed this would be really cost prohibitive as the door handles are $175, harnesses $100, locking mechanisms $175. Extra 2 antennas at $45 each. That is $1000 assuming the main wiring harness that goes into FEM and antennas is there and it does not include the trunk opener. |
04-08-2015, 11:12 AM | #50 |
Rep 341
I guess I stand correct. It looks like I have locking mechanism part # 51217202146 which has the alarm since my car is 335i and no comfort access. In the picture you can see there is pin 1,2,3 and 4 and 5 are missing and 6 and 7 are there.
In the other picture which is part # 51217202143 and it has the option for alarm and comfort access it has all 7 pins. So this is definitive proof that a new locking mechanism is needed aside from door handle and new harness. Still there is hope though. If the main harness is in the car we can always try to wire just one door and see if we get away with just that. roxxor was definitely 100% correct on needing a new locking mechanism. I misread the realoem diagram. Last edited by f30GTR; 04-08-2015 at 12:02 PM.. |
04-08-2015, 11:58 AM | #51 |
Rep 12,994
I do not think that you need a new driver's door harness as there is only one listed regardless of S322A (CA). What I do think is that the CA locking latch makes the driver's side harness CA-ready once plugged in.
For sure, the driver's side handle and the CA latch are required (your car seems to have the OEM alarm and the theftproofing device together, thus those missing pins). For the driver's side antenna, a new custom 2-wire harness is required -from pins 9 and 27 at the A173*9B connector of the FEM to the driver's door sill location of the antenna. That should work for the driver's side only after coding. Last edited by Technic; 04-08-2015 at 12:04 PM.. |
04-08-2015, 12:39 PM | #52 | |
Rep 341
And yes you are correct only 2 wires for the antenna straight from FEM which should be fairly easy unless you get too OCD of where the cables go. From the door handle we will need 2 cables to go to FEM and 1 to the passenger door unless we can get away without connecting them and also that cables needs to connect to this KI.30F (still don't know what it is ) Also one from the locking mechanism to FEM and 1 from the locking mechanism to door handle. It would be nice if i don't have to go down the route of making my own wiring. I will need plugs, pins and know where each cables goes to exactly what. For example pin 9 from FEM would go to which pin on the antenna? We need the pin outs for the antenna. But in all you are definitely correct a custom wiring can be done considering we can find the plug for FEM and having lots of beer and time. Last edited by f30GTR; 04-08-2015 at 12:45 PM.. |
04-08-2015, 01:07 PM | #53 | ||
Rep 12,994
This should be enough for the driver's side functionality. |
04-08-2015, 01:37 PM | #54 | |
Rep 341
04-08-2015, 03:36 PM | #55 |
Rep 12,994
No connector at all plugged into driver's handle?
04-08-2015, 03:58 PM | #56 |
Rep 341
Nope the only thing there is the cable for the LED on the keylock. I even traced the whole bundle of cables to make sure bmw didn't just zip tie it somewhere. I thought the harness might have the cables for CA because someone here mention that their dealer told them that the rattle from the door was from the CA cable which the person didn't have.
04-08-2015, 04:33 PM | #57 | |
Rep 12,994
04-08-2015, 05:20 PM | #58 |
Rep 341
04-08-2015, 05:38 PM | #59 |
Rep 341
And here are the bad news. I've checked my FEM and the blue plug A173*9B does exist but I only have 5 cables that go into pins 50,51,52,53, and 54. No cables for pins 9 through 12, 15, 16, 27 through 30, 34 and 35. What this means is that if we were to try to retrofit CA we will have to wire it ourselves. Do i feel adventures? Yes, but not right now. I am planning to finish my PDC backup camera retrofit first and then I might tackles this. I might start with 1 antenna and wire the driver side door.
Oh, also FEM is short on pins on that side but it does seem like all the necessary pins are there for retrofit are there. As you can see there are 3 rows of 11 pins each where the connectors' housing can take up to 54 cables. The plugs that go into FEM seem to be just housings that contain cartridges of each row of cables that is held by a cartridge. If you look in the picture where the pins are you can see 3 rows of pins. My connector only contains 1 row of 18 pin cartridge. I don't see 18 pin cartridge on realoem. Number 10 from the realoem diagram shows what the cartridges look like. Actually the images from ISTA on the previews page clearly show the cartridges work with the connector's housing http://www.realoem.com/bmw/showparts...80&hg=61&fg=15 Last edited by f30GTR; 04-08-2015 at 05:45 PM.. |
04-08-2015, 06:12 PM | #60 |
Rep 341
Squidlyboy, is there anything else more to this diagram? I want to figure out the pin out for the antennas. Your diagram shows the wiring for pins 33 and 34. I guess we need to figure out pins 9-12, 15-16, and 27-30. Anything would be helpful.
Also, i want to say big thank you to all that are contributing to this thread. Even though we might not have accomplished a whole a lot (yet) at least we are trying and honestly this is fun, but anyways big thanks to all. |
04-08-2015, 07:42 PM | #61 | |
Rep 1,035
I guess you have to settle for it in parts. I tried to break it out and group it based on the connector. So you have:
Let me know if you see any mistakes and I can update this ... |
04-08-2015, 08:36 PM | #63 |
Rep 1,035
Really odd... but the latch/lock mechanism/module was not on the detailed "Comfort Access" wiring/schematic (above set of diagrams) that included the pin/wire numbers.
This Comfort Access diagram (below) was the only place I could find where it was even identified but there are no wire numbers associated with this particular diagram. Looking at it though, it seems to have only two wires to it, and one is ground. I'm guessing the other wire that connects it to the FEM is an existing connection that is already there... pre-Comfort Access retrofit. That's my guess. Roxxor... any inputs here? Maybe you can take a peek in your Rheingold and see if you can turn up something I may have missed... |
04-08-2015, 08:49 PM | #64 |
Rep 12,994
The missing piece in here is the 7-pin diagram of the CA latch. Both the CA driver's handle and antenna pins are properly identified already.
04-08-2015, 09:44 PM | #65 | |
Rep 341
04-08-2015, 10:12 PM | #66 | |
Rep 341
