BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Cool feature, find something, learn anything?
      11-27-2012, 11:53 AM   #661
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
It took me about 10 minutes to find the heated steering wheel button... so for those reading this, or finding it via Google Search - it's located on the left side of the column near the adjusting lever. It has a little light that turns on when the wheel is being heated, but it is generally obstructed by the wheel itself so you have to look for it. Stupid design, IMO.
      11-27-2012, 03:32 PM   #662
woderd
Drives: boat
Originally Posted by jsedlak View Post
I realized last night the MT has a hill brake... which is sort-of-win.
Oh, and the buttons to adjust the hugginess of the seats are absolute win.
Where is the hill break?
      11-27-2012, 03:51 PM   #663
jsedlak
jsedlak's Avatar
Not sure what you mean? I don't know where the setting is in iDrive to disable it but you don't do anything to engage it while it's enabled.
      11-27-2012, 03:56 PM   #664
woderd
Drives: boat
ohh its automaticly applies the break on a hill?
      11-28-2012, 02:31 PM   #665
Messer-schmitt
Messer-schmitt's Avatar
Drives: 2012 BMW 328i
I dislike that I have to peak around the steering wheel while driving to see if it's still on or not.
'12 Jet Black 328i 6MT Sportline
Originally Posted by JBasham
Caddy ATS . . . finally, a decent rental car option.
      11-28-2012, 02:36 PM   #666
Carnook
Drives: iX
Agreed. The only two ergonomic fails in the F30 for me are: placement of heated steering wheel button, and the automatic windshield wiper light is obstructed by the steering wheel.
      11-28-2012, 03:02 PM   #667
pkimM3r
pkimM3r's Avatar
205
Wouldnt it be warm? Lol.
      11-28-2012, 04:15 PM   #668
David328M-Sport
Australia
101
Originally Posted by bcl0328 View Post
and not sure if everyone knew, but the automatic seems to have a hill brake too.
Introduced in the E90 almost 8 years ago.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      11-28-2012, 06:12 PM   #669
bcl0328
Drives: 2012 328i
when on a hill and your foot on the brake, press down and let go. it holds for you.
      11-28-2012, 06:12 PM   #670
bcl0328
Drives: 2012 328i
sorry, i'm new to bmws.
      11-28-2012, 06:19 PM   #671
Elk
Drives: 2012 335i
Not a problem. Many other cars have had this feature for years. They just use different names for it.
      11-28-2012, 08:07 PM   #672
F30SD
Drives: Waiting on 335i MG Sportline
Speed warning. Setup under idrive and it lets you know with a beep and indicator light if you exceed the set speed. I set it at 90mph and thought I would never get there(limit is 65mph). Hit it twice on the commute to work this morning without meaning to. The 335 is an amazing car!
      11-28-2012, 08:11 PM   #673
ocso1606
ocso1606's Avatar
Drives: 2013 335i M
2007 BMW 525xi  [0.00]
2010 Volvo  [0.00]
2013 BMW 335i M-Sport  [0.00]
Mines set at 155. Lol great car!
M5 with lots of goodies
      11-29-2012, 09:59 AM   #674
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
My speed warning is set at 85, though by the time I hear the warning and let go of the pedal, I would have often crossed 88-90.
      11-29-2012, 10:04 AM   #675
rallybull
rallybull's Avatar
I noticed that the HUD speed display has a lag. Try this: accelerate hard, keep noticing the speed on HUD. Then leave the pedal. For just a short moment after you have left the pedal the speed on the HUD will still go up( sometimes as much as 6-8mph).
So I have learnt to keep this in my mind while accelerating hard and when I would like to not exceed a particular speed.
      11-29-2012, 10:34 AM   #676
rallybull
rallybull's Avatar
This is almost what I do to "comfort" access my trunk:
1. Stand one foot away from the trunk.
2. You should not be dead center, instead Make sure your right foot is dead center, which means you are about 12" or so to the left from the center.
3. Stand in a military attention position for 2 seconds. Take a deep breath.
4. Start moving your right foot forward at about 2.5 mph till at least 80% of you foot is vertically invisible hidden by the trunk as seen from top. Since you will be standing about a foot behind the car, take precautions to avoid parallax errors in you judgement for determining the 80%.
5. Retract your foot bringing you back to attention position "as soon as" your foot covered the 80% mark in step 4. Retraction velocity should be 2.5 mph.
6. Wait for about a second and you should notice the tail lights blink and the trunk opens. Congratulations!! If not, repeat steps 1-6 or try variation 1.
Variation 1: In case you are with friends or if people are watching you and you want to save yourself embarrassment in case of failure try this variation to the above steps:
1. In step 3 above instead of standing in attention, stand with your left hand inside your left pant pocket, holding your BMW key, finger on the trunk open button.
2. Continue with steps 4-6.
3. If step 6 fails, long press the trunk open button without causing apparent external movement of your hand inside your pocket.
4. The trunk will open.
Variation to variation 1:
In case you got your car reprogrammed for ASS last user mode, you could perhaps also use the panic button instead of the trunk open button on your key fob
      11-29-2012, 07:12 PM   #677
Elk
Drives: 2012 335i
Just like the dial gauge speedometer and tach.
This is typical and the result of the damping built into the gauges. It is amusing this characteristic of physical analog gauges has been transferred to digital.
      12-01-2012, 02:06 PM   #678
jsedlak
jsedlak's Avatar
Pretty sure the doors in the front have slots for wine bottles, 1 per side. Haven't tested, but the size looks correct.
      12-01-2012, 02:32 PM   #679
G16grancoupe
G16grancoupe's Avatar
Drives: 2019 f90
Or champagne
      12-01-2012, 05:55 PM   #680
arnsbrae
arnsbrae's Avatar
Drives: BMW 520d
That probably sums up the differences between California and New Jersey...
August 2012 F10 520d SE sport automatic, Jet Black, Oyster\Black Leather, light ash wood trim, Professional media/ navigation, mobile apps, Internet, DAB radio.
      12-03-2012, 02:53 PM   #681
Monaco
Drives: 2013 Jaguar XF Portfolio Sport
Does anyone know if there is a way to display a volume meter when turning up/down the volume knob? For example, on every car I've ever owned, there has been some way to tell just how close I am coming to maximum volume when cranking my stereo. I have found no such indicator in my F30 328i. I have the HK stereo and would sure like to know how much further I can take the volume before hitting its limit.
      12-03-2012, 02:58 PM   #682
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
Unfortunately there is no manner to display relative volumes in BMWs. One of my pet peeves.
