03-16-2016, 10:52 AM | #23 |
Rep 1,065
Drives: 2012 F30, 2013 E70
Extremely interested but I have a 2012 328i RWD so I'm out of factory warranty this year.
How would the DINAN warranty work in my case?
2012 F30 | IBM | SB | M-Sport Conversion | OEM 437M Wheels | MPE ++
2013 E70 | SBM | NB | Coming soon |
03-16-2016, 05:29 PM | #24 | |||
Rep 3,128
You don't have to get the Dinan tune and just run the turbo if you like but you would not garner any power from the setup. If anything you would just introduce lag into the setup as the torque curve is just moved to the right due to the longer time the turbo will take to spin up. You could get it and run a different tune if you like as well but the warranty wouldn't apply outside of Dinan spec either. |
03-16-2016, 05:33 PM | #25 | |
Rep 3,128
One way or another you have 2 years of warranty--- whether that all be the limited 2 year warranty or a mixture of both the limited warranty and the factory matching one is determined by when you purchase it. If you have new car warranty left we honor that up until it is no longer applicable to the car (4 years after or over 50k miles). |
03-16-2016, 09:46 PM | #27 | |
Rep 3,128
03-19-2016, 02:09 PM | #30 |
Rep 3,128
On the mechanical wastegate it is 6.5 PSI over stock. In general the electronic wastegate variants have been a tad more forgiving so I expect the electronic wastegate stage 4/big turbo combo to be slightly higher then that.
03-20-2016, 07:18 AM | #31 | |
Rep 186
How much better is this flow compared to the stock turbo? |
03-20-2016, 12:39 PM | #32 | ||
Rep 2,410
Drives: E30 M3 Cecotto, F85, G05, G07,
03-20-2016, 06:11 PM | #33 |
Rep 235
With the release of the new Dinan Big Turbos for the F3x N20 and N55 engines the stage 4 DINANTRONICS Performance Tuner is now becoming available for applicable models. This stage of tune is specifically designed to optimize the top end power that comes inherently with an upgraded turbo. While in stock, and lightly tuned, configurations the engine tends to fall off rather dramatically after 5000-5500 RPM with the big turbo installed the the cars continue to make additional power all the way to red-line. This results in maximum gains of up to 84 HP and 77 lb-ft of torque.
P/N: D440-1631-ST4 - DINANTRONICS Performance Tuner for the F30 328i (ONLY applicable to cars equipped with a mechanical wastegate) BMW Factory Ratings: 240 HP, 260 lb-ft torque (268 HP, 287 lb-ft Measured) With DINANTRONICS Tuner, Dinan Exhaust, Dual Intercooler and Big Turbo: 345 HP, 336 lb-ft torque Have you got a graph overlaying the power/torque curves for Dinan stage 1, 3 and 4. The stage 3 says only 15hp more than stage 1 but would like to see how much broader the power curve is at the top end for both stage 3 and stage 4 compared to the stage 1 tune I have. thanks |
03-20-2016, 10:36 PM | #34 |
Rep 2,577
6.5psi (or even higher) boost is possible with stock turbo at down low. But at Up top, no way just not enough flow no matter how hard it's working.
03-21-2016, 12:32 AM | #35 | ||
Rep 3,128
It did. Quote:
UPDATE: Last edited by Dinan_Engineering; 03-21-2016 at 07:46 AM.. |
03-21-2016, 07:35 AM | #36 | |
Rep 186
But what I was really hoping for was some graph overlays to show the delta. Else if purely based on power, these levels are close to higher tuned JB4s and stage 2 ECU tunes... Can I say that the failures we are seeing with the broken pistons due to detonation are due to fail safes being removed and pushing ign advance too much? And that running safer ign advance, while boosting higher at higher RPM would be safer? Honestly I do not know. Any pros care to share? |
04-04-2016, 06:01 PM | #38 | |
Rep 235
When will the stage 3 and stage 4 tunes be ready with the EWG ? Do your graphs for stage 3 and stage 4 include the benefit of a Dinan installed exhaust ? thanks |
04-05-2016, 08:10 AM | #39 | |
Rep 3,128
4 cylinder EWG stage 3 and 4 are in development --- was hoping it would have been done by now but other things have shoe horned their way in front of it as we have to take advantage of development vehicles when we can get them in. Unfortunately though don have a specific date or timetable to give. |
04-13-2016, 11:13 AM | #40 |
Rep 319
This is on my list of things to do to the car this year. Your results are with the Factory Cat. have you done a pull with the Cat removed and one with a high flow cat installed? If so would you share those numbers?
2024 X3 M40i. wife says no Mods since it's aLease.. I see a JB4 tune in the near future.
2014 328i Melbourne Red Sport Line Dinan Dinantronics tune, Dinan Exhaust, Dinan Suspension, H&R Sway bars, 18x9 APEX PS-7 ,AFE CAI, BMW M Performance Brakes Retired |
04-13-2016, 12:07 PM | #41 |
Rep 3,128
No tests without CAT's or with high flow CAT's. Given emissions its not something we would ever sell so we don't test for it. Needless to say it goes without saying that removing the single most restrictive element in a system will garner some decent gains, albeit with a CEL.
04-14-2016, 08:57 AM | #42 | |
Rep 319
2014 328i Melbourne Red Sport Line Dinan Dinantronics tune, Dinan Exhaust, Dinan Suspension, H&R Sway bars, 18x9 APEX PS-7 ,AFE CAI, BMW M Performance Brakes Retired Last edited by Burnt C6; 04-14-2016 at 09:06 AM.. |
04-14-2016, 12:08 PM | #43 | |
Rep 3,128
The modified fuel pump we offer does not increase the flow of fuel, it simply ensures that fuel is being adequately delivered at ALL times and the system isnt starved of fuel under extreme load conditions with low fuel reserves as the stock system has a tendency to do. |
04-20-2016, 08:40 AM | #44 | |
Rep 235
