02-04-2015, 12:05 PM | #309 | |
Rep 3,486
Another one you might want to code is to get the car to remember your last climate control settings. |
02-07-2015, 12:28 AM | #310 |
Rep 78
Hi Shawn,
Could you send a link to the software please. My car doesn't arrive until the start of next month but I've already bought a cable so I can turn the ASS memory on. Thanks. |
02-07-2015, 04:21 AM | #311 |
Rep 32,881
02-10-2015, 06:54 AM | #312 |
Rep 1,470
OK - I've finally got around to this....
I've made my own ESYS cable as per the instructions on here. When I connect my cable to the OBD port, I never get an IP address from the car. I presume this should just work and there's no need for any particular drivers to be installed on the laptop (eg should just see the ESYS cable as a network cable?). |
02-10-2015, 07:04 AM | #313 | |
Rep 40,668
02-10-2015, 07:57 AM | #316 |
Rep 40,668
Buy ENET Cable.
02-10-2015, 07:59 AM | #317 |
Rep 8,081
You won't get an IP address from the car as the car has no DHCP server. You will get a random address on the reserved private address range: something beginning 169.254.x.x.
It can take up to a minute for your laptop to drop its normal IP address and use this address. You need to make sure WiFi is off if you're in range of your normal WiFi, otherwise your laptop will just connect to it. You need to make sure the wired network adapter is enabled You need to make sure the wired network adapter is set to "Obtain an IP Address Automatically" You need to make sure Automatic Private IP Addressing (APIPA) is not switched off (you can run with WiFI on of course, but I'm making it simple...)
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
02-10-2015, 08:04 AM | #318 | |
Rep 40,668
02-10-2015, 08:12 AM | #319 |
Rep 8,081
I know. Which is why I put the last line of my comment!
Ian
02-10-2015, 08:16 AM | #320 |
Rep 1,470
Ah - so it's expected to get an APIPA address? The guide I was reading showed the ZGW_Search.exe returning a 10.x.x.x address...
I'll try it again now as I was expecting an assigned IP address... |
02-10-2015, 08:18 AM | #321 |
Rep 8,081
No it will get an APIPA address.
As Shaun correctly said, it is perfectly possible to have WiFi and wired simultaneously and on different address ranges but not knowing your IT knowledge it is sometime conceptually easier to have WiFi off so you exactly where you are!
Ian
02-10-2015, 08:18 AM | #322 | |
Rep 40,668
"*NOTE: The car does NOT have a DHCP server, so it does NOT assign an IP Address to the computer. Both the computer and the car will go into DHCP fallback mode, each assigning themselves a random Class-B IP Address so that they can talk to each other. This can take up to 60 seconds, so you have to wait until the PC has an IP address before you try to connect). Class-B IP Address range is from 128.0.0.0 to 191.255.255.255. Automatic Private IP Addressing (APIPA) is a network client-side process used as a fall-back position when DHCP services are not available on the network but the client devices are configured to use DHCP for their IP address configuration. APIPA allows the client device to randomly choose one of the 65,534 addresses available in the Class B network address of 169.254.0.0/16."
02-10-2015, 11:09 AM | #324 |
Rep 1,470
OK that worked.
I changed to 6NS but I can't see any difference in functionality? If I edit my iPhone device under Bluetooth, the only services it lists is Telephone? I closed Esys down, opened it back up and read from the car and it show 6NS so it appears to have been coded? |
02-10-2015, 11:51 AM | #325 | |
Rep 32,881
If so do you definitely have a combox under the boot floor? Did you definitely perform all of step 4 in the OP? |
02-10-2015, 12:17 PM | #328 |
Rep 1,470
02-10-2015, 12:20 PM | #329 |
Rep 1,894
Sorry just read the guide. It sounds like you have done the VO coding correctly. If you have an apple device try playing back music via the apple cable. If it plays then your EBT is working.
02-10-2015, 12:32 PM | #330 |
Rep 1,470
Really? I thought EBT added BT streaming? Afaik I've always been able to play his the lightening cable...
