BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > 340i 6MT Daily Driver: The Power and the Glory
Studio RSR
      05-22-2023, 09:36 AM   #1
Cytoplasm0671
Armchair Aristocrat
Cytoplasm0671's Avatar
312
Drives: 340i 6MT
2017 factory options
RWD, M Sport, Track Handling Package w/adaptive suspension, Mineral gray, Saddle brown interior, 6-speed manual transmission
Upgrades (updated and current)
Bootmod3 Stage 0+ OTS tune (no burble) in the winter. Stage 2 OTS in the summer.
550i clutch
513m rims with 245/40/18 square PS4S tires
Active Autowerke catted downpipe
Flexfuel sensor
Dinan springs
Dinan exhaust
B58TU high pressure fuel pump
VAC lower control arms
CDV delete
Pennzoil Platinum Euro 5w40 LL01 motor oil
Ross Racing PCV breather and oil catch can
Hawk 5.0 Street brake pads
Uniden R8 radar detector (wired)
Window tint (rear and roof)
ASD bypass harness
ECS Tuning teflon shifter bushing
Rogue Engineering transmission mounts
Clutch stop
7-series metal Start/Stop button
Black kidney grills
Jescar Ultra Lock sealant (2x)
Possible future upgrades
Eibach sway bars (to limit bodyroll)
LSD (if I can find it!)
Trade rears on M3/M4 forum for square front 513m rims
Remove visor warnings
Full spare in trunk
Correct speedometer coding (EU requires faster displayed speed than reality)
Turn off license plate bulb in reverse
G11 iDrive ceramic controller
Ultimate clutch pedal
Safety triangle
Keyhole cover
Here's a morning photoshoot today to begin the summer (2023)...
Appreciate 6
      05-22-2023, 09:48 AM   #2
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
Reserved
      05-22-2023, 11:10 AM   #3
Bootboot340
Drives: 2016 340i 6mt Stage 1
Nice! Very similar to my 2016 340i 6mt rwd and track and handling package. At Stage I tune now but doing dp and tu pump soon for Stage 2.
      05-22-2023, 02:18 PM   #4
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
Car looks great. I do like those 513s. I would recommend the ultimate clutch pedal and CDV delete mods.
      05-22-2023, 04:54 PM   #5
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
340i ideal platonic form. I am jealous of the xDrive at times in the winter. But not in the summer.
Thanks. Those mods are already on the list. I have an actual list that is almost 50 items long, just listed the big ones above. CDV delete will happen at the same time as the 550i clutch. Ultimate pedal maybe in a few years depending.
      05-22-2023, 05:08 PM   #6
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
all good mod choices so far
      05-22-2023, 06:52 PM   #7
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
I am unembarrassed to say that imitation is the highest form of flattery
toxik2454.50
      05-23-2023, 09:06 AM   #8
oem.plus_440gc
oem.plus_440gc's Avatar
353
Drives: 2019 440i XDrive GC
Car looks great man! Keep it up!
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
      05-26-2023, 03:12 PM   #9
Xover22
Xover22's Avatar
106
Drives: 2018 340i xdrive
So clean!!!
2018 340i xdrive mineral white build
2020 m340i mineral white - SOLD
      06-08-2023, 12:33 PM   #10
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
Clutch upgrade
550i clutch upgrade: complete ✅
18 hours of work later, and my 340i 6MT has a brand new clutch, the 550i clutch that can hold ~100hp more than the stock version. Knowing what I know now, I think I could do the job in less than half that much time, perhaps in a single day (less than 8 hours) if I got started early enough. But for this first time around, I took my time and tried to enjoy the process. This is only the second major car work I've ever done in my life after brakes and rotors last fall, so it was like jumping into the deep end of a pool and learning how to swim. But I just took it slow, and MAN what a blast this was.
First, HUGE thanks to kern417 and his video on replacing the clutch in his 440i, which is the same process for my 340i: https://youtube.com/watch?v=9cwJV5SKl40. I'm not sure I would have attempted this without the work he did to document the process. Second, I was very much assisted by the BMW TIS guide on how to replace the clutch. Those two guides alone got me 99% of the way. I just needed a few odds and ends otherwise, like how to use the clutch alignment tool and how to bleed the slave cylinder.
That said, there are some things that Kern417 did in his video that I think could be looked at. A minor but important one is to mark on the driveshaft with a white paint pen where it originally was connected. This way you reattach it back how it was and avoid the chance of vibration after the repair is over. The biggest difference between me and Kern is I feel that a transmission hoist is pretty much a requirement for this job. I know Kern bench-pressed the transmission into the car and then tightened the transmission bell housing bolts, but not only is that near impossible for most people strength-wise, it's also very dangerous considering you have a 100 lb transmission precariously balanced above your body with no real leverage for protecting yourself if it comes crashing down. For goodness sake, spend the $129 + tax at Harbor Freight like I did and get a mini transmission hoist so you can get that massive hunk of metal up and down without major risk of injury. The hoist can be reused for dropping and installing the exhaust as well.
Some reflections:
- It is amazing how much work is required to get this relatively small clutch disc into your car. It requires removing your underbody panels, entire exhaust, heat shields, disconnecting your driveshaft, and then finally you have access to the transmission bell. Once there, getting at the bolts for removal of the trans is quite challenging, especially if you're like me or Kern and you're doing this on jackstands with less than 20 inches of space under your car. But with enough patience and socket extensions, you can get the bolts out and wiggle the transmission off the engine block and onto your transmission hoist. Then you lower the trans to the ground and slide it out from under the car. Then remove the clutch pressure plate and clutch, and examine your flywheel. Depending on the flywheel, you may need to service or clean it, or remove it and have a new one installed, or remove it to have it resurfaced. Then refresh all the various hardware in the transmission bell. Then you just do everything in reverse... you slide the trans back under the car, get it back on the hoist, jack it up to your engine, and reassemble everything. It's a huge process. But wow, it was so enjoyable.
- My favorite moment was getting that transmission bell back onto the hoist while under the car with 20" of vertical space. I spent over an hour trying (and failing) on that. I couldn't figure it out and was a little scared I would have to call a tow truck and have it done by a real mechanic. But eventually I realized that I could slide the transmission up from between my legs onto my chest, then move the hoist between my legs, and then slide the transmission back down my body and onto the hoist. Victory!
- Halfway through the job, I realized why my car had been throwing drivetrain errors about not getting enough torque on the clutch. As I removed the clutch pressure plate and clutch, the car's flywheel was revealed. It was covered in a moderate amount of surface rust. Thankfully, the rust had not pitted the metal of the flywheel, so it could easily be removed. I spent about 2-3 hours patiently polishing the flywheel with plastic low-abrasion polishing bits to get that rust off (mostly failing). Finally I resorted to 2000 grit sandpaper. I know the flywheel needs to remain with an evenness of 0.004 inches across the surface, so I made sure to lightly sand with 2000 grain sandpaper to the point where I did not remove the machine grooves from the surface of the flywheel. In the end, I'm fairly happy with the result. 90% of the surface rust was removed from the flywheel and the machine grooves on the flywheel were still there, which means the flywheel was (probably?) still within that 0.004" flatness. I was on the verge of ordering a new flywheel at first ($1300), but in the end I kept it in there, and I'm glad I did. If the clutch still throws draintrain errors, then I'll get back in there and simply install a new flywheel. But for now I think my surface polishing did the trick. I'm still confused how the flywheel got rusty. I noticed water stains on the floor of the transmission bell, so I wonder if somehow the transmission go flooded by a previous owner.
- I am glad I pre-ordered replacement parts I might need for this job. For example, I had replacement bell housing bolts in case I rounded one off on removal (I didn't use them, so I will return them for a full refund). Most helpful to have on hand were the replacement clutch pivot pin (brass instead of plastic), new guide tube, new release bearing, new release fork, and new spring clip. The fork and bearing comes with the 550i clutch disc, but the guide tube, pivot pin, and spring clip I ordered separately.
- Aligning the clutch was a bit tricky as I'd never done that before, and Kern didn't show how to do that. But with enough Youtube videos of other people doing it, I figured out how the tool worked, and my clutch was aligned.
- I was excited to do my CDV delete and get more clutch performance, but upon getting into it I realized the CDV had been deleted by a previous owner. Learned something new about my car.
- Finally, Kern says in his video "Oh yeah make sure to bleed the slave cylinder", so I just assumed that bleeding the clutch would be easy to learn. Well, it was actually a bit tricky. In trying to bleed it I accidentally introduced a ton of air into my slave cylinder. I had to order a Motive power bleeder and wait 4 days for it to arrive. Then spend another few hours learning how to bleed my brakes and clutch. In the end, I was successful, and my car now has new brake and clutch fluid, which it needed anyways.
In the end, the clutch got replaced, the transmission got hoisted back up in to the car, and after all the stuff got bolted back on (after bleeding the slave cylinder) I was able to drive the car around. I checked ISTA and the car is throwing no errors. I'll do my 300 break-in miles to get the clutch fully seated, and then I look forward to seeing if this 550i clutch can hold the 450hp that BM3 stage 2+ can offer. The 550i clutch seems capable of 500whp so 450whp shouldn't be too much of a stretch.
All in all, I highly recommend people take a few days off and challenge themselves to replace their own clutch. This might sound a bit cheesy, but not only did my sweet 340i get a clutch upgrade, but I also grew as a person. After heaving around that heavy transmission bell, getting it all serviced with new parts, and getting it back into the car, I feel a ton more agency as a man, more power to exert my will upon the world.
Xover22106.00
kern4174449.50
Cpark1440.50
      06-08-2023, 12:40 PM   #11
toxik
toxik's Avatar
congrats on a tough DIY and getting it done!
were you always planning on keeping the OEM flywheel, or were you waiting to visually inspect it to see if it needs to be replaced?
      06-08-2023, 12:51 PM   #12
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
Thanks! While pre-ordering stuff like the guide tube etc was fairly cheap, the flywheel is very heavy and costs $1300, so I really didn't want to have to return it. I just took my chances, hoping it didn't need replacement. I feel confident keeping it in there, as the flywheel still had rotational "springy-ness", and my surface cleaning was 90% successful.
      06-08-2023, 12:54 PM   #13
toxik
toxik's Avatar
yeah i saw its a point of debate with 6MT guys, basically not wanting to spend the dual-mass flywheel money if it's not needed, but also not knowing if you need to replace or not until you're already in there.
      06-09-2023, 05:04 AM   #14
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
Some reflections:
Nice job and write up. The trans jack is a must have tool for this job!
      06-09-2023, 07:29 AM   #15
B58 parts
B58 parts's Avatar
Yeah I can't believe kern bench pressed that thing. I'm pretty strong but I wouldn't want to try that. I would get a second hand for the exhaust and the trans parts. I had a shop do mine, but next time (soon) going to get the HF jack and a buddy to help.
I hope you pulled the CDV out of the slave cylinder while you were there
      06-09-2023, 07:38 AM   #16
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
I tried but the CDV was already gone via a previous owner
      06-15-2023, 11:56 AM   #17
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
good work
Youtube/Instagram/TikTok: @kern417
      06-15-2023, 03:12 PM   #18
Cpark14
Cpark14's Avatar
Drives: BMW 340i xdrive 6MT
Whats the benefit of that?
      06-15-2023, 03:58 PM   #19
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
The CDV is the clutch delay valve, a small restrictor that BMW puts into the clutch line to help slow down the clutch accuation so that people are less hard on their clutch discs. But many people here remove the CDV because it really slows down the cars performance and makes the pedal less precise.
Cpark1440.50
      06-21-2023, 04:45 PM   #20
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
Filled up with 93 octane at a popular Shell station, as recommended by people here, in order to try for higher quality gas, and timing corrections were much improved:
https://www.bootmod3.net/log?id=6493...90c65999749c03
I have officially moved the car to a Stage 2+ 93 octane OTS tune. Looking forward to a Flex Fuel sensor being installed next month to run E30 and get the corrections even lower or gone completely.
Interestingly, my motivation to get a Flexfuel sensor is not to get higher wheel HP, as most, but to get these timing corrections improved or gone so as to improve the life of the engine whilst running a tune.
Soon moving over to 5W40 Pennzoil Platinum Euro and installing stiffer transmission bushings.
Edit: As a result of the conversation here, I have moved the car from Stage 2+ 93-octane to Stage 2 91-octane. While the Stage 2+ logs were keeping corrections under 6 degrees, which is not terrible, member Skyhigh recommended keeping them at 3 degrees or below, and Stage 2 91-octane is currently the only tune I can run that has that small of corrections. Hopefully I can move to Stage 2+ with corrections at 3 degrees or below via E30 and the flexfuel sensor.
      06-27-2023, 09:05 PM   #21
Cytoplasm0671
Armchair Aristocrat
312
Drives: 340i 6MT
ECS Tuning shifter bushing: ✅
Rogue Engineering transmission mounts: ✅
The goal was to reduce the rubbery vague manual shifting of my 340i. I'm not looking to make it a racecar where I feel every bump on the road, but something in between.
Probably took 2-3 hours all combined. I'm getting better at pulling off those underbody panels. The transmission mounts were relatively easy to install, with my Harbor Freight transmission hoist coming into play again to hold up the trans while I removed the brace, unscrewed the OEM mounts, and installed the stiffer ones from Rogue Engineering. The ECS Tuning teflon shifter bushing was a bit more work as I didn't want to disassemble the shifter linkage, so I replaced the bushings by reaching up from underneath the car. Was a pain, but I got a box cutter up in there and cut the rubber on one side enough where I could push the old bushings out and pop in new ones.
End result is fantastic! Shifts are now much more precise while still being comfortable. To be honest, this is one of my favorite upgrades thus far. For a manual transmission lover like myself I actually feel this upgrade is more enjoyable than more popular upgrades I've done like adding an Active Autowerke downpipe. Man oh man, the car just shifts like a dream. I will eventually get the Ultimate Clutch Pedal and then am thinking the clutch situation will be complete.
      06-28-2023, 08:14 AM   #22
toxik
toxik's Avatar
those rogue engineering mounts are for RWD only according to their site... weird I figured there would be no difference between Xdrive and RWD.
edit: just did 5 minutes of research and it seems all aftermarket options are for RWD mounts only
