01-27-2021, 07:57 AM | #177 |
Rep 51
Drives: BMW 530 xdrive
01-27-2021, 08:10 AM | #178 |
Rep 525
-Kafas BE Front Collision Warning
-Kafas BF Pedestrian Detection
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
01-27-2021, 10:09 AM | #179 | |
Rep 40,774
01-27-2021, 11:52 AM | #180 |
Rep 51
I coded with e-sys, "DKOMBI => HUD_TLC_ENABLE = aktiv" , but it doesn't change anything, I don't have anything displayed in the hud ....
01-27-2021, 12:06 PM | #181 |
Rep 40,774
Then it is not supported in your car.
01-30-2021, 10:40 AM | #182 |
Rep 51
thank you for the answer and the help provided
I'm just waiting for my new steering wheel, and I'll post for the result |
10-28-2021, 10:12 PM | #183 |
Rep 7
Hi all,
My car originally fitted with Driver assistant Plus (Front Collision Warning, Pedestrian Detection & Lane departure warning). However after changing my steering wheel to M Sport (which does not comes with a module and vibrator in the steering), my lane departure warning was deactivated and each time I start my car it will displayed a warning on the deactivation. I have tried to recycle the harness & module (black box) from my previous steering wheel and it able to eliminate the warning sign when starting my car, but this causes the horn to stop working because of the harness So my question is, can I code via esys to make the warning message and fault to disappear while I am using the harness that comes with the M Sport steering wheel (which horn are working)? Appreciate if anyone can advise the solution and have attempt to resolve the similar issue. Thank you! |
10-29-2021, 12:31 AM | #184 | |
Rep 421
Drives: 2017 F31 328dx
Module - 61-31-7-849-393 - Check your module number as you may already have this in the wheel already. If the wheel has paddles you should be all set with the harness in there as it differs on having sport auto transmission or not. Front Trim Pad - 32-30-7-850-622 |
10-29-2021, 01:31 AM | #185 |
Rep 525
I will see first if you have heating steering wheel. If not then buy this 61317849392 module or you will have error in ista and you will not be able to turn this off.And you will need new wiring set 32307848337
10-31-2021, 04:32 PM | #186 |
Rep 5
kombi
DISP_LDM_2_ALIVE: aktiv [01] DISP_LDM_2_APPL: aktiv [01] DISP_LDM_2_CRC: aktiv [01] DISP_LDM_2_TIMEOUT: aktiv [01] IBRAKE_VERBAUT: aktiv [01] ST_TLC_ALIVE: aktiv [01] ST_TLC_APPL: aktiv [01] ST_TLC_TIMEOUT: aktiv [01] TLC_VERBAUT: aktiv [01] /////////////////////////////////////////////// FRM LIN_PUBU_TLC: aktiv /////////////////////////////////////////////// ICM C_KOV_TLC_verbaut: verbaut [01] C_Sperrtrigger_dynamisch_CTR_VIB_STW: aus [00] C_Sperrtrigger_dynamisch_ST_COOR_VIB_STW: aus [00] Verbau5AS_DriveAssist: verbaut [01] //////////////////////////////////////////////////7 NBT BRAKE_ASSISTANT_FCW: aktiv [01] LANE_DEPARTURE_WARNING: aktiv [01] /////////////////////////////////////////////////// |
11-05-2021, 03:53 AM | #187 | |
Rep 7
Out of all the value only 3 codes is different: FRM LIN_PUBU_TLC: aktiv /////////////////////////////////////////// ICM Verbau5AS_DriveAssist: verbaut [01] /////////////////////////////////////////// NBT BRAKE_ASSISTANT_FCW: aktiv [01] Rest of the codes has been set to "AKTIV" and "aus" as default. Will update if these 3 code works to switch off the LDW warning in the absence of the module Thank you. |
11-09-2023, 08:51 AM | #188 |
Rep 10
Is it possible to buy FSC BF and BE somewhere for around 60 euros? I bought from this site
https://www.baum-bmwshop24.de/bmw-fs...2444948-73729/ 7e, but I can't find BF and BE. Or can someone advise what the number is for BF and BE? for 7E it is 66502444948. I can't find another FSC because I don't know the product number. Or can someone sell for about 60 euros? |
yuwhehe3.50 |
11-12-2023, 01:34 PM | #189 | |
Rep 2,047
01-05-2024, 05:24 AM | #190 |
Rep 33
Hi!
Can I code LDW to stay always on, while i'll get buttons for it? O is it possible to code LDW without 5AD VO, but only using FDL?
Retrofits: 248, 2TB, 302, 3AG, 5AC, 5AS
01-12-2024, 12:08 AM | #192 |
Rep 33
Yesterday I've done 5AS retrofit, but steering doesn't vibrate when crossing detected lanes without turn indicator. Any ideas? Faulty vibro motor? Or I've made mistake by coding both 5AD and 5AS?
01-12-2024, 01:47 AM | #193 |
Rep 525
Just one of this can be code so 5AS or 5AD not both
01-12-2024, 04:10 AM | #194 |
Rep 33
Thank you! 5AD is for pre lci... Can you tell which ecus should be coded? I did on dsc, icm, fem, hu, kafas2, kombi.
01-12-2024, 11:34 AM | #195 |
Rep 525
Read with ista and write error here. This coding should be enogh
