BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding error. CAFD not found
proTUNING Freaks
      11-18-2022, 12:35 PM   #309
shawnsheridan
shawnsheridan's Avatar
Originally Posted by jfilipe View Post
Hi guys, I'm new to coding and using e-sys and I'm trying to learn! But I need help, can someone explain to me what's going on? When I try to encode FEM_BODY I always get this error:
Thanks!
cafd_ffffffff-255_255_255 means you corrupted CAFD. You need to inject CAFD and VO Code ECU to fix it.
And stop doing what you are doing to corrupt it...
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-18-2022, 12:48 PM   #310
jfilipe
Portugal
Drives: BMW 335d, MINI Cooper S
I really don't know how this happened, I just followed a tutorial video on how to leave the start/stop button in the last position. When I finished, a message appeared saying that something had failed. I don't know what went wrong and I really wanted to find out.
Regarding the corrupted cafd, how can I install it again?
Before making any changes, can I create a "backup" of the existing files?
      11-18-2022, 01:07 PM   #311
shawnsheridan
No Backup needed.
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
      11-20-2022, 07:34 PM   #312
jfilipe
Portugal
Thanks!
Thank you, I'll try to do this and then let you know.
As for the corrupting the file, I don't know why it happened. :
      09-13-2023, 03:30 PM   #313
TwinV8
Drives: Bmw X5
Hi,
Ive previously coded my G31 video in motion all was working all good until an update over the air from BMW was installed the VIM has stop working,tried to re codes the VIM but I get the CAFD file is missing also help needed thanks.
      09-13-2023, 03:56 PM   #314
shawnsheridan
Originally Posted by TwinV8 View Post
Hi,
Update your psdzdata. PM sent.
      09-14-2023, 01:52 PM   #315
TwinV8
Drives: Bmw X5
Many thanks Shawn for the reply, the initial issue has worked but the problem Im having is the missing function description does not work to allow editing.
      09-14-2023, 01:57 PM   #316
shawnsheridan
Need BimmerUtility for FDL Editing.
      09-14-2023, 02:01 PM   #317
TwinV8
Drives: Bmw X5
FYI Im using Launcher PRO V
      09-14-2023, 02:02 PM   #318
shawnsheridan
Which has old outdated CAFD mapping.
      09-14-2023, 02:12 PM   #319
TwinV8
Drives: Bmw X5
Thanks again Shawn didnt know that the launcher was outdated surprisingly.
      09-14-2023, 02:25 PM   #320
shawnsheridan
v.5 uses same CAFD Mapping Database as v.3.7, which is from Dec 2019.
      09-14-2023, 03:13 PM   #321
TwinV8
Drives: Bmw X5
Ive just tried using FDL editor on Launcher Pro V offline loading up the Cafd file saved earlier when connected to car and the missing descriptions all show up and the options to edit was availbe too,if this is possible can I save it in the modified state and code back to car?
      09-14-2023, 03:18 PM   #322
shawnsheridan
Yes. You can edit .ncd offline, connect to car and write save .ncd to it.
      09-14-2023, 03:32 PM   #323
TwinV8
Drives: Bmw X5
One thing bothers me why did the NCD file when connected to car didnt show up the descriptions since it was the same file I saved earlier when trying to code the VIM and I was able to view the descriptions offline,maybe I made an error somewhere possibly?
      09-14-2023, 03:33 PM   #324
shawnsheridan
No idea. Defies logic.
      09-15-2023, 01:30 AM   #325
TwinV8
Drives: Bmw X5
Appreciate your help and advise
      09-27-2023, 12:07 PM   #326
PepyXXL
Drives: BMW F31
I have a problem on my f31 , i am trying to code apple carplay on it and it says this error :
CAFD_00001EF6_006_057_003 Fehler: File for "cafd_00001ef6-006_057_003" not found! [C012]
      09-27-2023, 12:10 PM   #327
shawnsheridan
      03-20-2024, 02:22 PM   #328
E30MT325i
Drives: BMW E46 M3 / BMW E30 325i
Use latest v.4.37.42_PSdZData_Lite. Your Receive PM function is disabled. PM me when working.
Hi Shawnsheridan, I would also like to receive the latest PSdZData files as I am missing the cafd_00001ef6-006_055_013 file. However, I just signed up this forum, so not sure if my DM function works already. If not, I'll try it a week later. Thanks in advance.
      03-20-2024, 05:04 PM   #329
shawnsheridan
PM sent.
      Today, 07:10 AM   #330
zipius
Drives: bmw f31
cafd files missing
hi bimmers,
i'm getting the same error of most people C012 when trying to code ecu's of my F31 320d 2015. it appears cafd files are missing or outdated.
aliexpress softwares....it cames with the cable. https://f30.bimmerpost.com/forums/im...ilies/iono.gif
i'm able to change FA, write FP but cant code modules...
can i get some help?
best regards
