BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 OEM Alarm Retrofit (320i/328i)
      08-01-2023, 05:05 AM   #265
labanauskas
Lithuania
Drives: F30 LCI 318d
Originally Posted by zingaling18 View Post
so for those that don’t have sunroof, what’s the part number for the roof consule?
61 31 6 826 921 - without sunroof, with sos
      08-02-2023, 04:34 PM   #266
antoniof20
Drives: f20
There are other place to install siren?
      08-05-2023, 07:22 PM   #267
wenlubin
Drives: 2019 BMW X3; 2015 BMW 328i
Anyone has a clear video or link on how to remove the C-pillar? Can’t seem to find a good one.
I’m interested in running the signal wire from the trunk to the roof module and think it would be best running it through the C pillar directly into to roof liner but please let me know if from your experience you would recommend another route.
EDIT:
Nvm…. Figured it out and finlized the retrofit. Big thanks to OP and everyone else with their inputs!
      08-30-2023, 08:10 PM   #268
Popo
Bobafett
Popo's Avatar
Drives: 2014 BMW 328 Msport Xdrive
None of the CAFD file options are close to my Istep. I’ve tried a couple, and I get errors when trying to code the REM and FEM modules. No audible chirp on locking, or unlocking the door. Alarm only sounds the horn. I’ve tried getting power to the siren by using an add a tap to a constant fuse (number 161) to eliminate the problem of no power from the fuse added in the OP. I get the quick blinking red light when first arming the system. Any ideas?
      08-30-2023, 09:07 PM   #269
david51
david51's Avatar
France
538
Drives: bmw M3 F80
To make the alarm sound towards the siren instead of the horn, try this line
FEM/3100/HORN_BUS/aktiv
or
HU NBT/3001/DWA/aktiv
divers option
Authentication when arming/disarming
FZD 07/3002/Authentifizierung/aktiv
Activate/deactivate interior protection function
FZD 07/3002/Innenraumschutz/aktiv
Activate/deactivate tilt sensor function
FZD 07/3002/Neigungssensor/aktiv
Activate/deactivate horn emergency running function
FZD 07/3002/Notlauf FZG-Hupe/aktiv
Visual alarm output indicators
FZD 07/3002/Optische Alarmausgabe Blinker/aktiv
With visual alarm output “low beam”
FZD 07/3002/Optische Alarmausgabe Abblendlicht/aktiv
Optical alarm output high beam
FZD 07/3002/Optische Alarmausgabe Fernlicht/aktiv
Visual confirmation when disarming
FZD 07/3002/Optische Quittierung Entschaerfen/aktiv
Acoustic confirmation when disarming
FZD 07/3002/Akustische Quittierung Entschaerfen/aktiv
Alarm type
FZD 07/3001/Alarm type/ece or us or gb
      08-31-2023, 11:48 AM   #270
Popo
Bobafett
Popo's Avatar
or
divers option
Alarm type
Did all this. No change.
      09-02-2023, 05:21 AM   #271
labanauskas
Lithuania
If the car hasn't got sunroof, do I need to run can and power wires ? ( car has sos, atm, extended lights package)
      09-03-2023, 09:46 AM   #272
labanauskas
Lithuania
Just removed fzd and 14,15 pins are empty...
      09-03-2023, 10:48 AM   #273
Siki78
Siki78's Avatar
136
Drives: F30,G30
You will need just can wires power is not necesery because you have already power and ground
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      09-04-2023, 12:59 AM   #274
labanauskas
Lithuania
Do I need new wires directly from FEM?
Edit: I think I found fem pins are 49 - CAN-L, 50 - CAN-H.
      09-04-2023, 01:41 AM   #275
Siki78
Siki78's Avatar
136
Drives: F30,G30
Yes A173*8B pin 49,50 If not exist new one or just tap it to the exist one
      09-05-2023, 01:12 PM   #276
Popo
Bobafett
Popo's Avatar
Update: It was a sh|t siren. Had checked all my wiring and it looked good. Ordered another alarm just to check. Plugged in the new siren and it works like a charm!!!
      09-05-2023, 02:46 PM   #277
labanauskas
Lithuania
Ok thanks. Pins were occupied, so I've tapped to exiting ones.
FA 302 and FZD became visible. Only now I have to add siren and add another two wires from siren to fzd and from fzd to mirror...
      01-30-2024, 05:26 PM   #278
Freakstar50
Freakstar50's Avatar
Netherlands
64
Drives: BMW 335d xDrive
Sorry for reawake a old thread, but i have a EU car wich does not come with a rear view mirror with the red LED in it, but what do i need to watch for to replace it, does it have any camares in it for addaptive headlight or speed sign recognition or anything?
Thanks for the help, wanna add the alarm to my car...
