BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 OEM Alarm Retrofit (320i/328i)
      05-06-2018, 04:17 AM   #89
sevenofnine
sevenofnine's Avatar
Sweden
Drives: M235i
Two more things you can check. If you arm the car with the trunk open and then pull the fuse to the siren the alarm should start. Also you can try to jack up the car when the alarm is armed then the tilt sensor in the siren should set of the alarm also.
Also what fuse location did you use for the siren? I had to hunt around for a fuse with constant 12v even when the car goes in deep sleep. The first one I tried only had power for 5 minutes after arming and the alarm would fire after 5 minutes
      05-06-2018, 10:46 PM   #90
Gen2mike
Drives: 2013 328i xDrive, 2018 X3 M40i
where has everybody been sourcing the roof module? I seem to be having diffuculty finding one. Ive got sunroof and sos. I've searched far and wide other than buying a new one.
      05-06-2018, 10:57 PM   #91
sea_m2c
sea_m2c's Avatar
82
Drives: 2019 M2C - 6MT
Originally Posted by sevenofnine View Post
Just made the connection to the siren in the trunk and the siren is working. I have not coded the car yet but the alarm is working as it should. Before I connected the siren the led in the rear view mirror would blink fast when I armed the car for a couple of seconds and then it would start blinking normaly. Now when the siren is connected the led blinks normaly directly after arming. So if your led is blinking fast for a couple of seconds right after arming that could mean that there is no connection to the siren.
Good to know! My led does blink fast initially. There must be an issue with the wires or siren. I think I'm going to take another shot at the wires over the next few days and then I might order a new siren.
As far as the mount I made, I drilled a hole above where the wiring loom enters the car and ran a bolt through there. It sounds like you figured something out though.
      05-06-2018, 11:02 PM   #92
sea_m2c
sea_m2c's Avatar
82
Did you use the F103 fuse in the DIY? That's the fuse I've used for power.
I'll try pulling the fuse power like you suggested and see what happens. I was riding a ferry this weekend and locked my car. When I came out the led was flashing rapidly as if the alarm was going off but no sound so I suspect the tilt sensor is doing something.
      05-08-2018, 05:49 AM   #93
sevenofnine
Sweden
Drives: M235i
No I used a different fuse beacuse I have yet to recieve the contact for the fuse box from bmw so I just used a spade connector from the top of the fuse box. And I only had the larger spade connector that fits where the large fuses go.
So I am using fuse location 112 at the moment. Hopefully I will get my contact from bmw soon so I can mount it the correct way.
      05-10-2018, 11:15 AM   #94
sea_m2c
sea_m2c's Avatar
82
Alarm fully functional, happy to report.
The fuse block for F103 was actually not getting power. I invested in a multimeter and pinned that down as the issue.
I had the same issue finding a constant 12v source that didn't set the alarm off after the car went to sleep
      05-10-2018, 04:39 PM   #95
sevenofnine
Sweden
Drives: M235i
Great to hear.
      05-15-2018, 09:43 PM   #96
Gabrielisimous
Gabrielisimous's Avatar
Drives: F30 328i 2013, E46 325i 2005
Coding alarm retrofit
Hi guys, I'm about to get my roof module and the siren bracket, does anyone knows if there is a how to code for dummies (step by step) since I only have FDL coding but never VO??
      05-18-2018, 01:31 PM   #97
Jhnblckwood
Drives: F30 2014 320i xdrive
Instead of hitting code fdl u hit code with the actual module selected not the cafd below. That is VO coding.
      05-19-2018, 01:51 PM   #98
Gabrielisimous
Thank you!
Gabo
      05-19-2018, 02:21 PM   #99
Jhnblckwood
Goodluck.
      05-28-2018, 09:16 AM   #100
the_mpd
Drives: 2015 F30 328i
Coding / No FZD...?
I got all the connections made and am having some problems with the coding portion of the project. I added VO code 302 successfully to the FA. When I activate the FA in the Coding screen, there is no FZD module listed. I proceeded anyway and re-coded all the modules in the car and the "Acoustic signal on lock/unlock" option appears in iDrive but it won't let me check the box to select it - I highlight it and push the button to select it and the box won't check.
I'm fairly certain the issue lies with there being no FZD module visible but I can't for the life of me figure out how to get it there. My car does NOT have a sunroof, which may or may not be contributing to the issue.
Can anyone help me with this? I feel like I'm SO close and there is just some detail I'm missing that I'm too stupid to figure out for myself .
      05-28-2018, 09:59 AM   #101
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
we must add the + of the food (positive) and the negative as the following schema if you do not have it
      05-28-2018, 10:33 AM   #102
the_mpd
Originally Posted by david51 View Post
Hello
Thanks for the reply. So basically you're saying that I need to get power and ground to a few extra terminals in the roof console. I'm not sure I understand - I'm not seeing the FZD module in e-sys after I add option 302, even before I do anything with the car and I don't think that's going to change no matter what setup the wiring in the car has, no?
I'm definitely not going to be running wires from the engine compartment through the firewall. If the solution isn't something simpler I'll probably just book this as a "fail" and move on.
      05-28-2018, 11:43 AM   #103
david51
david51's Avatar
France
538
Drives: bmw M3 F80
hello I had the same problem when adding the alarm. you can connect the power supply (positive) with the existing one to test
you have no choice otherwise it will not work
      05-28-2018, 03:31 PM   #104
Gabrielisimous
OMG!
Hello
OMG! if exist an explanation with pears and apples for this I mean something that normal people can understand it would be really appreciated, I'm in the same boat with the_mpd
      05-28-2018, 05:41 PM   #105
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
we must add 2 son as in the picture
reference connector
61138364834
quick coupling
61138364566
      05-28-2018, 06:03 PM   #106
david51
david51's Avatar
France
538
Drives: bmw M3 F80
if you do not have a power supply, it will be necessary to add one to the fuse box engine compartment F62 (fuse 30A)
      05-28-2018, 06:12 PM   #107
Gabrielisimous
OMG!
that looks clear... so in the case we need for power we just need to run a wire from fuse F62 and another for ground in the pins you marked on the 16 pin connector right?
      05-28-2018, 06:26 PM   #108
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Yes exactly
      05-28-2018, 06:31 PM   #109
Gabrielisimous
Yes exactly
Ok I still waiting for my module (without sun roof) if needed I would do this and post an update, thank you David in advance!
      05-28-2018, 06:33 PM   #110
david51
david51's Avatar
France
538
Drives: bmw M3 F80
ok
