BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6WB coding tread
      09-23-2018, 07:14 AM   #89
dincic
Drives: Bmw f80
Now bkombi disappeared from svt but dkombi still not appear
      09-23-2018, 07:16 AM   #90
dincic
Drives: Bmw f80
Works !)))
      09-23-2018, 07:19 AM   #91
atzebmw
Drives: Tesla Model 3
Great
      09-23-2018, 07:26 AM   #92
dincic
Drives: Bmw f80
But now have another problem. Cluster show 00000 km !(
      09-23-2018, 07:27 AM   #93
dincic
Drives: Bmw f80
Any ideas ?
      09-23-2018, 07:31 AM   #94
dincic
Drives: Bmw f80
I modify svt
(Delete bkombi) and write it to car again
Then code nbt with zeit 03.17 and dkombi appears. But now it didnt see car km
      09-23-2018, 08:45 AM   #95
dincic
Drives: Bmw f80
Can it be codding problem or EEPROM ?
      09-23-2018, 09:08 AM   #96
dincic
Drives: Bmw f80
Most interesting is the fact that the kombi is new
      09-23-2018, 10:10 AM   #97
dincic
Drives: Bmw f80
By the way. I tried to solve problem with Tow and without succes:
3ac is still in fa and all values are aktiv ((
      09-23-2018, 10:21 AM   #98
dincic
Drives: Bmw f80
Which modules to code after retrofit dkombi ?
Dkombi and nbt right ?
      09-23-2018, 11:44 AM   #99
dincic
Drives: Bmw f80
Maybe need fem to if on car was installed bkombi from factory ?
      09-23-2018, 12:26 PM   #100
atzebmw
No, the FEM does not have to be coded.
But it's not bad to do it anyway.
Is the MOST connected correctly?
I think from the MOST the DKombi gets the km.
Can you read out the error memory?
      09-23-2018, 01:37 PM   #101
dincic
Drives: Bmw f80
Will look tomorrow. How about tow ?
      09-23-2018, 09:19 PM   #102
M2Andy
Drives: G01
I have had 6wb retrofitted into an F25, mostly ok except 2 small issues.
Range showing 700 miles when should be more like 500 miles dependant on driving style and also, fuel gauge is being slightly over optimistic.
Old cluster set at 65lt, new one set at 66lt in TNK_VOLL_ANZEIGE (official stats show capacity of 68lt) so if anything, it should be pessimistic with the range and gauge?
Any ideas please?
      09-24-2018, 12:28 AM   #103
dincic
Drives: Bmw f80
Red dot is presented ?
      09-24-2018, 03:20 PM   #104
dincic
Drives: Bmw f80
By the way. Tow is retrofited too as i was informed today. Both are connected to FEM so maybe problem goes from FEM ??
      09-25-2018, 07:43 AM   #105
Patryk90
Drives: f36 / f15
Hello Guys,
Could you please let me know how i can add by esys at 6wb Navigation system directions ?
like on this pict. and also wornings about speed ?
Thank you
      09-25-2018, 11:55 AM   #106
dincic
Drives: Bmw f80
Fdl code nbt resolve
      09-25-2018, 11:57 AM   #107
dincic
Drives: Bmw f80
Kombi_cic = kombi high
      09-25-2018, 12:00 PM   #108
dincic
Drives: Bmw f80
Kombi navi nbt anable
      11-16-2018, 06:36 AM   #109
pcornejo
Drives: F36 420i
Originally Posted by chp10 View Post
Did someone found a solution for the HUD issue? Mine is still not working. Sometimes it is starting up but after a couple of seconds it turns off again.
Another problem with the 6WB is that the navi advise does not disappear. It stays until the next advise. Have anyone the same behavior?
THX
Hi chp10, i have the same issue in my 6wb, the navi indication stays until next advise, did you find a solution?
thanks
      12-13-2018, 05:46 AM   #110
KDKE30
Drives: F15 M50D
Originally Posted by jkwhar View Post
Changing "Motorleistung Enable" to aktiv didn't enable the hp/tq on the cluster.
I did find 3000->BMW logo -> default:BMW, changed to MPM. Waiting 10 mins for the car to sleep to test this out.
EDIT: changing the bmw logo to MPM shows "m550i(or m550d, cant remember". Other options are bmw_i, bmw_x5, bmw_x6, unk_param_0, unk_param_1, unk_param_2, and unk_param_3.
Is there a way to increase the splash screen time?
Hey, do you find a way to increase the splash screen time?
