BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding Speed Limit Info
      01-18-2019, 05:35 PM   #45
x5mad
x5mad's Avatar
Drives: iX 40
bmw  [0.00]
Originally Posted by daMANiack View Post
Hi,
Yes, greatly depends on the build date of your car and country it was made for.
My 2016 F26 X4 35d for Australia was obviously flashed with firmware for the Kafas2 ECU before BMW had resolved SLI detection from our numerous speed signs so they didn't include it by default.
I had to add 8TH to the cars FA, then update the Kafas2 firmware to a later version, I used v.4.14.14_PSdZData_Full.
I then had to code the HU_NBT2, Kombi and ECU to inject SLI parameters.
Then inject the FSC SLI files using E-Sys.
I'm a novice and most things I do regarding coding is new so I don't remember details all that well, I have to research before I do something.
Cheerz
Originally Posted by x5mad View Post
I am really keen to have SLI but am lazy and don't want to redo all of my coding for the ECUs which will be flashed.
Does anyone know the individual coding involved to get SLI working?
My wife's X3 has SLI and it is so handy, really want it on my 340i but don't want to recode all of my individual settings.
Sorry I should have been more clear.
What I meant was I wanted to avoid VO coding if possible. I have numerous FDL codings which would be affected. Not least CarPlay (I bought elsewhere not from Bmw) and video in motion etc etc.
I was looking for the FDL coding for SLI.
I'm sure my KAFAS2 is up to date, I had new iSTEP done by Bmw in 2018, would be at least the March 2018 iSTEP.
      01-22-2019, 11:39 PM   #46
1rb1ss
Drives: 428xi
Originally Posted by greb View Post
Yes, so if anyone needs any FSC codes please let me know!
Hi Greb,
Can you please advise, if i already have working SLI feature but for USA Road Signs - can I change it to EU road signs without additional FSC ?
      01-27-2019, 11:12 AM   #47
DMM2
DMM2's Avatar
Drives: '17 M2 *sold*, '18 330i F31
SLI FSC
I was able to get an FSC code from Greb in less than 24 hours - so a big thanks to him! Also, thanks to baturbo for the instructions, and all those who have posted on the subject. Like Sean750, my notification at the end of the process in E-Sys was:
AppID 126
UpgradeIndex 1
SWTType SWTclassic light
FSCStatus accepted
FSCCertStatus not available
And, as others have reported, this doesn't seem to have any impact on how the SLI functions.
One thing to note (for those who, like me, are E-Sys rookies), when using these instructions: http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf, note that after 'Step 2', in the table of contents on the left, select 'Editors and Viewers' and press the 'FA-Editor' button. This step is necessary to bring up the 'SALAPA-List'.
Happy coding!
Originally Posted by tigger_643 View Post
I also got the same result with the SWTType SWTclassic and FSCCertStatus values. And similar to you, it works fine. Thanks again greb for your help with getting the FSC code.
greb67.00
      02-02-2019, 12:29 AM   #48
mikofung9638
Australia
Drives: 2015 BMW F23 228i
Well guys, lucky me today. Finally one of the dealers ordered the fsc code and sent it to me by e-mail. Just €40,-...
I directly coded it with E-Sys and it works!
Hi Greb,
My name is Fung. I m new to coding. I have been researching how to code the speed limit info on My F23 228. My car equipped hight beam assist and haedlight cornering, so i belive that i have already got all the required hardwire on board, all i need is to enable the software part. Would u be able to give me some instructions on what need to be coded ? since u have got it worked on your . I appreciate for that
      02-02-2019, 11:03 PM   #49
mikofung9638
Australia
HI Gerb,
My name is Fung located in Australia, would u be able to help me getting a fsc code? I have tried few dealers but they don't want to give it out. I really appreciate for that.
      02-12-2019, 05:12 AM   #50
Bambazonke
Bambazonke's Avatar
Australia
210
Drives: 2017 X5 & 2020 X5
  [0.00]
yes i have the fdl code changes for both the kombi and the NBT unit as i have 8TH using the GPS emulator version that i fitted myself in my X3 and FSC coded one in my X5 retrofitted by a dealer that uses the camera and Gps database. i saved copies of the Caf files of before and after and used Tokenmaster's Tool to do a comparison
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      03-07-2019, 04:22 AM   #51
mzex
Drives: BMW F06 640D
Succesfully coded on F06 2014, thanks everyone
      03-07-2019, 05:42 PM   #52
dotjonnL
Drives: 335iX M-Performance
Is it still €40? Interested to get the FSC if you can point me in the right direction.
      03-19-2019, 07:01 AM   #53
lostbf
Drives: BMW F15
Smile
Hi Greb, would you please let me know the contact for getting the FSC Code please? thanks a lot
      03-19-2019, 09:26 PM   #54
teja535d
Drives: BMW 535d M-Sport (F10)
Does anyone know if this works for the F10? I have a 2015 535d with lane departure assist, automatic high beams. And is there a way to do it through bimmercode?
      03-25-2019, 03:59 AM   #55
Del1407
Drives: F16 X6 2015 30d M Sport
Hi greb any chance you are still able to get fsc codes? Thanks
      05-08-2019, 12:38 AM   #56
MingLu
Taiwan
Drives: 650i xDrive GC
YES, please PM me. Thanks a lot!!
      05-08-2019, 12:43 AM   #57
MingLu
Taiwan
Unhappy
Originally Posted by baturbo View Post
I have tweeked the instructions I received from Greb to get it working for me
Store the fsc files locally. You should have received 3 files:
e.g. xxxxxxx_007f1234.xml
e.g. xxxxxxx_007f1234.der (FSC Code Certificate)
e.g. xxxxxxx_007f1234.fsc (FSC Code)
1. Add '8TH' to FA and code related modules KOMBI, NBT and KAFAS2. Follow these instructions ( http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf )
2. Load FSC Code Certificate - Options => Settings => FSC Tab => Certificate Field. Load FSC Code Certificate (e.g. xxxxxxx_007F1234.der)
3. In 'comfort' mode go to FSC and browse for the FSC file. (e.g. xxxxxxx_007F1234.fsc)
4. In the 'FA Field' select "Read FA" to use cars current VO.
Enter the following in the fields:
Diagnostic Address (hex) = 0x5D
Application Number (dec) = 0x7E
Base Variant = KAFAS2
Upgrade Index = 0x01
5. Select "Upgrade FSC" to Import and Activate FSC Code. NOTE: I clicked 'update' instead or 'upgrade'. Don’t do this.
6. Select "Check FSC Status", and you should see:
AppID 126
UpgradeIndex 1
SWTType SWTclassic full
FSCStatus accepted
FSCCertStatus accepted
Can't find the PDF file anymore....
      05-09-2019, 04:58 AM   #58
Morozdim
Drives: F46
I’ m from Belgium
Thanks
      05-11-2019, 11:11 AM   #59
munic1234
Drives: F31 F46
Yes please. PM me
      05-11-2019, 04:50 PM   #60
Morozdim
Drives: F46
Hi Greb
Please PM me. Thanks !!
      05-29-2019, 01:55 AM   #61
yuriy.nik
Hi greb, I'm also interested in FSC codes. Please PM for details.
      06-05-2019, 10:42 AM   #62
yuriy.nik
Can someone advice with contacts to get FSC SLI (7E) code?
      06-16-2019, 12:07 PM   #63
javi_es
Drives: BMW X3 F25
HI @Greb can you help me to get the FSC Codes?
      06-16-2019, 12:21 PM   #64
javi_es
Drives: BMW X3 F25
I join the request, can someone upload the guide to Add '8TH' to FA and code related modules KOMBI, NBT and KAFAS2?http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf
      06-20-2019, 04:04 PM   #65
Court
Court's Avatar
Drives: F31 2016 335xD (Current)
Hi greb can you pm me for details and if it will work on my F31.
Thanks
      07-19-2019, 07:43 AM   #66
nosod
Drives: F34
This thread is very useful for some owner, thanks for the sharing!!
coding, esys, kafas, speedlimitinfo
