BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > E-Sys Launcher & Tokenmaster
      05-17-2019, 03:50 PM   #89
BimaExtremeRetro
Drives: e91
Originally Posted by splteko View Post
You may not want to use the 2.8.2 that TM has just released, at least not on a computer that has access to your passwords or data. 2.8.2 installs a trusted root CA certificate that allows TM to decrypt all your network traffic and more.
sorry, but this is simply not true and actually impossible with or without a root certificate.
      05-20-2019, 12:51 PM   #90
justa3bmw
Drives: bmw
hey splteko any update on newer versions of tokenBuster.
      05-21-2019, 08:38 PM   #91
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
2014 BMW 335i  [0.00]
Windows 1903 is out, can someone update and let us know if the launcher issue is resolved? I'm traveling atm.
      05-24-2019, 08:00 PM   #92
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
Just got back to my laptop, updated to 1903. It works again!!
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff
Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser
Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327
      05-25-2019, 10:19 AM   #93
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
New problem: I can't activate my FA... It just sits there loading indefinitely.
      05-25-2019, 02:29 PM   #94
ian332isport
ian332isport's Avatar
Drives: F31 340i Shadow Edition
I had this with E-Sys 3.27. Upgrading to 3.30.1 fixed the problem for me.
      05-25-2019, 03:23 PM   #95
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
I actually did that as part of my troubleshooting, went from 3.28.1 to 3.30.1, not sure if this is still related to Windows problems or what...
      05-25-2019, 04:52 PM   #96
ian332isport
I don’t think it will be Windows related. I was running fine on the insider preview versions, and I actually updated to the latest full release (1903) today, and everything still works fine.
      05-25-2019, 06:01 PM   #97
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
Is it worth it upgrading ESYS to 3.30.1?
      05-25-2019, 06:07 PM   #98
ian332isport
Probably not if the older versions work for you. Can’t say I’ve noticed any difference, but I’m hardly a power user
I only upgraded because I had the problem where the FA wouldn’t activate. I don’t know why the later version fixed it for me, but happy it did.
derbo3610.00
      05-27-2019, 06:02 AM   #99
doctor80
Drives: F30, 328 Xdrive
ok. I updated to 1903, did complete uninstall with Revo uninstaller. Removed both ESys and Launcher.
Installed from scratch.
for now I just started the ESys from launcher, and it worked.
not sure if it was bad installation or Windows version.
I have a question.
For next time, do I need to run tokenbuster again if I want to start ESys? Or starting Launcher alone will be enough?
      05-27-2019, 06:23 AM   #100
cjn
Drives: 2021 F40 M135iX
I have a question.
Good news!
If you haven't messed around with the .EST token file, or reinstalled the Launcher, it shouldn't be necessary to rerun the ToklenBuster.
      06-03-2019, 06:44 AM   #101
justa3bmw
Drives: bmw
@splteko you still there?
      06-05-2019, 04:18 AM   #102
lion87
Drives: 335d e92
it's work whit esys 3.30 ..thanks
      06-11-2019, 06:36 PM   #103
Samu_f21
Drives: BMW 1 Serie
can anyone help me?
always get two medlings. If I remove the message, the program will start. see image
thanks
      06-12-2019, 12:50 AM   #104
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Originally Posted by Samu_f21 View Post
can anyone help me?
thanks
Probably Windows10 issue.
      06-12-2019, 09:53 AM   #105
Samu_f21
Drives: BMW 1 Serie
whats can i do ?
      06-13-2019, 05:24 AM   #106
pzayats
Russia
Drives: BMW F30 2.0D
You can run esys without any sort of token solution. What you can’t do is FDL coding. This requires launcher to handle the required token.
Try opening the FDL editor, and it will request a PIN.
Guys, can somebody please help me with my problem? Yesterday I tried launching Esys using TokenBuster and LauncherPro_2.8.1 and ultimately it launched, but I faced two problems:
1) when Esys launches the following error appears "Connection to E-Sys launcher failed. Restart launcher and try again" - once you hit OK the message disappears and E-sys is working.
2) when I tried to code FDL, E-sys won't accept my PIN, although I am 100% sure I was entering it correctly - the one I set in the TokenBuster tool - 1234.
Thanks!
      06-13-2019, 08:30 AM   #107
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
Both of you need to update windows to version 1903.
      06-14-2019, 06:23 AM   #108
pzayats
Russia
Thanks! After following your advice and updating Windows to 1903 everything works fine!
      06-19-2019, 01:46 PM   #109
Samu_f21
Drives: BMW 1 Serie
After following your advice. everything works fine!
Thanks!
      06-20-2019, 11:21 AM   #110
alex-xs
Drives: BMW f31, BMW f25
it works fine with 1903,
but cannot see anything to code, in the past I coded a lot, now it seems like scrambled after reading out svt
