BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport+ Coding
Studio RSR
      03-04-2014, 09:32 PM   #89
bucawke
Drives: 2015 BMW x5
Originally Posted by Timbits93 View Post
Coding one of the modules results in "Drivetrain Malfunction, Drive Moderately". It just goes away after you turn off the car completely and start it up again. Normal.
Yeah, I remember that happening when I coded Sport+ and SAT last night. The CEL must have been cause by something else I tried coding today.
      03-04-2014, 10:35 PM   #90
Frogman
Drives: 2012 F30 328i
Originally Posted by buco702 View Post
Has anyone gotten a CEL by coding this? I coded this last night and had no problems. But when I coded other things today, I ended up with a CEL. I undid everything, drove to an auto store and pulled the code P144B. My friend tried to clear it and it wouldn't disappear, but then when I left it was gone. Kinda scared to code anything now :/
I don't know about P144B, was it P1448?
P1448 Diagnostic Module Tank Leakage (DM-TL) Pump Too Low During Switching
      03-04-2014, 10:44 PM   #91
Frogman
I did more looking and see a P144B code. Like 1448, It has to do with an issue between the fuel being used as reported by the DME and what the rate of fuel level change is.
Probably triggered by running the engine while coding.
It's not related to the EGS (transmission), just some anomaly for sitting idling for a long time. If it cleared on it's own, you should be fine.
      03-04-2014, 10:53 PM   #92
bucawke
Drives: 2015 BMW x5
I'm sure it was P144B.
I never kept the engine running while I coded. I had the battery hooked up to an external charger. I'm hoping it was just a fluke.
      03-05-2014, 01:18 AM   #93
Frogman
Strange, the P144x code range seems all related to the fuel system. At least it cleared on it's own for you.
      03-06-2014, 03:56 PM   #94
FanboyBMW
Drives: 2013 BMW 328xi
are you able to code the sport + if i have xdrive???
PM me please to reply
      03-06-2014, 04:19 PM   #95
ardyer
Drives: 2014 320xi
As someone new to all this, would the presence of xdrive matter for this? I wouldn't think so, but I would like know sure.
      03-06-2014, 05:52 PM   #96
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2022 X4 M Competition F98 LCI
Given the Sportline and M-Sport xDrive models have Sport+ (mine has that setting), i don't see why it would be a problem.
      03-07-2014, 09:48 AM   #97
carzaddict
Drives: 2015 Cadillac Escalade ESV
my xdrive came with sport+.....its not an issue
2015i Cadillac Escalade ESV
      03-08-2014, 06:18 PM   #98
ardyer
Drives: 2014 320xi
Does this require any packages/options to work or does or work on any f30?
      03-09-2014, 11:48 AM   #99
carzaddict
you can code any F30 to have Sport+
but if you get the sport line or M-sport...car comes with it coded already
      03-09-2014, 02:43 PM   #100
ardyer
Drives: 2014 320xi
Thanks! That's what I assumed, but you know what they say about that...
      03-09-2014, 08:40 PM   #101
hsk1610
Drives: 2013 328i xDrive
I was able to only partly code for the following and got the Sport + DSP Off on the Dash, but for some reason, my CADF file for EGS seems to be corrupted and could not retrieve a copy to inject into the vehicle computer. What do the two commands under EGS do?
Can someone send me their CAFD file for the EGS for a 2013 BMW 328 XI?
Kombi => 300C ECO_FDS =>Function
FDS_MENUE_TEXT_1=> menue_3
FDS_MENUE_SIGNAL_1=> menue_3
FDS_MENUE_TEXT_2=> menue_3
FDS_MENUE_SIGNAL_2=> menue_3
FDS_MENUE_TEXT_3=> menue_3
FDS_MENUE_SIGNAL_3=> menue_3
FDS_MENUE_TEXT_4=> menue_3
FDS_MENUE_SIGNAL_4=> menue_3
ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut
EGS/3000 Applikation -> Sportschalter_alt -> aktiv <-- unable to code
EGS/3000 Applikation -> Sportschalter -> aktiv
<-- unable to code
ICM/IcmKod_B_S2TBA -> verbaut
      03-09-2014, 09:45 PM   #102
shawnsheridan
shawnsheridan's Avatar
I replied to your PM.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-16-2014, 10:17 PM   #103
TheDukeYYC
Drives: TBD: F30 320i ZSP + ZMT ?
I programmed my car using the below (320i xDrive, Canadian version) and I now have Sport+ . I drove a few KM and got the engine warmed up, but have no launch control...
I googled and saw something that said you had to have 6 miles / 10KM on the car running before it engaged - that may be my problem - Can anyone confirm if the F30 requires 10KM on it before it 'unlocks' launch control?
Originally Posted by Timur View Post
It is possible . I have done on on my 320i.
Do the following:
It will activate sport+ and sport transmission )))
Or you also could add 2TB option and delete 205 in salapa element
      04-18-2014, 08:32 PM   #104
FanboyBMW
Does coding your car to sport + void your warranty?
please someone send me details
      04-18-2014, 09:25 PM   #105
shawnsheridan
Coding does not void your warranty. BMW would have to prove that your coding caused car to somehow fail, and even then, the warranty void would be limited to just that specific issue, not the entire car.
      04-21-2014, 12:12 PM   #106
FanboyBMW
do you promise??
      04-21-2014, 12:14 PM   #107
shawnsheridan
If you are that worried about it, I suggest you not code your car then.
      04-21-2014, 12:19 PM   #108
carzaddict
do you promise??
no one here can promise that coding wont void your warranty.
The fact of the matter is, IF something goes wrong during coding...it CAN render your car useless and YES will VOID your warranty. the chances are low, but its possible.
the risk is on you and only you. it doesnt sound like something you're willing to handle
      04-21-2014, 12:26 PM   #109
FanboyBMW
woah man!
ok i know i heard it can malfunction the CPU unit and sounds like most people with bimmers down in USA like to code so I think I can trust you guys
I am a little confused about one thing though; I have a luxury line xdrive 328i can I still code the SAT into the car along with sport +??
Another question to you guys then; Have you guys had malfunctioning issues after installing the sport + mode? warning lights, all that stuff?
I am planning to install the DINAN suspension kit, will it affect the adding of sport + ???
      04-21-2014, 02:33 PM   #110
ardyer
Drives: 2014 320xi
I haven't. I had the coding done for Sport+ in February and I have yet to have a warning light for anything. I didn't do the coding myself though.
