BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Lane Departure Warning / Speed Limit Info
proTUNING Freaks
      01-27-2021, 07:57 AM   #177
music21050
France
Drives: BMW 530 xdrive
Originally Posted by Siki78 View Post
you will need BE and BF fsc if you dosen`t have it already
what is BE and BF fsc?
      01-27-2021, 08:10 AM   #178
Siki78
Siki78's Avatar
136
Drives: F30,G30
-Kafas BE Front Collision Warning
-Kafas BF Pedestrian Detection
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      01-27-2021, 10:09 AM   #179
shawnsheridan
shawnsheridan's Avatar
Originally Posted by music21050 View Post
'''I activated the line in the kombi with bimmercode
on the other hand I have no display in the hud, neither when stopped, nor while driving, is this normal?
do I have to do it with e-sys?
another question: can I display the turn signals in the hud?
thanks for help...
Asked and Answered:
Originally Posted by shawnsheridan View Post
To enable in HUD, try FDL Coding
DKOMBI => HUD_TLC_ENABLE = aktiv
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      01-27-2021, 11:52 AM   #180
music21050
France
I coded with e-sys, "DKOMBI => HUD_TLC_ENABLE = aktiv" , but it doesn't change anything, I don't have anything displayed in the hud ....
      01-27-2021, 12:06 PM   #181
shawnsheridan
Then it is not supported in your car.
      01-30-2021, 10:40 AM   #182
music21050
France
thank you for the answer and the help provided
I'm just waiting for my new steering wheel, and I'll post for the result
      10-28-2021, 10:12 PM   #183
white328i
Drives: F30 328i
Hi all,
My car originally fitted with Driver assistant Plus (Front Collision Warning, Pedestrian Detection & Lane departure warning). However after changing my steering wheel to M Sport (which does not comes with a module and vibrator in the steering), my lane departure warning was deactivated and each time I start my car it will displayed a warning on the deactivation.
I have tried to recycle the harness & module (black box) from my previous steering wheel and it able to eliminate the warning sign when starting my car, but this causes the horn to stop working because of the harness
So my question is, can I code via esys to make the warning message and fault to disappear while I am using the harness that comes with the M Sport steering wheel (which horn are working)?
Appreciate if anyone can advise the solution and have attempt to resolve the similar issue.
Thank you!
      10-29-2021, 12:31 AM   #184
shiftdnb
Drives: 2017 F31 328dx
Originally Posted by white328i View Post
Hi all,
Thank you!
Vibration Unit - 32-33-7-849-416
Module - 61-31-7-849-393 - Check your module number as you may already have this in the wheel already.
If the wheel has paddles you should be all set with the harness in there as it differs on having sport auto transmission or not.
Front Trim Pad - 32-30-7-850-622
      10-29-2021, 01:31 AM   #185
Siki78
Siki78's Avatar
136
Drives: F30,G30
I will see first if you have heating steering wheel. If not then buy this 61317849392 module or you will have error in ista and you will not be able to turn this off.And you will need new wiring set 32307848337
      10-31-2021, 04:32 PM   #186
elettronicksportcar
Italy
Drives: bmw f10
kombi
DISP_LDM_2_ALIVE: aktiv [01]
DISP_LDM_2_APPL: aktiv [01]
DISP_LDM_2_CRC: aktiv [01]
DISP_LDM_2_TIMEOUT: aktiv [01]
IBRAKE_VERBAUT: aktiv [01]
ST_TLC_ALIVE: aktiv [01]
ST_TLC_APPL: aktiv [01]
ST_TLC_TIMEOUT: aktiv [01]
TLC_VERBAUT: aktiv [01]
FRM
LIN_PUBU_TLC: aktiv
ICM
C_KOV_TLC_verbaut: verbaut [01]
C_Sperrtrigger_dynamisch_CTR_VIB_STW: aus [00]
C_Sperrtrigger_dynamisch_ST_COOR_VIB_STW: aus [00]
Verbau5AS_DriveAssist: verbaut [01]
//////////////////////////////////////////////////7
NBT
BRAKE_ASSISTANT_FCW: aktiv [01]
LANE_DEPARTURE_WARNING: aktiv [01]
      11-05-2021, 03:53 AM   #187
white328i
Drives: F30 328i
Originally Posted by elettronicksportcar View Post
kombi
FRM
LIN_PUBU_TLC: aktiv
ICM
NBT
I have checked on the parameters:
Out of all the value only 3 codes is different:
FRM
LIN_PUBU_TLC: aktiv
ICM
NBT
Rest of the codes has been set to "AKTIV" and "aus" as default.
Will update if these 3 code works to switch off the LDW warning in the absence of the module
Thank you.
      11-09-2023, 08:51 AM   #188
Oto
Drives: BMW 218d Active Tourer 2014
Is it possible to buy FSC BF and BE somewhere for around 60 euros? I bought from this site
https://www.baum-bmwshop24.de/bmw-fs...2444948-73729/
7e, but I can't find BF and BE. Or can someone advise what the number is for BF and BE?
for 7E it is 66502444948. I can't find another FSC because I don't know the product number. Or can someone sell for about 60 euros?
      11-12-2023, 01:34 PM   #189
TheNine90
Drives: bmw
PM me i can provide both BF and BE FSC.
      01-05-2024, 05:24 AM   #190
labanauskas
Lithuania
Drives: F30 LCI 318d
Hi!
Can I code LDW to stay always on, while i'll get buttons for it?
O is it possible to code LDW without 5AD VO, but only using FDL?
Retrofits: 248, 2TB, 302, 3AG, 5AC, 5AS
      01-09-2024, 10:45 AM   #191
TheNine90
Drives: bmw
Its possible to code it manually but need to know the fdl for 5AD then use for LDW only
      01-12-2024, 12:08 AM   #192
labanauskas
Lithuania
Yesterday I've done 5AS retrofit, but steering doesn't vibrate when crossing detected lanes without turn indicator. Any ideas? Faulty vibro motor? Or I've made mistake by coding both 5AD and 5AS?
      01-12-2024, 01:47 AM   #193
Siki78
Siki78's Avatar
136
Drives: F30,G30
Just one of this can be code so 5AS or 5AD not both
      01-12-2024, 04:10 AM   #194
labanauskas
Lithuania
Thank you! 5AD is for pre lci... Can you tell which ecus should be coded? I did on dsc, icm, fem, hu, kafas2, kombi.
      01-12-2024, 11:34 AM   #195
Siki78
Siki78's Avatar
136
Drives: F30,G30
Read with ista and write error here. This coding should be enogh
