BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Did engine oil change (328i) myself today
proTUNING Freaks
      04-30-2013, 04:48 AM   #67
williammm
Drives: BMW F80 M3 (2016)
Is there a need to replace the oil screw plug (PN. 11137605018)?
Or is the rubber o-ring supplied?
      11-25-2014, 05:20 PM   #68
Mauricio Palacios. MD
Stark und Frei
Mauricio Palacios. MD's Avatar
Drives: BMW F32 435i M Sport
Originally Posted by yjoonee View Post
It's 5 quarts. I did some research and local BMW service dept checked it for me. After the engine oil change, if you run the oil level check built in our cars, it's right at the top of the Max level line.
Hello friend! Do you know how much oil is for a N55? Thanks.
      11-26-2014, 05:36 AM   #69
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
The plug is reusable. All O-rings and crush washer (oil plug) come with the filter.
      11-30-2014, 02:52 AM   #70
dreamspeed
dreamspeed's Avatar
Drives: 6MT
Although changing the oil every 3-4k with synthetic is overkill, it certainly beats going 15k.
Depending on driving habits the oil may or may not last that long
      04-07-2015, 07:46 PM   #71
GarbageMan
Drives: 2014 M5
I have an M5 (which is where I've been on the forum). At any rate, I bought 2014 CPO 328i for my daughter for graduation this past weekend. As with the M5, my biggest complaint with BMWs is the lack of a dipstick, and an obstructionist position towards the consumer doing any maintenance. It took me a bit to get the proper oil capacity on the M, but I finally did. This little car has ~6,500 miles on it, and I want to get my Mobil 1 0W-40 in it. So, just to be sure, capacity is 5.3 quarts? (This is what I'm told by the dealer). (I need a password to get into BMWs service database...). Thanks...
      04-09-2015, 09:53 PM   #72
GarbageMan
Drives: 2014 M5
Bump
      04-11-2015, 04:35 PM   #73
GarbageMan
Drives: 2014 M5
Did it today. I actually pulled 8 oz from the 5qt jug of M1 0W-40, and the oil monitor still read full... I bought a little 3/8 torque wrench (inch pounds) to insure light touch on that plastic oil plug...
      04-23-2015, 10:37 AM   #74
F30lolz
I can haz cheezburger?
F30lolz's Avatar
6799
Drives: 14 Sahara/08 335xi/22 Maverick
I had the oil changed in my 2013 F30 this past Friday at 1565 miles. Currently iDrive says oil service is due within 11K miles so I'll have it changed again on my own dime around 7K miles.
Originally Posted by RaptorKTM View Post
Also our E90 330 and 325 will soon have some sort of boost. So there is actually more of a chance to get more hp out of a 330 then a 335 in my opinion
      06-30-2015, 05:20 PM   #75
skanderbeg
Drives: F30 328i
For what it's worth, wikimotors states the engine oil capacity is 5.3 quarts for N20 engine. I put 5 quarts during my last oil change and the oil level reads at the max mark.
http://mywikimotors.com/bmw-n20/
      07-07-2015, 02:39 PM   #76
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
I used mobil 1 0W-40 on my e90 for 10 years and the car is/was running strong. Used it on the M235i and plan to use it on the 428 also
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      07-07-2015, 02:47 PM   #77
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
You guys crack me up about torqueing a plastic plug by torque specs
2006 325xi (Sold)
      07-08-2015, 10:14 AM   #78
fusion0389
Drives: 2016 328i xDrive M Sport
There's alot of info in this thread. I'd like to know the rationale behind BMW's choice of a plastic oil pan\plug on the RWD 328i? That just seems stupid.
As to the oil change intervals, you cannot always believe the MFG claims that 15k is appropriate for every situation. Yes synthetic does increase the OCI, but we all drive our cars differently. My 2016 328i xDrive M Sport is on order, i plan on doing shorter OCI's in between the free BMW ones. I generally do Blackstone Oil Analysis reports whenever I change my fluids and will be posting the results here.
Lastly, lifetime fills are completely bogus. I've completed oil analyses of several different components of my previous daily driver (trans, transfer case, rear diff) all of which claimed "lifetime fill." Needless to say, the Blackstone analysis report disagreed with the MFG claims.
      07-08-2015, 10:25 AM   #79
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Bmw is now 10k mile change or 1 year
The plastic pan is prbly for cost and weight savings
2006 325xi (Sold)
      07-06-2016, 09:06 PM   #80
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [0.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [0.00]
For those that are interested, I just finished a DIY video for an N20/N26 oil change. Thread is here.
Video is here:
      07-11-2016, 10:42 AM   #81
Johannes356
Drives: 2012 328i
So the RWD 328i with the plastic tank and plug has a massive shield that requires about 15 torx screws to be removed in order to access the drain plug. Has anyone found a replacement shield that wont require removal each time the oil needs to be changed? If all else fails I may get the scissors out and cut an access hole because that thing is a PITA to put back/remove each time and I just dont feel comfortable not having since the oil pan is plastic.
      07-17-2016, 03:09 AM   #82
MPG
Drives: 2013 328i M-sport
There should be one screw that opens the access door to the drain plug
      07-17-2016, 05:30 AM   #83
cncmastr
cncmastr's Avatar
2018 X5 M  [0.00]
2020 M2 CS  [0.00]
2006 BMW M3  [0.00]
That sounds like the front reinforcement plate. The bolts might be one time use torque to yield. Toward the middle of the car, just ahead of the transmission there should be a small opening or a screw that holds a door closed, under there is the drain plug for the oil pan. You'll see it in the video I posted above.
You should NOT have to remove an entire shield under the engine to drain the oil.
      08-11-2016, 08:25 AM   #84
Toothy
Drives: 2016 328i xdrive
Got a new 2016 328i xdrive with N26 engine. Service guys swear you don't need to change more often than every 10K but my plan is to do a break-in change at 1,500 and then one between the free 10K changes. Can't believe the owners manual doesn't tell you how much oil to use Anyhow sounds like 5 - 5.5 quarts of 0W - 20. My question is will the DIY oil change reset the maintenance notice intervals that display on the dash?
      08-11-2016, 12:54 PM   #85
MickAv8r
MickAv8r's Avatar
Drives: 2014 EBII 328ix
Let's put this to bed once and for all. From the Service Manual (Bentley)
N20/N26 Engine
AWD = 5.1 US Quarts (4.8 L)
RWD = 5.3 US Quarts (5.0L)
N55 Engine
6.9 US Quarts (6.5L)
N47 (Diesel)
5.5 US Quarts (5.2 L)
So for an N20/N26 just buy the 5L jugs and call it good.
and before you ask, no the manual does not cover the B48/B58 engines yet.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware!
2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK
      08-11-2016, 01:02 PM   #86
MickAv8r
MickAv8r's Avatar
That is reset manually. Press hold the Odo button for 10 seconds+ and youll get the menu to appear.
      08-11-2016, 01:12 PM   #87
CruzM3
CruzM3's Avatar
Drives: 2018 M3 "Velocity Edition"
I did kind of the same thing on my wife's 2016 328i with N26 engine. Changed the oil at 2k mi. To get the break-in stuff out and I plan to get the next service done at the dealer at the normal service interval. I used 0W-30 BMW Castrol Professional. Haven't decided if I'm going to do supplement oil changes with the 328 as 10K is a little longer than I would like to go. I definitely won't be going that long on my 340i.
      08-15-2016, 06:36 PM   #88
Class5Kayaker
Class5Kayaker's Avatar
Drives: 2016 BMW F15, 2014 Porsche 991
Here's how you reset the oil change reminder as well as other things (brake fluid, pads, etc.)
2016 BMW F15 xDrive 35i - Imperial Blue Metallic
2014 Porsche 991- Sapphire Blue Metallic
MattRST109.50
