02-09-2016, 10:28 PM | #23 |
Rep 1,503
02-09-2016, 11:02 PM | #24 |
Rep 448
BMW roadside as well as car insurance roadside should do it... Jack and TQ wrench in the garage should take care of the rest would waste a lot of space and unnecessary weight to carry it along
02-10-2016, 07:49 AM | #25 |
Rep 222
As others have said, Carry a jack and a plug kit and a tiny compressor and you are good to go.
I've plugged two tires (rft) while on road trips on my 328. Thousands of miles later and they are still fine. Plugs are lifetime repairs for everything but track tires for me. Why waste hours waiting for a tow, especially on a road trip? |
02-10-2016, 10:04 AM | #26 | ||
Rep 16,065
02-10-2016, 01:53 PM | #27 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I think the confusion is the plug part. The 'old' method was to drive a piece of rubber/glue etc into the hole and it'll act as a plug which you can do either on or off the car. With speed rated tires, this isn't the best idea. Shops, as we all know, remove the tire and patch it from the inside, which is the better process. Tires lose their speed rating once they have a hole. Not sure what it knocks them down to, but they are no longer the designation on the tire. (Not that we all go 130+ mph).
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
02-10-2016, 01:54 PM | #28 | |
Rep 3,258
25% 3M Tint| |
02-10-2016, 02:22 PM | #29 | |
National Championship #17 and Counting!
793
Rep 1,508
I carried a hydraulic jack which was a bit big and heavy, but effective and quick to use. Now it stays at home.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
02-10-2016, 02:27 PM | #30 |
Rep 821
Not exactly true. If you ruin one tire you can purchase a new tire and have it shaved down. Many a tire store does it. Or you can replace two on the same axle.
02-10-2016, 03:17 PM | #31 |
Rep 1,329
Yes, the best repair is a patch from the inside, but these plug kits certainly are a very effective method to get you off the side of the road and buy time to get the tire repaired at a shop.
Unless you just assume you are replacing the tire, I stop when the tire pressure warning first goes off. I carry a pressure gauge, very small cheapy pump for emergency use only and plug kit sealed in a ziplock freezer bag so the plug stays soft for as long as possible. I don't bother with a jack unless I have a spare. I understand the idea that jack helps make the repair easier, but as this is only in case of emergency I get it done without by moving the car to the easiest point to access. It has been awhile since I have had a flat on either run flats or go flats. I keep a close eye on my tires and don't seem to drive in areas risky to get punctures. I usually stay 100 miles from home, but if I were road tripping I might consider a spare, jack and wrench if I had the room. I am funny about who I let work on my car, so it would buy me comfort if I were away from home. |
02-10-2016, 03:26 PM | #32 | ||
Rep 16,065
02-11-2016, 03:06 PM | #33 |
Rep 1,329
If 40% of your mileage is away from home, then I would do 1 of 2 things:
Either plan on replacing the tire with any flat and carry just a can of fixaflat in case you are more than 50 miles from a replacement tire. Or carry a jack, wrench and spare. I think run flats really only make sense under certain use and are playing the odds that you probably wont have a flat with a tire that is worth saving. Which given most peoples use of a BMW is probably a fair bet. |
02-11-2016, 03:29 PM | #34 |
Rep 8,942
For what it's worth I once waited 4 hours for BMW roadside. In addition to the kit others have mentioned I'd also include a small sledge hammer. If your wheel is stuck on the hub a knock or two (always on tire never wheel) will break it free. Before I started carrying the hammer I once slid under the car and delivered a swift kick. Worked fine but then realized if wheel comes off and jack gets knocked loose, car would have landed on me. No Bueno.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
02-11-2016, 10:17 PM | #35 | ||
Rep 30
02-12-2016, 06:26 AM | #36 |
Rep 603
The plug kit, air compressor, and tire gauge are a great idea. I keep those in my car although I'm not using runflats. I personally think this is much better and cleaner than fix a flat, that stuff makes a huge mess.
- 2022 X3M Comp
- 2021 X5 xDrive 40i - 2018 F80 M3 (sold) |
02-12-2016, 07:41 AM | #37 | ||
Rep 16,065
02-12-2016, 09:23 AM | #38 | |
Rep 821
02-12-2016, 10:23 AM | #39 |
Rep 16,065
+1. There would have to be a major difference for it to matter, and I for one wouldn't shave 10,000 miles of tread off a new tire to satisfy what's more of a OCD issue than an actual need.
02-12-2016, 11:37 AM | #40 |
Rep 821
