BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > BMW 437M wheels (Black M4 wheels)
      08-07-2014, 10:10 AM   #1
messiry
messiry's Avatar
Drives: F15 X5 35, E60 530
Hi everyone, i would like to take your expert opinion on changing my OEM F32 44M2 wheels to the M4 Black wheels
The F32 oem are
Front axle: 8"J x 19" offset 36
Rear axle: 8.5"J x 19" offset 47
The 437M wheels are
Front 9JX19 ET:29
rear 10JX19 ET:40
Thank you.
      08-07-2014, 10:30 AM   #2
remmib
remmib's Avatar
Norway
1571
Drives: 2013 F10 520d M-Sport
Front will extend 20mm, and rear will extend 26mm.
Don't know if that's too much though.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      08-07-2014, 01:47 PM   #3
335i_4D
Now in the dark side !
335i_4D's Avatar
Drives: 2011 911S 997.2 Cab
Wow, for once, the M wheels look like an almost direct fit for the non-m cars.
I've seen people posting 9j x 20 30 offset and 10j x 20, 40 offset installed without any problems.
If you have a good relation with your SA, I suggest you go there and try them on to see the fit.
I know my SA would do it, just to see the looks it gives to the car...
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey)
Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed)
2010 X5 35d Black fully loaded (Sold)
2007 335i sedan Antracite (Sold and missed !)
      08-07-2014, 02:16 PM   #4
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Will work on a lowered car (as the camber will tuck them). On stock height they will be 10-15mm outside the fender.
My HRE where an identical fitment (look at my older threads).
      08-08-2014, 02:35 AM   #5
messiry
messiry's Avatar
Thanks for the reply guys. i saw these wheels on F30 and it looked damn cool. i am planning to select more conservative tires not the same as the stock M4, so for the front 245/35/19 and rear 265/30/19. i checked on tirerack.com and found these tires for BMW. will that make difference? do i still need spacers?
      08-08-2014, 01:08 PM   #6
335i_4D
335i_4D's Avatar
Since they are already limit on fitment, don't put spacer as things will get worse.
Spacer substract from the offset, so the wheel will stick out more.
BMW X3 M40i (wifey)
      08-09-2014, 08:55 AM   #7
messiry
messiry's Avatar
No plan for spacers don't like them anyway,, I am planning front 245/35/19 and rear 265/30/19, will it rub on stock M sport suspensions?
      08-09-2014, 09:43 AM   #8
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
It will look silly on stock suspension. The wheels will be 10-15mm outside the fender. You need to lower the car.
      08-09-2014, 11:01 AM   #9
betlion
Drives: bmw
235/35/20 and 275/30/20 would be better
245/35 is almost .5 inch taller than 265/30 IMO
      08-09-2014, 11:11 AM   #10
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
It is not recommended to put 20" tires on 19" wheels...
      08-10-2014, 03:53 AM   #11
messiry
messiry's Avatar
ohhh Sorry my mistake i meant 20" wheels for sure
thanks anyway for your suggestion, i checked your other threads, you have a very nice F30.. i like the exhaust too.
cheers
      08-10-2014, 04:07 AM   #12
messiry
messiry's Avatar
the 235/35/20 will work too as the stock are 225/40/19 so it should be ok with no rub,, however i am not sure about the rear i am a bit worried that 275/30/20 will be aggressive thats the only reason i was checking the 265/30/20..
need to check on tire rack.com if its can be done.
thanks for the help
      08-10-2014, 07:41 AM   #13
G30 B58
Pace Car Driver
1555
Drives: '22 AW G30 B58 M-Sport
http://f30.bimmerpost.com/forums/sho....php?t=1003865
http://f30.bimmerpost.com/forums/sho...d.php?t=994084
Link? What you probably saw were 20" M5 wheels (or knock-offs).
This has been covered numerous times.
      08-11-2014, 01:05 AM   #14
messiry
messiry's Avatar
i saw it parking nearby, don't have a photo sorry,,, and i am sure its 437M i had the M5 wheels, or actually i still do have them in my garage after selling my F10 however i couldn't find anyway to fit these M5 oem rims on my F32,, thats why when i saw these black rims on that car i was shocked, it looked really nice.
      08-11-2014, 04:51 AM   #15
messiry
messiry's Avatar
not sure if you guys saw this thread http://f30.bimmerpost.com/forums/sho....php?t=1020934
looks nice, and no rub.
      10-01-2014, 01:11 AM   #16
davegill
Drives: 2014 428xi Coupe
Did anyone end up trying this? I would like to know how it worked out and see pictures.
      11-06-2014, 11:55 PM   #17
okuruca
Drives: 335
+1 I want to know if you ever pulled the trigger and how well it worked
      11-08-2014, 01:35 AM   #18
Labeef
Labeef's Avatar
265
Drives: 320I Sport/Xenon
Stay tuned, I will have 513s to try on my 3 in the next couple days. I honestly think it will be okay at stock height and killer lowered.
      11-09-2014, 04:09 PM   #19
Labeef
Labeef's Avatar
265
As promised.
http://f30.bimmerpost.com/forums/sho...2#post16906972
perezr10140.50
      11-11-2014, 04:27 PM   #20
ecbb125
Drives: 2015 435 Gran Coupe M sport
435GC on 437m wheels
This is my 437 setup. Haven't touched the suspension. I have 245/35/19 and 285/30/19 in the back. Michelin Pilot sport A/S tires.
Name:  2014-11-11 15.55.57_resized.jpg
Name:  2014-11-11 15.59.21_resized.jpg
Name:  2014-11-11 16.19.18.jpg
      11-11-2014, 09:10 PM   #21
Labeef
Labeef's Avatar
265
I ordered H&R Sport springs, hope I don't rub with a 255 on the front. Any one running H&R sports, x9 Et +29, with a 255?
      11-12-2014, 11:34 PM   #22
messiry
messiry's Avatar
Attachment 1116588
Attachment 1116589
Attachment 1116590
that looks very cool on F36, does it rub, how is it on bumpy roads, anything different you felt. thanks for sharing
