01-31-2020, 04:43 PM | #23 | |
Rep 29
08-27-2022, 09:50 AM | #25 |
I make videos for all things F34 !
55
Rep 40
The HK system isn’t great. I have a blown speaker in my passenger door and blown dash speaker too. I think BavSound is the best option, aftermarket or OEM.
08-27-2022, 01:08 PM | #26 |
Rep 16,144
Bavsound sells re-badged Chinese gear that's not even the equal of OEM. This is where they get it from.
https://www.aliexpress.com/item/3256...80119986%21rec https://www.aliexpress.com/item/3256...52428024%21rec |
MEN54238.00 |
08-27-2022, 02:16 PM | #27 |
Rep 666
lol, so whoever buys bavsound speakers have been conned by their social media marketing. God bless their money, lol
btw, how do you determine the OEM is better than the bavsound? i mean there is no spec paper on the OEM speakers. do you based it on your listening only? this guy supremeF34 is resurrecting a lot of old thread, totally self promoting Last edited by dangerus_car; 08-27-2022 at 02:30 PM.. |
08-27-2022, 02:39 PM | #28 |
55
Rep 40
dangerus_car yup basically just my own listening lol. I like to think I have a good ear.
Have I posted links to my videos? Yes. But not in every post. Besides, I've answered some questions that haven't been answered yet, or answered fully. I just don't understand how sharing my videos from time to time is a problem. I mean, they are topic-related. Is this not a place to gain/share knowledge of BMWs? Aren't you required to make "a certain number of replies" to get full access in here? I know I'm the new guy posting but yikes |
BimmerBren108.00 |
08-27-2022, 04:51 PM | #29 |
Rep 16,144
There's no specs on the Bavsound/Isudar speakers either. They show SPL charts, but they're fake. The 'Average Joe' wouldn't know that, but I've been designing speakers since 1969, so I know a fake when I see one. I have the specs on the OEM Hi-Fi speakers and real SPL charts because I measured them.
johnung4537.00 |
09-18-2022, 02:38 PM | #30 |
Rep 28
I will resurrect this thread once more due to my recent experience. I had the full Bavsound HiFi replacement in my 2018 330i GT which was installed separately in this order: amp, woofers, door speakers. Unfortunately that car was totaled in August and I replaced it with 2018 430i GC with Harmon Kardon. So now I have apples to apples comparison of 3 distinct systems.
Here's my assessment. The HiFi system was embarrassingly bad for a premium car like BMW. My previous Acura with the technology package blew it away. The Bav amp was a major improvement making everything cleaner, more neutral and with a wider sound stage. The amp revealed how weak the woofers were so on to stage 2. The Bav woofers are punchier and tighter but not necessarily lower dB. I decided to go ahead with main speaker replacement. It was a lot of work on installation but a marginal upgrade. In fact, I had to turn down the treble because they were overpowering the sound. In summary, I was very pleased with the amp upgrade, liked the woofers but disappointed with the main speakers. Now onto the H-K system, I can say it is a ton better out of the gate from HiFi to the point that I could live with it as-is. The equalizer, limited though it may be, is useful. I have done some research on the upgrade options to H-K and they are fairly limited. I visited the Bimmertech showroom (I live in the Orlando area) and discussed with them. Because it uses a fiber optic cable, Bimmertech does not offer an amp replacement. I'm not sure who does though I am not spending the exorbitant cost for Bav anymore if they do. I am also not going through the hassle of replacing all the main speakers. Just not worth my time and really they aren't terrible. I am interested in replacing the woofers with Earthquake 8x. In fact I have spoken directly to the owner Robert about it. I believe Earthquake is the only true audiophile option for underseat woofers. He explained that some H-K systems have different impedance from the factory though you wouldn't have any way of knowing without testing with an ohm meter. I tested mine and it happens to be 8 ohm. They offer a 2 ohm and a 4 ohm woofer. I can't find specs on the H-K amp, am not interested in an external amp, and now trying to decide if the 4 ohm Earthquakes are a good match to the amp. If anyone has direct experience or can send a link to a thread, let me know. |
09-18-2022, 05:52 PM | #31 |
Rep 16,144
As you've found out, and many of us have long been preaching, the amp is the weakest point, not the speakers. The best amp is the MatchUp 7. The H-K underseats are 8 ohm, as opposed to the 4 ohm Hi-Fi woofers. That's a wiring consideration. You can get more power with more voltage into a higher impedance or with more current into a lower impedance. More current requires larger wire to handle it. BMW went with higher voltage. The H-K amp may be able to handle a 4 ohm load, but I wouldn't trust the wire being able to handle it. The Earthquake sub in 2 ohms is the best option, but it demands being either separately amplified or be used with an amp that has separate volume control over the sub amps and mid/hi amps.
Threads dealing with the MatchUp 7 and Earthquake abound in the Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics section. |
09-18-2022, 07:11 PM | #32 | |
Rep 5,399
The HK amplifier doesn't supply enough power to the subs, so install a secondary amplifier like the AudioControl ACM-2.300 along with a Technicpnp wiring harness to connect the HK amplifier to the secondary amplifier. I have posted details about this so just search Bimmerpost. |
Billfitz8278.50 |
09-23-2022, 10:05 AM | #33 | |
Rep 481
Bro, its just a disabling a feature within car's computer via a coding software, its just that simple. |
09-23-2022, 01:58 PM | #34 |
Rep 5,251
Hey just to update I did do this a few years ago after i posted and it was great. Silence is golden fake noise is bad.
