BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > radio volume??
      10-05-2012, 08:42 PM   #1
emtrey
emtrey's Avatar
92
Drives: 16 M235IX, 06 Carrera S, 335i
radio volume??
When I turn off my car with the radio set at a given volume, the radfiod does not retain that volume and comes back on at a much lower volume.
Is there a setting that controls the radio volume where the normal user volume is retained when the car or radfio is turned off ?
thanks in advance.
      10-14-2012, 07:41 PM   #2
fshubert
fshubert's Avatar
89
Drives: 2015 F30 335i
Have not noticed that. Radio seems to come on at the volume I last left it at. Perhaps a different FOB is making the change?
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      10-17-2012, 08:35 AM   #3
emtrey
emtrey's Avatar
92
I drive the car 99.9% of the time. Just can't figure this out..
      10-17-2012, 10:07 AM   #4
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Yea it does that
M Sport Line Estoril Blue
      10-17-2012, 10:16 AM   #5
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Yeh it does start at a lower level. I've been looking for away to change the start up volume but couldn't find it. My Gti had this feature too but I knew how to set that start up volume.
      10-18-2012, 12:53 AM   #6
RPM90
Drives: 340i M-sport AT
My last 3 BMW's and the A4 did the same thing, the audio volume starts at a lower level than if I turned the system off at higher volume.
I like this feature very much. It's nice in the morning when you don't want something LOUD blarring at you like some of my older cars that retained the last volume setting.
I'm not positive, but I thought there was start up volume setting where you can set the "start up" default level. Maybe that was in the A4?
Not sure. Look for it in the manual, I'll have a look too.
      10-18-2012, 07:20 AM   #7
jwilly
Drives: They're all white now.
Speaking of radio volume, does anyone notice that the volume control is not very speed sensitive? By that, I mean that the volume does not decrease very much when stopping from highway speeds and vice versa. In my E46, this feature worked very nicely. Not seeing it so much with the F30.
Joel
That's a lot of white
      10-18-2012, 08:56 AM   #8
emtrey
emtrey's Avatar
92
did not see anything in manual and did not get much info from CA either.
'09 135 did not do this..
      10-18-2012, 09:20 AM   #9
Latinnftl
Drives: MY 13 328i Mineral Grey
The volume is speed sensitive and drops significantly when I come to a stop. However, at start up if I have pulled right into the drive way the volume is the same as when I turned off the car.
      10-18-2012, 10:03 AM   #10
Frogman
Drives: 2012 F30 328i
Joel
You can adjust the speed volume sensitivity.
I have mine cranked up to about 80%, it helps a lot.
      10-19-2012, 10:19 AM   #11
jwilly
It's a very subtle change on the F30 compared to my E46.
Joel
      10-20-2012, 06:26 PM   #12
RPM90
Must have been the A4.
I don't see setting either, cause there ain't one, as you say from the manual.
      10-20-2012, 06:28 PM   #13
RPM90
Joel
It works noticeably in my 335i HK system.
But, now that you mention it, it does seem to come UP as speed increases, but doesn't seem to go DOWN as much as speed decreases. Hmmm...
I'll have to listen closer next time to hear the differences.
      10-20-2012, 06:45 PM   #14
Frogman
Agreed, the picture in the manual does not show it, but the text mentions it. I have in on my non-HK system.
      10-27-2012, 07:30 PM   #15
emtrey
emtrey's Avatar
92
talked to service yesterday. This is a FEATURE to prevent blown speakers. No way around it unless they do a software update at some time.
Maybe I am spealling FEATURE wrong..should be PIA......
      11-05-2012, 07:25 AM   #16
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
Question. I have the Traffic Anouncement obviously on. The volume gets higher when there is a Traffic Anouncement on the radio, AND you cannot switch /fade that button from F---->R anymore at that moment, 'all' sound goes to the front speakers. This is imo exaggerating uncomfy and useless.
So which button do I push to get back to normal volume/cd HD/iPhone music when that happens?
Or just put the whole TA off, and that's what I cannot find anymore in the menu....
I have the OEM HK set.
Thanks.
Cheers
Robin
