BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > How's your aim? Low Beams pointed in to the ground?
      11-05-2014, 01:46 PM   #1
sdhotwn
Mmmm... Bavarian
sdhotwn's Avatar
2129
Drives: M2 CS, X5 45e, i3, Cayman S
Curious what others think of the low beam aiming on the adaptive headlights. Mine from the factory seems REALLY short. You can see the beam cutoff line on the pavement about 30 feet in front of the car. I can be at a light and parked a car length back and not even hit the bumper with the cutoff lines. Similar for anyone else?
Thanks!
Steve
M2 CS
2023 CB X5 45e
2018 i3 94
2014 Cayman S
      11-05-2014, 01:56 PM   #2
Pauleebe
Pauleebe's Avatar
Drives: Inbetween BMW's.
I'm pretty sure BMW uses really accurate technology to align the headlights from the factor. You have to be careful with making the beam cutoff higher because it can blind oncoming or traffic ahead of you.
      11-05-2014, 01:58 PM   #3
sdhotwn
Mmmm... Bavarian
sdhotwn's Avatar
2129
Yeah, I understand that. I also have adaptive headlights on our X3 with WAY different aim. I'm curious if something is off for some reason. May have the dealer re-check it.
M2 CS
2023 CB X5 45e
2018 i3 94
2014 Cayman S
      11-05-2014, 02:50 PM   #4
umkc
Drives: 2014 335i xdrive M-sport
i complained about the same issue and dealer fixed it( raised the focus angle) without a question, which is odd because its a traffic hazard and can blind the oncoming vehicles, but i am happy because i can actually see at night now.
      11-05-2014, 03:25 PM   #5
cricoid
Drives: '15 435i M-Sport
Mine seem aimed very low too. I typically drive home on a rural two-lane road, and the high beams are pretty much required to see at a safe distance when moving at a brisk pace.
It's especially noticeable after I've been driving my 4Runner for a day or so. Those low beams seem to throw an amazing distance in comparison to the 435.
      11-05-2014, 03:48 PM   #6
sdhotwn
Mmmm... Bavarian
sdhotwn's Avatar
2129
Well at least it's not just me. Hopefully the dealer will adjust it a little bit.
M2 CS
2023 CB X5 45e
2018 i3 94
2014 Cayman S
      11-05-2014, 03:55 PM   #7
Koer
Drives: F15 X5 2014 Sec. 50i
you can adjust them yourself.. just google "f30 headlight adjustment". should be pretty similar to the 4 series.
there are 2 adjustment knobs on each headlight when you open the hood. one adjusts left-right direction and the other up-down.
park your car in front of a wall so you see how much you raise them, remember that every turn is about 8 feet of range in either direction
      11-05-2014, 04:25 PM   #8
sdhotwn
Mmmm... Bavarian
sdhotwn's Avatar
2129
Good to know. If they say they are "fine" then I'll adjust. I have to take it in for a few other quibbles eventually here, so we'll see.
M2 CS
2023 CB X5 45e
2018 i3 94
2014 Cayman S
      11-06-2014, 12:01 PM   #9
rking117
Drives: Z4 3.0i & 320i
I dont know about the F30 but on my E89 each wheel has a sensor that sends a signal to the auto leveling function and the sensors have been known to flip around backwards after hitting a large bump like a speed bumb or something. Once that happens the headlights dont project but maybe a few feet in front of the vehicle. To correct the problem the car has to be raised and the sensor removed and flipped back around so that it sends the right signal to the auto levleing function again. This is a big issue on the E89 forum.
But like i said I am not aware that this issues crosses over to the F30s or not but it is worth taking it in to have them take a look at the sensors. If you find out that it does work similar to the E89 please post your results as this may be one more thing we need to monitor on the F30.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold)
      11-06-2014, 12:54 PM   #10
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
I was noticing the same on my F30. I do have the Dinan springs which lower the suspension another 10mm. But it is a level drop, so you would think that would not cause it.
I find that having the Anti-Dazzle unlocked on the Adaptive Headlights takes care of it though.
F30 Sapphire Black M-Sport 335i 6MT
      11-07-2014, 12:39 AM   #11
wolves
Drives: 2014 BMW 328i
Thanks for posting, I need to do this.
      11-07-2014, 01:11 AM   #12
mvrwdakingtm
Drives: bmw
bmw is cool
      11-07-2014, 06:46 AM   #13
sdhotwn
Mmmm... Bavarian
sdhotwn's Avatar
2129
That's interesting and good to know.
Last night I was following a newer Subaru Forester and it looked like their beam cutoff distance was the same as the 335's.
M2 CS
2023 CB X5 45e
2018 i3 94
2014 Cayman S
      11-08-2014, 11:33 AM   #14
msej449
msej449
msej449's Avatar
Drives: M235i Convertible +LSD 2016
Not sure if this helps, but I initially felt the same until I started to turn on the High-beam Assist and let the forward-scanning camera adjust the lighting dynamically.
This gives you almost permanent high-beam on the near-side (driver's side), which adjusts to the road's curvature left/right.
You then have to get used to the constant adjustment of the ahead and off-side vertical/horizontal throw. At first, it can seem like it's overly 'busy' and is changing the throw all the time (which it is): but after a while you get used to it.
I suppose what I'm saying is that the Adaptive works best in conjunction with High Beam Assist and the relatively short 'throw' isn't a problem when both are working in tandem. I think BMW should really package these together as a single option and give owners a bit more guidance.
      11-08-2014, 12:49 PM   #15
snowghost
snowghost's Avatar
This needs to be coded here in the USA. By default the Adaptive Anti Dazzle is decoded.
      11-09-2014, 08:14 AM   #16
coolguy_y
Drives: 428xi GC
Many times when I am driving I feel like I am getting flashed from drivers behind me only to find out that their lights are set to auto setting and every bump (speed or a pothole or whatever) sets the system to auto correct and level. It's momentarily blinds people driving ahead of you who don't have anti-reflective coatings on either their side view or rear view mirrors.
I feel that high beam assist is not a safe feature for drivers in front of you and for drivers in the oncoming traffic. This can lead to dangerous situations for these folks at the expense of the "auto" feature.
      11-09-2014, 10:26 AM   #17
Prissy
Prissy's Avatar
Taiwan
1065
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
2010 BMW E92  [10.00]
takes 1mins to adjust the aim yourself.
      11-09-2014, 01:45 PM   #18
Jimminez
Jimminez's Avatar
Drives: 2014 F31 M-Sport
^this.
There are two adjustment screws on the top side of each headlight. The ones towards the middle adjust vertically. Follow the guidance in the site linked below.
http://www.danielsternlighting.com/tech/aim/aim.html
Martin
Past - F31 M Sport Estoril Blue - Thread - Pic
Current - 2021 Audi RS6 Avant
      11-09-2014, 11:26 PM   #19
Koer
it's no longer an issue on the f30... i've hit potholes that have broken both the tire and my rim on the rear and my auto level never stopped working. There is a fine line between too high and too low on the low beams, finding the right height might require some nightime driving but its worth it!! after that let the auto level do the fine tuning
      11-10-2014, 01:32 AM   #20
mvrwdakingtm
Drives: bmw
bmw is cool
      11-10-2014, 05:51 AM   #21
Christos
Christos's Avatar
187
Drives: 2019 Z4 s3.0 Msport
Thanks!
Steve
I have felt the same about my 428i since delivery. So many deer on the roads around central Nj, I can't see far enough ahead. High beams are a required more than ever with this car. guess I'll have to google headlight adjustment
2019 Z4 sDrive 30i Msport,
Previously owned BMWs, 2014 428i Msport, 2008 335i Coupe, 2007 328xi sedan, 2002 325i sedan 1996 318ti (loved this little car)
