01-19-2013, 06:25 PM | #2157 | |
Rep 385
Actually, I'm happy to pay the $65 and support the cause. I'm not even going to bother checking iLevel. I'm just order E-Sys patch and token. Thank you. You're the man. |
01-19-2013, 06:27 PM | #2158 | |
Rep 8
interesting
interesting!
01-19-2013, 06:47 PM | #2161 |
Rep 41,150
01-19-2013, 06:52 PM | #2162 |
Rep 490
01-19-2013, 06:53 PM | #2163 |
Rep 41,150
Yes, totally separate from the PSdZData.
01-19-2013, 08:55 PM | #2164 |
Rep 1,027
I AM GOING TO PULL MY HAIR OUT..
After buying my token and testing by coding one setting.. i had to go back and watch my kids. Well now it wont connect to eh car.. NO ZGW AVAILABLE... i didnt change anything. I just closed esys. What causes this?
M Sport Line Estoril Blue
01-19-2013, 09:34 PM | #2165 |
Rep 385
Is the 1 setting you changed with the patched E-sys and new token still coded/working? I imagine it is, just trying to troubleshoot and wondering if I do mine should I do it all in 1 shot first try if it'll stay coded.
01-19-2013, 09:44 PM | #2166 |
Rep 385
John08135i scared me a bit with his problems above with new patch/token so I checked my iLevel. Guess it's official, I can't go back beyond 48.3 and I hope that the patch/token work.
01-19-2013, 09:55 PM | #2167 | |
Rep 490
Extract from installation instruction (from esys 3.18.4) Run "C:\EDIABAS\Hardware\Ediabas-Konfigurator\Ediabas-Konfigurator.exe" and make sure "Interface:" is set to "INTERFACE=ENET". Did you also update the esys program properties to point the token & ods to the right file/directory? Let's just say you had a bad day.... I do sometime fail to get IP from the car, what I did to make sure I ALWAYS get an ip is start the laptop AFTER the cable is connected to the car & computer, and turn on the car (not start engine)... CHECK to make sure your computer is receiving an IP with "limited connectivity" I'll be around for the next few hour... will be heading out to a coding party thereafter, hopefully none of the car will have 505! Last edited by kon; 01-19-2013 at 10:06 PM.. |
01-19-2013, 09:57 PM | #2168 |
Rep 490
01-19-2013, 10:19 PM | #2169 | |
Rep 1,985
Drives: 2020 G20 320i M Sport
How did you end up with that iLevel? Was it when you took your car in for the FEM module recall back in December? I'm helping another forum member code his MY2013 this week so I hope it will be ok with 48.1. |
01-19-2013, 10:56 PM | #2170 | |
Rep 385
01-19-2013, 10:57 PM | #2171 | ||
Rep 385
01-19-2013, 11:50 PM | #2172 | |
Rep 1,892
Did you try just running ZGW_SEARCH.exe and see if that will read your VIN? I don't think that program accesses the ODX or token (can anyone verify?), so if that won't connect, then you have a cable problem, the car ignition wasn't on, or you didn't get into DHCP fallback mode. |
01-20-2013, 12:51 AM | #2173 |
Rep 84
hi guys, at first i have intermitten problems connecting my cable direct with my windows machine. Until when I installed http://www.dhcpserver.de/dhcpsrv.htm into my windows and make it as DHCP server. Ever since, connection is very smooth.
01-20-2013, 12:56 AM | #2174 | |
Rep 490
01-20-2013, 02:43 AM | #2175 |
Rep 41,150
I am not sure what the issue is with the connection problems. I have messaged Andy, and hopefully he can figure it out.
01-20-2013, 02:45 AM | #2177 | ||
Rep 41,150
I don't see how a DHCP Server utility will help.
01-20-2013, 02:47 AM | #2178 |
Rep 41,150
Ok. Hopefully you are correct.
John can try it and confirm if it works.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-20-2013 at 02:56 AM.. |
