07-31-2014, 08:36 PM | #1 |
Rep 145
F30 Audio Upgrade Question: Tweeters
Hi guys,
I've been researching the forums for information on how to upgrade my 2014 320i Hi-Fi system, which sucks (My 2008 Golf sound is 10 times better!). So, I'm leaning towards Technic's recomendation for harness and JL XD600/6 amp. And considering Bavsound to replace the stock speakers. My question is (forgive my ingnorance) about the tweeters: Where are the tweeters located? In my Golf they are inside the window frame, inner corner of the exterior mirror assembly. But my BMW doesn't have any grilles or little speakers there... Does it mean that I don't have tweeters? Or, are they located somwhere else?
2018 X3 30i / Alpine White
08-01-2014, 08:32 AM | #2 |
Rep 253
I have a 335i with the base sound system. I added a good amp and sub by kicker L7. Amazing sound and forget about changing the speakers, add a sub and you'll be just fine
08-04-2014, 06:55 PM | #3 |
Rep 145
Thanks Marckymarc for your advice !
08-04-2014, 11:05 PM | #4 |
Rep 1,739
The tweeters are in the corner, the same place as your Golf. If you don't have any then you may have the 6 speaker system. In the US, all the 2014s come with the tweeters.
08-07-2014, 03:23 PM | #6 | |
Rep 12,999
Your system is Stereo (BMW name). My harness + XD600/6 is for the HiFi system.
08-07-2014, 07:58 PM | #7 | |
Rep 145
Would you have a harness suitable for upgrading my system? Thanks!
08-08-2014, 12:54 AM | #8 |
Rep 12,999
08-08-2014, 05:35 PM | #9 |
Rep 145
Thank you Technic for the link !
Tmar has done a lot of work: Removed the head unit, wiring and adding two pieces of equipment. Is there a more direct, "plug and play" option for upgrading just the base amp? Kind off what you showed for the Hi-Fi system, without having to remove stuff from the dashboard and do any wiring...? PS: Just checked the trunk and I have an empty space where the Hi-Fi amp goes. Is that why IŽll need to run a harness from the front to the back, so I can connect the new amp?
08-08-2014, 09:34 PM | #10 | |
Rep 12,999
Your system is NOT HiFi: http://f30.bimmerpost.com/forums/sho...44&postcount=6
08-09-2014, 12:05 PM | #11 |
Rep 145
Understood. I'm not an audio expert and I'm trying to understand what are my options given that I have the non-Hi-Fi equipment...
There's a lot of detailed info on the forums about upgrading the Hi-Fi, not so much for the base stereo.
08-09-2014, 02:20 PM | #12 | |
Rep 12,999
It is OK if you do not understand how to upgrade your system. What that really means is that you require local professional install. |
