11-17-2015, 07:32 AM | #23 |
Rep 32
11-17-2015, 02:04 PM | #24 |
Rep 1,122
11-17-2015, 02:06 PM | #25 |
Rep 1,122
My cruise shows in miles, but I also never tried to code it. Didn't bother me since everything else is in km/h (HUD speed)
11-17-2015, 02:08 PM | #26 |
Rep 32
Interesting. So far it seems like people that have our issue all have H/K. I'm still reading up on it, hopefully I can figure out what's causing the issue.
11-18-2015, 03:51 PM | #28 | |
Rep 2,108
ANZEIGE_FREQ = nicht_aktiv With regards to how the stations are now sorted, this is normal once you change radio country to ECE. Even Euro-spec cars from the factory have their stations sorted alphabetically.
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
01-28-2016, 04:56 AM | #30 | |
Rep 75
a good intro is here https://www.bimmerfest.com/forums/sh...s+to+km&page=2 suggest to check Russian forums..they seem to be a bit ahead on these things sekmes
bmw 428i (us->eu)
10-13-2017, 09:30 AM | #33 |
Rep 43
hi there.
Can you pls help with detailed manual with adding languages to US F30 (likely, Russian), step by step - what parameters in what modules should I code? Last edited by spudvti; 10-13-2017 at 09:51 AM.. |
10-13-2017, 03:54 PM | #34 | |
Rep 2,302
6UD is the equipment number for russian language. |
spudvti8.50 |
10-16-2017, 11:54 PM | #35 |
Rep 43
10-31-2017, 12:50 PM | #36 | |
Rep 43
should I remove some US codes (if are so, like I've added 2TB instead of 205), or just add 6UD, like I've added 3AG option in VO coding menu? |
11-21-2017, 09:13 AM | #38 |
Rep 43
11-21-2017, 03:59 PM | #39 | |
Rep 2,302
It's like a list of languages. If you code the 6UD, the master language will be russian, but you can select other languages in NBT. If you code the 853, the master language will be english_UK and you can select other languages in NBT. |
11-25-2017, 05:41 AM | #41 |
Rep 43
well then, there were Errors, mapping that there are few language packs, so you MUST delete other language options while adding other!
Thank, all works with 6UD (it contents Primary Russian with English, German, and many others) |
01-19-2018, 01:40 PM | #42 |
Rep 2
can anyone help me with US -> ECE conversion? car is 2015 year, on FA changer type to ECE and national version to German, code all car, and got lots of errors "Coding does not match car equipment" and front fog lights error on FA no fog lights. It there needed any wiring modifications?
03-07-2018, 05:28 PM | #43 | |
Rep 30
That post looks pretty tough (flashing EEPROMS)! - is there an easier option for coding this at all? Thanks |
07-19-2018, 05:42 PM | #44 |
Rep 7
Hi, I have question related to car from USA in Europe.
What is the trick to update NBT maps (NBT_K15072A) from US to EU? (none of the FSC keys generated wasn't working for 2018-1, 2018-2 version of Next maps. Thank you. |
