BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > seats electric bmw F30
      03-25-2022, 08:48 AM   #67
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by Redluaf1 View Post
Hi can someone help me please I've got a bmw f30 2014 with manual heated lumbar support seats and I'm wanting to fit f80 electric memory seats has someone got any pictures of the wires I need to add please
I sent you a message
      03-25-2022, 08:51 AM   #68
Redluaf1
Drives: Bmw f30
Hi david51 it has not come through
      03-31-2022, 09:23 AM   #69
M.CSL.GT3
Belgium
Drives: BMW F30 2012
Replied per email
      03-31-2022, 05:23 PM   #70
william48151623
Drives: BMW F30
Thank you!
      04-09-2022, 04:11 PM   #71
Goodstegosaurus
Drives: BMW M140i
Hello
Would you mind sending me the wiring diagram too please?
Looking to put some F80 M3 seats into my car and will need the electric adjustments to be wired/coded in
Thank you in advance!
      04-11-2022, 10:53 AM   #72
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by Goodstegosaurus View Post
Hello
contact Mp
      04-11-2022, 06:03 PM   #73
Goodstegosaurus
Drives: BMW M140i
contact Mp
I Don't appear to have received it? Or I can't seem to access my messages.
I'm assuming because my account is so new. Is there any other way you can send it please?
Thanks
      04-11-2022, 06:08 PM   #74
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thanks
kelkiff@msn.com
      05-18-2022, 03:02 AM   #75
hitehite
Drives: BMW F30
Hi everyone,
I have a 2013 320i with manual seats. I bought f30 power, heated, memory seats and a 2013 f30 climate control module with heated seat buttons. How do I install and wire the seats?
I also have Ista and Esys on my laptop which connects fine but I don't know how to code it yet. Can anyone please help??
      05-23-2022, 04:21 AM   #76
hitehite
Drives: BMW F30
Can anyone help? Do you have wiring diagram?
      05-23-2022, 07:51 AM   #77
david51
david51's Avatar
France
538
Drives: bmw M3 F80
kelkiff@msn.com
      07-11-2022, 07:23 AM   #78
yuwhehe
Netherlands
Drives: BMW F30
Hi David, please be informed that I sent you an email about this topic today.
I would appreciate it if you could reply.
thanks
      07-11-2022, 08:40 AM   #79
david51
david51's Avatar
France
538
Drives: bmw M3 F80
thanks
      07-12-2022, 01:49 AM   #80
yuwhehe
Netherlands
Drives: BMW F30
received safely
Thank you David.
      07-14-2022, 08:03 AM   #81
david51
david51's Avatar
France
538
Drives: bmw M3 F80
received safely
Thank you David.
      10-09-2022, 09:35 AM   #82
jlexandr
Drives: BMW F31
Hello
almost the same story for me
BMW F31 2018 with heated seats.
I bought electric seats, installed them, and got no reaction to any control elements.
I've coded all blocks with SALAPA-Element 459 and got the same absence of result plus a lot of errors in ISTA like a bonus
Now electric seats don't work, the seat heater works only for the passenger, and there is no reaction to other control elements.
I've checked the fuse block under the hood fuses related to the seats, and that's ok
Under the driver seat, I have white block OE 61.35 9 354 457.9 Date: 11/07/14
I'm stuck. Can anybody help me with that?
      10-09-2022, 09:46 AM   #83
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by jlexandr View Post
Hello
the seat module is well detected on E_sys ?
my mail kelkiff@msn.com
      10-09-2022, 10:03 AM   #84
jlexandr
Drives: BMW F31
I don't know how to check. Could you please direct me?
Originally Posted by esi183 View Post
As a clarification, for error (2), what I mean is I already had the VO code of 494 (heated seats) for my manual heated seats.
When I then VO coded the car with 459 after installing electric seats, it seems like this didn't stop the REM searching for the old LINbus module on the driver side.
Solution as above; VO code 459 (electric memory) to all ECUs -> remove 494 from VO (but keep 459) and code REM only -> add 494 to VO and code REM again. Solved error for me
Also, I have tried solutions from esi183 but it doesn't help me
      10-11-2022, 04:01 PM   #85
david51
david51's Avatar
France
538
Drives: bmw M3 F80
MP:
      01-23-2023, 03:06 AM   #86
birolori
Drives: F31 320xd
Hello
if anyone can help me, it would be much appreciated.
I have a 2016 F31 LCI with base heated, and with electrical lumbar support, but manual seats.
I would like to switch to full electric memory heated sport seats. I think the seats also come from an LCI model.
Can you help what coding and additional wiring I need?
david51 can you help me please? thank you very much.
      01-23-2023, 05:49 AM   #87
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by birolori View Post
Hello
contact me on my email
      02-06-2023, 01:23 AM   #88
spoilerbrake196
Drives: BMW 335i xdrive
Hey
I have a 2015 BMW 335i xdrive base model ( base model seats heated+ particial electric+ memory). I picked up m sport seats from a 340i (lumbar support+ side bolster+ heated+ memory). All I did was swapping the seats and belt tensioners and also my driver seat gray box Module from my car , everything works EXCEPT SIDE BOLSTERS AND LUMBER SUPPORT. It really sucks because I was so excited once the seat moved automatically and heating worked. Anyone had the same situation or know what do I need to do
