06-14-2015, 11:17 AM | #1 |
Rep 40
BMW F30 Instrument Cluster Color
06-14-2015, 11:37 AM | #2 | |
Rep 1,894
VALUE: DIM_NACHT_EIN DEFAULT: werte = 32 NEW: werte = FF Changes orange night colors of KOMBI to be white at night (No Navi Night Switch too). I'm guessing it also does the same when the lights come on in tunnels etc etc. |
06-14-2015, 12:37 PM | #3 | |
Rep 40
I will try it and inform, My car's currently values like following, Also there is a KOMBI, 3007, DIM_NACHT_AUS, Activ Werte = 36 Do you know that What does meaning the DIM_NACHT_AUS? |
06-14-2015, 01:12 PM | #5 |
Rep 40
06-14-2015, 02:53 PM | #6 | |
Rep 40
I saw the below after coding, Aktif changed to UNKNOW, Before code Aktiv Werte=08 After code UNKNOW Werte=FF Because of this , I have changed back coding. Do you have any suggestion? Thanks, Last edited by bryan06; 06-14-2015 at 03:54 PM.. |
06-14-2015, 05:27 PM | #7 | |
Rep 1,894
Did you FDL code and save it, see if it works? Worst case is just back it out afterwards. |
06-14-2015, 07:21 PM | #8 |
Rep 817
Drives: bmw M3 F80
hello
I made the change on the counter here's how http://f30.bimmerpost.com/forums/sho...1027008&page=2 |
06-15-2015, 01:24 AM | #9 | |
Rep 40
Coding was OK, but not change the color. Thanks again. |
06-15-2015, 01:27 AM | #10 | |
Rep 40
I have readed your post and I saw that This feature requires hardware changes. So we can not change the color with any coding, right? Thanks, |
06-15-2015, 05:28 AM | #11 |
Rep 817
Drives: bmw M3 F80
06-15-2015, 09:02 AM | #13 |
Rep 1,573
no need to try coding. Changing the color on the speed/tach requires changing the LEDs (hardware).
the only thing you can code is the screen below it
2015i Cadillac Escalade ESV
06-15-2015, 09:32 AM | #14 |
Rep 40
Yes, my lcd screen is white in day and it's orange in night. this means that we can change color of lcd with coding.
06-26-2015, 04:57 AM | #16 |
Rep 931
led, hardware replacement
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
10-01-2015, 02:04 PM | #18 |
Rep 1
anyone figured how to fix this?
11-26-2015, 04:54 AM | #19 |
Rep 37
Hi Everyone,
Can you indicate the posssible coding for the LCD (at the bottom of the tachi). This coding: ECU: KOMBI [3007] VALUE: DIM_NACHT_EIN DEFAULT: werte = 32 NEW: werte = FF Does not change anything on mine (still orange at night) Thx! |
11-26-2015, 09:29 PM | #20 |
Rep 185
Drives: 2017 X3 35i X Drive M Sport
If you read the posts in the thread you will see it was determined that the actual LEDs have to be changed.
11-30-2015, 05:39 PM | #22 |
Rep 1,799
This is impossible to do as there are only orange LED's in the instrument cluster so no amount of coding can turn them white. You need to replace them with white LED's.
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
