BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Real world MPG?
      05-06-2014, 06:58 PM   #507
alpinweiss 335i
alpinweiss 335i's Avatar
Drives: '13 f30 335i 6MT M-Sport
2013 f30 335i  [5.00]
2012 e92 M3  [5.00]
2013 f30 335i  [4.75]
2006 e90 330i  [5.00]
2003 e46 330xi  [4.00]
335i, 6MT, xDrive. No mods. Mix city and highway driving.
Average 22-23 mpg. Average 300 mile tank range.
e46
e90
f30
e92 ///M
f30
alpinweiss 335i is offline   United_States
      05-07-2014, 09:20 PM   #508
RPM90
Drives: 335i Msport w/sport AT
Originally Posted by ft1330 View Post
In my 335i, I get about 20 US MPG when driving "normally" and 38 US MPG in Eco Pro on the highway driving the speed limit and like a grandpa (extremely boring).
In Eco mode you can't but drive like a grandpa.
I NEVER use that mode.
I use sport mode about 95% of the time.
My fuel efficiency is regulated mostly by my right foot.
It's been really cold still in the Chicago area and my tires are running at lower psi than what I set them at. I last set them when it was around mid 70's when we got a warm spell. Set to 40psi rear and 39psi front.
But, since the temps have been in the mid 50's psi has been lower.
Current MPG is averaging 25.5 mathematically calculated.
When temps go up I get about 1mpg better.
Dip into the power of a 328i or 335i and watch that number drop, and considerably if you continue dipping.
For typical day to day driving 328's and 335's are both producing about the same power demand. Weight difference between equally optioned 3's is only around 110-120lbs. Can't cheat weight to power, and there is no magical way to cheat that. Driving either variant in the same low to moderate power production is going to use about the same amount of fuel.
328i will do a little better, it's a bit lighter.
Driven hard and using the 335i's greater power is going to result in lower MPG obviously as you're calling on the engine to produce the greater power it's capable of producing.
IOW, producing the full 300hp/300lb ft. is going to require more fuel compared to producing 240hp/255lb ft.
On the highway with both cars moving at the same steady state speed, they're both going to require about the same power and will burn about the same amount of fuel. Note, not exactly the same, but pretty darn close.
There's likely more MPG variance among 328i's driven mostly city and mostly highway then there is between 328i and 335i as a group average.
The EPA MPG testing reveals that.
RPM90 is offline
      05-10-2014, 08:31 PM   #509
ny176
ny176's Avatar
Drives: F32 428xi
My 14' F32 428 xi has 1750 miles, today I hit 27.4 mpg with mixed city/highway. I miss the power of my 10' N54 engine but I love the seeing my mpg go up on a weekly basis. I averaged 21.1 mpg on the 10' 335 xi. Plus when switching to sport/sport +, I'm pleasantly surprised of the power this 4 cylinder turbo engine puts out.
Current: 2014 F32 Jet Blk 428xi
Past: 03' X3 2.5i, 07' sprk graphite E92 328i, 10' Blk saphire 335xi
ny176 is offline   United_States
      05-11-2014, 04:37 PM   #510
dude987
Drives: BMW 335i xDrive M-Sport DHP
The Real Deal F30 335i xDrive MPG
Actual milage and MPG recorded from the gas pump. Averaging 24.3 MPG for the life of the car with over 27,000 miles on it. Currently live in Germany and excessive triple digits on the autobahn derpesses the MPG. Can easily get 33 MPG with easy 80 MPH.
dude987 is offline   Germany
      05-12-2014, 08:54 AM   #511
sportlineguy
Drives: none
These are from a trip from Nashville, TN to Raleigh, NC and back- up through the Smoky Mountains and Ashville and back down - amazing what this 328i can do! This was with the AC on and cruise set - and does it really pull going up hill - passing is effortless!
Sport seats make a difference - but still after 8 hours need to get out and stretch!
Why buy a hybrid - possibly a diesel to get these numbers.
sportlineguy is offline
      05-12-2014, 09:19 AM   #512
chiefneil
Drives: 335i M Sport
Average speed of 68 over an 8 hour trip? That's damn good time; did you even stop to eat?
Anyway so far my overall average is 24mpg at an average speed of about 34mph in my 335i auto. Roughly 5k miles on the clock so far.
I suggest people posting their mpg also post their computer-indicated average speed, that's probably the biggest factor in gas mileage.
chiefneil is offline   United_States
      05-12-2014, 10:28 AM   #513
300hp
Drives: X5 & 335xi
You can also try this. You can then calculate your average OBC mpg from here. Mine indicates 25.6mpg over those 1000 miles. 70% city, 30% highway.
335i xdrive with 335hp and 19" staggered summer tires.
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs
Deep Sea Blue Metallic 2013 X5 35d Sport
Prem, Convenience, Cold and Premium Sound packages
300hp is offline
      05-12-2014, 11:44 AM   #514
kent11202
Drives: 2013 328i
328i Luxury. Round trip 103.2miles, 34.2mpg avg., 50.1mph avg., grandpa mode (eco), cruise control 65mph.
Elevation change 1300 feet to sea level and back. Home to sea level location was 38.8mpg. Mileage would have been much better on return trip but good old CA freeway moving at about 20mph for a big part of return trip killed overall mileage.
No complaints about mileage at this end of the world.
kent11202 is offline   United_States
      05-16-2014, 09:27 AM   #515
yashart_330
Drives: 330xi
Silly question, but does anyone know if the "miles gained" in Eco Pro mode are per tank? Or is it per gallon?
yashart_330 is offline
      05-16-2014, 10:27 AM   #516
hollandog
hollandog's Avatar
Drives: 2013 328i xDrive M Sport
NYC mileages.
2013 328i xDrive M Sport 8AT Alpine White
hollandog is offline   United_States
      05-16-2014, 10:30 AM   #517
Powaup
Powaup's Avatar
Drives: 6MT F82 M4
2015 BMW M4  [5.00]
My parents get 20 mpg on their 428 they live in the middle of LA that's probably why and zf8 speed.. this car is just so freaking nice oh and 4200 miles so far
CSUN 2013 17/80 @ FSAE West Lincoln, Nebraska
Powaup is offline   United_States
      05-16-2014, 11:36 AM   #518
rjpeaks
rjpeaks's Avatar
Drives: F30 335i M-Sport 6pd
anything over the 13MPG i got on my last car is great.
right now ~23MPG
335I M-Sport 6spd EBII MPPK MPE DHP HK PDC ZTP ZPS ZPP ZDA ZPK 802.11ac ABC123
rjpeaks is offline   United_States
      05-17-2014, 06:50 AM   #519
Bluelondon
Drives: 2014 428i M
I average anywhere from 19-21mpg. Is this normal for a 428i? Although I'm still in sport mode 90% of the time.
Same. Didn't expect this much zing from a 4 cylinder.
Bluelondon is offline
      05-18-2014, 11:24 AM   #520
CK335iMSport
CK335iMSport's Avatar
Drives: 2014 335i M Sport
2014 335i M-Sport, MPE, 8AT city/hwy (70/30) = 21-23 MPG avg.
Comfort Mode = 60%
Sport Mode = 40%
2014 335i M Sport - Mineral Grey/Coral Red, Nav., Premium, HK, MPE, 8AT. Mods: 20" Velgen VMB5 Gloss Black Wheels on Hankook's, Bilstein B8 Struts/H&R Sport Spring combo, AFE Magnum FORCE Stage 2 Intake, M-Performance black kidney grilles, IND Distribution color-matched reflector inserts and key hole cover.
CK335iMSport is offline
      05-19-2014, 08:23 AM   #521
JesseSRQ
Drives: 2013 328i Sport Line
Did a drive with four people across the state of Florida yesterday. I averaged 37.5 MPG taking secondary roads, including plenty of passing. Now to clean off the love bugs. . .
850 T-5 | Golf III | Golf MK4 | Jetta MK4 | TSX | S40 T-5 | C230 | TSX Wagon | F30 328i
JesseSRQ is offline   United_States
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
