11-05-2014, 08:33 PM | #23 |
Rep 1,772
Experiencing same. Car also feels underpowered.
Had it looked at, no codes but dealer changed all 4 injectors. Helped for a little while but back again after only driving 1k. The dealer cars I've driven just feel so much faster. It's real frustrating as I know I'm not imagining it but dealers only go by codes thrown. If no codes there is nothing wrong with your car. Really need to put this thing on a dyno and see if I can get something to back me up. I had a loaner 125i and that thing was awesome. No lag, quick to rev to redline and just felt noticeably faster than my 328 |
11-06-2014, 05:19 AM | #24 | |
Rep 3
11-06-2014, 05:50 AM | #25 | ||
Rep 1,772
11-06-2014, 09:11 AM | #26 | |
Rep 3
http://www.bimmerfest.com/forums/sho...d.php?t=590791 |
11-11-2014, 03:31 PM | #27 |
Rep 540
Drives: 22 G05, 22 G26
Have you tried a different brand and grade of gas?
07-14-2015, 12:04 AM | #28 |
Rep 577
@Dippydo have you seen this thread.
There seem to be various potential culprits, but reading the link posted above it seams a boost leak may be a candidate too. |
07-14-2015, 10:45 AM | #29 | |
Rep 577
Can you tell us how you cleaned your PVC valve?
I would like to give this a clean. I've cleaned my MAF and will run a tank of injector cleaner. Quote:
07-14-2015, 11:57 PM | #30 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Pc valves are easy to swap in some cars. Not sure about our BMWs though....
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| Last edited by CalCarNut; 07-15-2015 at 01:49 PM.. |
07-15-2015, 12:12 AM | #31 |
Rep 308
Is it possible to use fuel injector cleaning method (filling up tank with BMW fuel system cleaner plus and speeding) to get rid of carbon build up for Direct fuel injection system. N20)?
I read from somewhere that this method doesn't work for Direct fuel injection system.
F30 328i sedan
07-15-2015, 09:26 AM | #32 |
SPEED RACER
375
Rep 740
Try doing the italian tune up. Run your car in manual and keep the rpms around 4000 rpm and drive for 10 mins like that. It should sort out the hesitation. Also reset the accelerator pedal by putting the car into accessory mode and fully depressing the accelerator pedal past the click point and then hold it for 30 secs. Turn the car off and then start the car it should also help.
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black |
07-16-2015, 11:50 AM | #33 |
Rep 577
I thought the PCV may have something to do with this hesitation. However I just read the section (pages 18-24) in the technical training doc (http://www.bimmerpost.com/goodiesfor...BIMMERPOST.pdf) and it turns out the PCV is not active during boost. it is bypassed. So doesn't look like the PCV could be playing a part in hesitation in the zone we are all experiencing it in (3000rpm - ie boosted)
07-23-2015, 08:09 PM | #34 | |
Rep 7,047
There are conditions that can contribute to combustion chamber environments where knock can rear it's ugly head at higher levels and greater intervals. High ambient temps. Lean atmosphere, such as higher elevations. Heavy load, such as climbing hills, pulling weight, etc. Lean air/fuel mix caused by dirty fuel injector, low fuel pressure, or some other fuel restriction. Lower octane fuel. Combinations multiply the potential. Make sure you are using the proper octane rated gasoline. I've experienced fuel cut and hesitation on hard accel in turbo engines due to air leaks in the air charge pipe/turbo pressurized air. It's also possible to have a faulty knock sensor. It might be overly sensitive, or it may have electrical problems sending out intermittently errant signal to the ECU indicating knock when there isn't. You can try fuel injector cleaner if you have high mileage. But, if you don't have over 50K or more miles I wouldn't go there right way. Still, a bottle of Techron isn't that expensive to try. Modern ECU's data log a good amount of information about what the engine is doing such as throttle input, boost pressure levels, fuel amount, air/fuel mix, spark events including misfires, knock sensor events, etc. Take it to a BMW tech who can hook it up to BMW's ECU readers. That's where I would start, once the bottle of Techron doesn't work. |
07-23-2015, 10:58 PM | #35 |
Rep 577
Thanks for this @RPM90.
I have tried the Techron, but that unfortunately wasn't the cure. I only have 10k miles so it was a slim chance as you noted. From my review of the data I logged (unfortunately I didn't log Knock) it seems as though the engine dumps boost and within a split second also pulls timing. At least that's what I can tell. I'm on V-Power 93. so don't think its the gas. I've gone to various stations and it hasn't changed the result. As the local ambient temp has moved up to 100F here in TX it really has started to stutter more. Even with my larger Stepped Core ATM FMIC. So I've put together a Intercooler spray setup so that I can evaporatively cool my FMIC and charge for heavier pulls. I expect to reduce my IAT from the 107F I'm currently getting to closer to 90F when the FMIC is sprayed. I do still suspect that I have a boost leak, even though I've tried smoke testing (found no leaks), I don't think it shows enough at low pressure (1PSI test) because I couldn't find a leak. That said there are several reports of blown or leaking plastic charge pipes at higher than stock boost. So I have the ER Charge pipes and will be installing them next week. I'm willing to bet the leak in the stock chargepipe I have, only gets big enough to cause the ecu confusion as boost gets over 15PSI. So fingers crossed the ER pipes fix the issue. I've also already installed my DV+ from GFB so that I can rule the DV issue out. One other thing I'm going to try is the colder S55-M3 spark plugs, as there have been some reports that the hotter N20 plugs don't like the conditions brought on by the tune. Both engines use the same coils, so only have to change the coils. Those are going in this weekend too. I'll report back what I find. |
11-28-2015, 09:26 AM | #36 |
Rep 7
Has anybody got anywhere with this? I have a '15 320 with the BMS JB4, and it was sort of noticeable before(without the tune) but with the tune I find it much more likely to happen.
Unfortunately it's not intermittent for me...picture this. 3500 RPM, holding revs, say going through a corner in Sport+ Manual mode, then I punch it...it's almost like it coughs. No CEL or anything like that but I can hear the diverter valve opening and closing like crazy, then all at once it clears up, I get full boost and away I go. It's repeatable without fail each and every time. Only mod is the tuner, but as I stated, I can deactivate the tuner and it still does it, just to a lesser degree...less boost. |
12-08-2015, 11:44 AM | #38 |
Rep 52
I had the exact same symptoms when I replaced the spark plugs on my 328. Turns out, one of the plugs was bad. Once I replaced the plug, everything went back to normal and I've had no issues since.
07-07-2017, 04:54 PM | #39 | |
Rep 403
01-23-2018, 06:08 PM | #40 | |
Rep 1
when i continue to build up speed in 3th, 4th or 5th gear, the RPM drops from 5K to 3K RPM instantly! even though i am flooring the throttle. And i'm not talking about shifting, it's really accellerating in gear . sometimes it only goes up to 3,5K or 4K RPM and drops slightly, sometimes it goes up to 5,5K RPM without any troubles. on that point i shift. When the RPM drop i can feel the reduction of speed in the entire car. I will try to clean all the filters and systems. |
01-23-2018, 07:50 PM | #41 | |
Rep 96
I had the same issue when my car was stock and had the JB4 installed. Under initial heavy load the car would bog down and sputter. In my case, I changed the spark plugs and replaced a leaky fuel injector and the problem went away. In general, for turbo cars running high boost, you should make sure to have colder iridium plugs; which should be gapped to prevent pre ignition, misfiring, sputtering etc.. It really helped in the initial setup of my car. I’ve also noticed 90C is optimal for water and oil temps in the N20. You’ll see similar symptoms of sputtering and misfiring under heavy load if engine temps aren’t optimal. As @Stubok mentioned above, IAT’s shouldn’t be ignored either and temps above 55-60C WOT should be monitored. Intercooler, Meth can help also. Last edited by take1step; 01-23-2018 at 08:04 PM.. |
01-24-2018, 06:48 AM | #42 | |
Rep 327
I currently have my spark plugs gapped to .022 and the car seems to run pretty good even on Map2 (Cold enough here in TX). I will be looking to get an intercooler before summer hits.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
