06-29-2016, 12:57 AM | #1 |
Rep 173
335i fuel
So I use she'll v power nitro or Petro Canada 91 as there 2 closest to my house. On the filler cap it says 91 recommended and max 10% ethanol. Is this same for other vehicles. So according to Petro Canada website there ultra 94 has max 10% ethanol. So would this be ok for my car or should I stick with the 91. I'm a few weeks/months from getting a jb4 with catless downpipe. Would the 94 with 10% ethanol be better to run then it should I stick to 91. Just wanted some feedback as a product advisor from burger tuning said with the jb4 I should stick to using 91. Are our engines quite fuel sensitive
06-29-2016, 08:10 AM | #2 | |
Rep 6,990
06-30-2016, 08:10 PM | #3 |
Rep 153
You can use 94 octane if you want, but you won't get anything beneficial out of it (just a lighter wallet). Save your money and use the 91 octane. And regardless of whether or not you use 91 or 94 octane, do not use any fuel with more than 10% ethanol.
Basically, do what the owner's manual (and fuel cap) tells you to do. |
07-01-2016, 06:41 AM | #7 | |
Member
458
Rep 1,517
Not sure who you spoke to at Burger but I don't think they would recommend using 91 instead of 94. The fuel requirements for both should be very similar. For higher boost levels you can run 100+ octane with no issue. The lower octane you run, the more timing and boost will be pulled. The only time fueling becomes an issue is when adding ethanol. Then engine will love more than 10% ethanol but the fuel pump is the weak link.
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
07-01-2016, 09:58 AM | #8 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
The JB4 will love 94+10%. An early dyno with mine just the JB4 & 94 produce 370whp. Octane - you don't need anymore than the car can use. Car will run quicker on 94 than 91. A dyno should show at about 12/15whp with just the gas swap over 91.
Our standard premium in NC is 93. Used to mix 93 & 100 to raise the number as the tune got more aggressive. Logs of engine performance showed the effect of the change. Higher octane, no timing pulls, higher boost levels, no throttle reductions. MPG - had no real interest so I can't comment on it. It should be better due to running with more advance timing but a lot is the result of where & how you drive. Probably no advantage in city stop & go. Should show up over the road at speed.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 07-01-2016 at 09:26 PM.. |
07-01-2016, 08:47 PM | #9 |
Rep 173
Thanks, I spoke with Aldo at burger tuning who's email is shown for product advise or something. So while stock as it know even tho has mppk I will carry on using 91 and when I get the jb4 and downpipe I will go to the 94.
Secondly I understand shell v power nitro has no ethanol so when I have the jb4 will it be better to use Petro Canada ultra 94 which has 10%ethanol rather then v power nitro |
