BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > BMW M Performance LSD for 335i and 435i. Pricing and Technical FAQ.
Studio RSR
      10-01-2015, 01:55 AM   #67
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
Originally Posted by JT50 View Post
As for doing the swap myself I think I've got that covered (see pic) Use to work as a Mechanic for a living and I've acquired various specialty tools doing various mods on German cars over the past couple years So I think I can handle it
So did I, 30y ago :-) Worked on BMW for 5y.
They are in SB /CA and listed as Birds Dealer.
http://www.hpashop.com/Quaife-LSD-BM...-Automatic.htm
They have just listed the LSD for the Auto as far as I see.
But Birds in the UK http://www.birdsauto.com/ is distributing/shipping the Quaife worldwide.
Quaife would have LSD for all Models (Auto/Manual)
http://www.birdsauto.com/quaife/sear...mw&s=30180&mi=
Maybe HP Autosport can order it for your car.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
      10-29-2015, 05:15 PM   #68
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
Originally Posted by shivaswrath View Post
I have it with PPK right now.
The transmission would probably give before the LSD.
Am I the only one confused and concerned that the ZF8HP45 transmission us automatics have has a torque limit slightly less than stock torque on an MPPK tuned N55?
I don't have MPPK but I'm tuned Dinan S2 so my torque is way above the limit, and since I plan to add a flash tune, meth, and Pure S2 turbo in the future, I can't imagine the transmission will last very long.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      10-30-2015, 08:11 AM   #69
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I'm concerned too! But so far haven't had any slippage...it's been 1k on 400r+, so only time will tell!
SOLD: 2012 335i Mineral Gray
      10-31-2015, 04:23 PM   #70
Feddersen
Feddersen's Avatar
Denmark
451
Drives: X1 xDrive25i
Check this out. Looks like the LSD is coming for the manual transmission now from BMW.
It has part number: 33108659988
http://www.etk.cc/bmw/EN/search/sele...CE/33/33_1890/
      10-31-2015, 06:03 PM   #71
cryptocar
cryptocar's Avatar
Does Quaife offer LSD for xDrive? Or any other manufacturers? I really hope someone starts making them soon if it's not out there already. That would be such a fantastic handling experience. I'm loving my Dinan springs so far along with shockware, and when Bilstein adapts the B16s for F30 with EDC that would be beautiful. I'm not sure they will but since they have it for the F8X now and it's a very similar chassis to the F3X I think they could with only minor engineering changes.
      11-02-2015, 08:55 AM   #72
Krelle
Denmark
90
Drives: M2C
From my last correspondence with James from Bird's Garage:
James Bird [mailto:james.bird@birdsauto.com]
Exchange diff 2013 xdrive
We do indeed, the price will be the same as it was for your LSD. We have the exchanges in stock and ready for both the manual and automatic versions.
Tell him to email me with his VIN if he'd like an offer.
All the best, James
So, send James the VIN..
Good luck,
/Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
      11-03-2015, 01:35 PM   #73
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Quaife installed on my car today. Have to go out for a drive soon.
      11-04-2015, 06:50 AM   #74
Krelle
Denmark
90
Drives: M2C
You would like the DSC buttom to be overrided at all times
      11-04-2015, 09:14 AM   #75
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
Yes i always have it fully off now and i do like it very much
      11-04-2015, 11:54 AM   #76
cryptocar
cryptocar's Avatar
Doesn't it [DSC Off] change throttle and steering settings to comfort though?
      11-04-2015, 11:25 PM   #77
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
Yes for the throttle part not for the steering wheel. I always hated sport throttle anyways. Always drove dsc off. Most easy to modulate the throttle.
      11-05-2015, 10:12 AM   #78
cryptocar
cryptocar's Avatar
What exactly is the difference in the throttle, I've never run logs of what the sport settings change. Personally I think I like the sport throttle better.
      11-05-2015, 11:30 PM   #79
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
In sport throttle your 0 to 100% throttle is reached over just 20% of pedal length.
In comfort you have to use full 100% pedal length.
I find it a lot more convenient to play with 100% pedal length than 20%. But thats personal preference
      11-11-2015, 06:21 AM   #80
Polo08816
Drives: 2014 335i M Sport
So the install specifies about 1-2 hours of labor. Anyone know of a DIY guide for this?
      11-12-2015, 02:36 AM   #81
Krelle
Denmark
90
Drives: M2C
You'll be in need of the bmw puller, a lift and the lifting/holding device to hold the diff. which is quite heavy.
You need an extra guy when you loosen the diff.
1-2 hours is not enough unless the car is brand new.
Don't forget to buy 2 ltr., (min. 1,2 ltr.) of Titan Sintopoid 75w90 fully synthetic gear oil. (some other oils are approved..).
/Krelle
      11-12-2015, 07:08 AM   #82
Polo08816
/Krelle
Not sure what the BMW puller is but I have access to a lift, air tools, and a transmission jack.
I'm leaning towards the BMW M Performance LSD over the Quaife because a reputable shop said they would need the car for an entire week to do the Quaife LSD install. It's my daily driver so I'm not going to have it down for an entire week for a LSD install.
      11-12-2015, 09:41 AM   #83
Krelle
Denmark
90
Drives: M2C
There are two way's of getting the Quaife diff.
1. Like your shop which likely take it of and get it modified. -Then mount the same diff. again.
2. You pay a deposit and get the overhauled Quaife diff. -Dismount your own and mount the new in one go.
Then return your old diff. to Quaife.
/Krelle
      11-12-2015, 09:51 AM   #84
Polo08816
/Krelle
Based on the formal estimate, it was Option #2. They have pre-built diffs and would just need to remove current and install new diff. It just didn't seem like a week would be necessary.
      11-12-2015, 10:43 AM   #85
Krelle
Denmark
90
Drives: M2C
No, 2, max 4 hours depending on how easy everything comes of the shafts..
/Krelle
      11-15-2015, 04:31 PM   #86
Polo08816
/Krelle
I put my car on the lift today to check out the original rear diff (among many other things).
Here are a few pics:
      11-16-2015, 01:18 AM   #87
Krelle
Denmark
90
Drives: M2C
Don't forget a wrench, (55mm?) for the big nut.
      11-16-2015, 05:32 AM   #88
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
My quaife was installed in 1h30min....
