BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 - Rear Spacers on 19's
      02-07-2013, 08:18 PM   #23
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Originally Posted by dcg71 View Post
No worries, you made a good argument for getting the M perf suspension. My kit is on the way.
LOL if either one is off, then the other has to pay for the return shipping...no wait, I think I might end up with the short end of that stick
Yeah, after looking at it tonight, it'll be tight, but the suspension (especially the struts) have such a rapid and tight rebound, I'll be very surprised if it's an issue given the camber that's naturally dialed in...and if it is, I'm hoping $99 mistake would be the least of my worries.
SOLD: 2012 335i Mineral Gray
      02-07-2013, 08:42 PM   #24
dcg71
72
Drives: F15 X5
LOL yeah mine will be a 2.5K mistake, excluding fitting. Can't see myself wanting to return it though
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      02-07-2013, 08:53 PM   #25
ks200906
Drives: F30 328i MSport
Yeah, they will be closer to the hub, 13mm closer compared to the 397, but the rear wheel will be 12mm wider. The numbers cancel each other out so an 8.5" wheel at ET47 will sit out exactly the same as an 8" wheel at ET34. On M perf suspension you will be 1/2" higher compared to H&R sport, plus you should have less body roll, so I can't see that rubbing.
I've not used spacers on the front, but would be reasonably confident 12mm will work.
Of course we're talking mm's here, so obviously the tire and its sidewall play a big role.
Hope you don't mind, I'm just not sure if your math is right...
With 8.5" et47 (400M), the centre of the wheel will be 13mm further IN compared to the 8" et 34 (397). With the additional 0.5" of the wheel, it will have extra 0.65mm on both inside AND outside. So the overall effect will just be 13mm - 6.5mm = 6.5mm, i.e., the 400M wheel will appear 6.5mm further IN compare to the 397 wheel.
Please correct if I am wrong.
      02-07-2013, 09:36 PM   #26
shivaswrath
Drives: 2012 335i
Hey guys, spoke to Burgertuning before I ordered, turns out no more than 12mm all around to be safe with the lowered suspension...I'll post pics, they were helpful, so I hope it sorts out!
Ordered a nice set of Jack pads too (lol), my Evo never had these jacking issues...so Euro.
      02-07-2013, 10:32 PM   #27
dcg71
72
Drives: F15 X5
Yeah you are correct, 1/2 of that 13mm will be on the inside. The 8.5" wheel at ET47 will sit 6.5MM further in compared to my 397s. The wider tire however probably negates that, so still nearly identical as far as clearance goes I think.
Look forward to the pics Shiv.
      02-08-2013, 12:54 AM   #28
ƒ°
ƒ°'s Avatar
101
Drives: ✚
So what size(s) did you get?
      02-08-2013, 09:04 AM   #29
shivaswrath
Drives: 2012 335i
12mm all around per Jason at Burgertuning.
      02-08-2013, 10:50 AM   #30
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Interesting. i was told by Burger that only a 5mm and 15mm will fit the rear hub unless you shave a couple millimeters off the hub lip.
      02-08-2013, 01:52 PM   #31
shivaswrath
Drives: 2012 335i
Yeah that's what I remember reading. Well, I'll give it a try, and if it doesn't work out, they'll have to take it back + shipping since it was their recommendation!
      02-08-2013, 02:34 PM   #32
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Well good luck. Keep us posted. A 12mm in the rear would be ideal for sure. I tried a 10mm non-hub-centric spacer one time and it looked near perfect.
      02-13-2013, 08:49 PM   #33
shivaswrath
Drives: 2012 335i
Just put the rear's on...no rubbing, all is good, and plenty of clearance.
12mm is PERFECT for the 397's...I would say probably same for the 400M's too...
Here's the separate thread with pics...
      02-14-2013, 11:31 AM   #34
INDOOS
Drives: f30 red/red 335i msport
nice i threw on 15mm on my 19 msport wheels w h n r sport springs looks nice
      02-14-2013, 01:31 PM   #35
ƒ°
ƒ°'s Avatar
101
Drives: ✚
PICS!!! NOW!!!
      02-17-2013, 09:49 PM   #36
335i-SG
335i-SG's Avatar
Drives: 2013 335i M-Sport
Please post pics for us! Thanks
      04-12-2013, 02:49 PM   #37
335i-SG
335i-SG's Avatar
Lightbulb
Just installed my H&R sport springs, H&R 10mm Front & 15mm Rear spacers w/extended bolts. Take a look.
BIFCAIDS857.00
      04-12-2013, 03:10 PM   #38
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
They look like the perfect sizes.
Current: 2021 340xi
Retired:
2018 330xi | 2016 340i 6MT | 2013 335i 6MT |
2011 328i 6MT (N52) | 2008 335xi (N54)
      04-12-2013, 03:45 PM   #39
Alex@ONEighty
Alex@ONEighty's Avatar
Drives: 2011 E90 M3 CZP 6MT
15mm would be perfect... Tested and looks awsome
      04-12-2013, 11:15 PM   #40
Camnyc
wannabe
252
Drives: E90 LCI M3
15mm rear and 10mm front are perfect.
      04-13-2013, 12:32 AM   #41
inChargeOfIT
Drives: 2013 335i Sport
On the M-Sport USA Spec, it comes with OEM springs that are 10mm lower. The H&R Sport Springs will be almost exactly 1 inch lower than that all the way around. This is for the 335i only. 328s won't go as low in the front.
Here's my car with H&R Sport Springs.
http://www.f30post.com/forums/showpo...7&postcount=54
That is the first Alpine White 335i (with good quality pics) I have seen with OEM 401's on the H&R Sport's.. beautiful! I have the 18" sport line on my F30 335i sport line and have been considering getting the springs and new rims; but after seeing your car, I may sell my stocks and find a pair of 401 take offs!
H&R sports with the stock 18" sport lines just does not seem to sit right, so I am going to get the wheels before springs (or m-perf suspension.. they should sit about the same right?). 19" fills the gap so much better.
Did you have any spacers in those pics?
      04-13-2013, 07:43 AM   #42
335i-SG
335i-SG's Avatar
My opinion:
Yes, my pics below are with spacers and springs installed.
My opinion:
10mm in front is perfect, 15mm in rear is a bit to aggressive but flush with my stock bubble tires. With different tires it could be perfect.
12mm would have been perfect but H&R only makes 5mm, 15mm & 20mm for rear. 5mm, 10mm, 13mm, 15mm, 20mm front. 12mm rear is supposedly not safe but some have done it anyway with different brands. You can read why by searching this form.
H&R Sport springs:
I feel less body role, slightly stiffer but comfortable and the sport drop looks sporty and classy. My car has not bottomed out on big pumps but my biggest issue is with small road fluctuations. The front end seams to bounce a bit. Bounce is a little to strong a word but its bad enough that I will eventually change to coil overs.
Overall I'm happy considering the look for the low cost.
      04-13-2013, 02:21 PM   #43
ƒ°
ƒ°'s Avatar
101
Drives: ✚
There is a seller in the Classified that is selling his 401s with Bridgestone Potenzas... cheap and brand new. I was going to pick them up, but decided I will probably go down to 18" wheels.
As far as the M-Pref Suspension being the same drop as H&R Sport, that is not the case. The M-Pref Suspension will lower it 10mm more than the US Spec Sport and M-Sport Suspension. The H&R Sport Springs will lower the car about 24mm more than the US Spec Sport and M-Sport Suspension. Again, this is only on the US Spec 335i.
A US Spec 328i on M-Pref will still lower the car 10mm more than the US Spec Sport and M-Sport, but the US Spec H&R Sport Springs will lower it less than 24mm in the front due to the lighter engine.
Basically, in the USA, we only get the 335i H&R Sport Springs. In the EU, they get different H&R Sport Springs for the 328i and the 335i. Hope this makes sense.
As far as ride quality vs performance, it's up to you. IMO, the performance gains of lowering the car is a moot point since most people won't drive their car at it's limit. However, if you do drive your car like that (hopefully only on the track), you should consider more than just swapping out springs. So for daily drivers, I always consider ride quality before performance; and H&R Springs alone will make the ride quality suffer. This is just my opinion and everyone's tolerance for what is acceptable will differ. Hope this helped.
      04-13-2013, 02:49 PM   #44
inChargeOfIT
thanks for the tips and I agree.. I just joined the BMW CCA and will hopefully do some courses soon, so I may hold out for M suspension or some coilovers.. I just cannot stand my current ride height with the 18" rims, too much Camry for me.
If I were to really get into autox, i would probably get a lightweight set of 18" arc-7's or something similar, but for daily driving, the 19's are pretty.
