10-28-2017, 05:06 PM | #1 |
Rep 12
oil filler for N47
Hi Bimmers,
Just get a silly question, I put a new oil filter on my X3 D20, but have no idea this copper ring? is it for oil drain? or should I put it on the oil filler? thanks mates |
10-28-2017, 10:03 PM | #2 |
Rep 2,196
It's meant for the drain plug on the oil pan.
10-29-2017, 01:23 AM | #4 |
Rep 12
I found this oil filter installation is very tricky,
1, I try to install this oil filter as pic 1 below, "align the filter and push in" then result in oil leaking!!! I found many many oil mark on my floor in two days, 100% sure I tighten the oil filter and replace the rubber ring correctly. 2, then I pull it out, and this time I attach it to the cap first (pic 2), and " align the filter and push in", only found few drops in these two days ( not sure why still have oil drops!!!) I just wonder which methods is correct? and why I still get oil drops thanks mates |
10-29-2017, 11:37 AM | #5 |
No 55mph
1621
Rep 8,476
When you remove the oil cap the oil filter normally stays on the cage that is part of the cap - so upon changing out the filter I install the filter on the cap/cage assembly prior to putting cap back on - basically just the way it came out of the housing
I
10-29-2017, 05:27 PM | #6 |
Rep 2,196
Me too! And make sure that big O-ring is in the correct groove on the cap.
10-29-2017, 05:39 PM | #7 | |
Rep 12
Thanks 1QuikWS6 mate, I think you are right and I did the same way likes you in the second time, but still found few drops (2-3 overnight) in these two days (228 and 29 Oct), dont know why but hope they are from my last stupid installation. |
10-29-2017, 05:43 PM | #8 |
Rep 12
Thanks John, yes I did check that rubber o ring is in the correct groove because I was thought that is the problem but not, now looks like I follow the pic from the internet that push the filter into housing first before attaching it to the cap!!!
