BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > JDM 328d Wagon Build (Volk, 3D Design, KW, Recaro, BBS)
      06-06-2018, 02:06 PM   #155
FaRKle!
Originally Posted by Johnny250 View Post
Recaro sportster cs.
I’m not sure, did he not email you back?
Yeah, I never got an email.
      06-06-2018, 02:37 PM   #156
Johnny250
Drives: 328d Wagon
maybe email him again?
      06-09-2018, 11:16 AM   #157
B58
B58's Avatar
558
Drives: 922 Turbo
Wheels are sick!
2024 X3 M40i
2014 BMW M5
      06-13-2018, 11:02 AM   #158
Johnny250
Drives: 328d Wagon
A few interior updates.
-OEM cupholder lid
-OEM M3/M4 shift area with leg pad
-M Performance trim kit
-M Performance M3/M4 Armrest
-M Performance M3/M4 Brake handle
-M Performance M3/M4 Steering wheel with race display
-Recaro Leather Sportster CS
-Brey Krause seat brackets to utilize OEM electric sliders
Did a interior overhaul, cupholder lid helps me drink less sugary drinks, good place to put my phone for waze. I've always wanted the M Performance M3/M4 armrest, after getting it.. sorta had to get the brake handle too. Picked up the electronic steering wheel second hand, had to figure out the wiring myself, wasn't that complicated after doing some research, but definitely was a headache. Got some Recaros because I've always wanted these seats, they match the OEM black dakota leather perfectly! Also found out about Brey Krause seat brackets, they are compatible with the OEM electric sliders, which was wired up to E30 window switches so that I can move forward/backwards using a switch!
Ridiculous wiring harness from my used steering wheel
Recaro pics
Untitled by johnnyboix, on Flickr
kern4174449.50
D Unit92.50
haagm58809.50
      06-13-2018, 12:43 PM   #159
RobbDubbs
RobbDubbs's Avatar
100
Drives: '19 F31
Ugh those seats!
Good to know that the material matches the Dakota leather really well
      06-20-2018, 09:09 PM   #160
paikman
paikman's Avatar
324
Drives: F80 M3 CS, R33 GTR, MK7.5 GTI
oh man. Wish you were closer, we need to link up for a JDM shoot
Johnny2501044.00
      06-27-2018, 05:58 PM   #161
Johnny250
Drives: 328d Wagon
New wheels!
-BBS LM 18x8, 18x9.5
-Blue M-Sport brakes front and rear, 340/345 setup
Found a rare set of BBS LM's in an 18 inch setup (discontinued) and couldn't pass it up, it's a 18x8 (+25 to +30) ish offset fronts and 18x9.5 +34 offset rears. The front offset is around there just by guessing, I've ran quite a few wheels and that's what I came up with. I WILL eventually measure it to see what it is, but the reason I don't know is because it's a face off a 18x9.5 +34 LM wheel, onto an 8 inch wide barrel.
I chose this setup due to the fact that it can run the OEM sized tires (225/45/18 and 255/40/18) without stretching the tires, I'm trying to keep the OEM radius as close as possible because the vehicle has x-drive. Installed OEM tpms sensors with BBS valve stem caps, and topped it off with Blue/Gold BBS caps (always wanted these, I remember the blue cap was rare since it only came with the mag BBS wheels, but I guess they started making them for everyone).
Issues
Of course, after I mounted up these pretties I would run into issues. Test fit went fine, until I tried turning the front wheel, the inside barrel was stuck on my bbk caliper (370 mm M Performance brakes).
Initial Test Fit
So I figured out I needed the 340 M-Sport brakes in the front to make it work, so I asked around for a car with similar specs, and someone was nice enough to help me test-fit.
Second Test Fit
Woohoo, it fits! but...
If you don't know what you're looking at.. the rears are WAY too aggressive. Good news is I knew the rear was reverse-faced, if you don't know BBS LM's.. that means the face was mounted from the inside of the barrel, allowing for more lip and more aggressive stance. No problem.. let's reverse-reverse face this damn thing.
After/Before (notice the face location)
Finally! Ready to install this thing.
I ended up getting some blue M-Sport 340/345 calipers from ebay, Stoptech drilled/slotted front rotors, and Hawk HPS 5.0 pads. Had Danny at Minicorsa install em and finally put on my rims.. from buying these wheels in March, to finally installing them in June, it was pretty satisfying seeing them on.
kern4174449.50
cdwalls702.00
haagm58809.50
      06-27-2018, 06:05 PM   #162
DG20
DG20's Avatar
Drives: M340i
Gorgeous. Well done! Just got some LM-Rs myself and I absolutely love the whole JDM look!
Instagram: @dg_g20
Johnny2501044.00
      06-27-2018, 06:12 PM   #163
Johnny250
Drives: 328d Wagon
Here are 3 different sized BBS LM's on Estoril Blue Wagons
20 inch Jimminez
19 inch kkakonn
18 inch Johnny250
jvit27110.00
      06-27-2018, 06:13 PM   #164
Johnny250
Drives: 328d Wagon
Thanks! Your car looks great with those LM-Rs!
DG20966.50
      06-27-2018, 11:21 PM   #165
tpliquid
Drives: f31 330i wagon
Did u sell the 370 brakes?
      06-28-2018, 09:53 AM   #166
Johnny250
Drives: 328d Wagon
Pending to a buddy, I'll post up here if he backs out.
      06-28-2018, 12:46 PM   #167
Sam!
Drives: 2014 328xi Touring
Looks like ebII f31 have same taste in wheels. I'm on a set of lm-r
What's the change in et for reversed mount?
      06-28-2018, 12:51 PM   #168
Johnny250
Drives: 328d Wagon
It's around 10-15 more aggressive for reverse mount for sure.
pic of your wagon?
      06-28-2018, 04:25 PM   #169
Sam!
Pretty cool you found blue caps in 70mm, I didn't know they have it in that size. Was thinking of picking up a red set eventually.
      06-28-2018, 05:41 PM   #170
VMRWheels
VMRWheels's Avatar
2042
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Love the way your car has progressed! The blue caps and the blue brakes are nice touches!
      06-28-2018, 06:13 PM   #171
tpliquid
Are you able to program car for no seat airbags?
Can you weight the original seats?
      06-28-2018, 09:05 PM   #172
manghong
manghong's Avatar
84
Drives: BMW F30 328
Tastefully modify, i do prefer the aggressiveness of the TE37 over BBS.
2012 BMW F30 328i
kern4174449.50
      06-29-2018, 10:33 AM   #173
Petrolhead Tom
Drives: BMW M135i 2012
This is by far the best looking touring ever.
      06-29-2018, 12:56 PM   #174
Jimminez
Jimminez's Avatar
Drives: 2014 F31 M-Sport
Looks awesome. Great comparison too.
Martin
Past - F31 M Sport Estoril Blue - Thread - Pic
Current - 2021 Audi RS6 Avant
      06-29-2018, 12:57 PM   #175
Johnny250
Drives: 328d Wagon
Great looking wagon! I got mine through IND, but the ones on their website are 4 prong, you need 3. Just make sure you tell them you want 3 prong.
Thank you! I thought it was going to be too much blue, but it's fine for now.
tom @ eas did all the coding on that, highly recommend going to them.
Thanks! I still have the TE37's, I like swapping wheels, I think these two sets give me the best of both worlds.
Appreciate it.
Thanks OG!
      07-16-2018, 01:26 PM   #176
Johnny250
Drives: 328d Wagon
Video of the aFe Momentum GT intake in action.
haagm58809.50
328d, estoril blue, f31, msport, wagon
