05-31-2015, 03:30 AM | #1 | |
Rep 498
Last week I found a thread about "easy entry" coding for an F10:
http://www.bimmerfest.com/forums/sho...d.php?t=825923 Quote:
Since my F36 doesn't have power adjustment for steering wheel, I only coded this: EASY ENTRY SEAT: SM > EINAUSSTIEGSHILFE > Modus_FA_SLV It didn't seem to work, so I gave up because everyone said F30 series doesn't support this. Today, I misplaced my keys and due to being late for an appointment, I took the spare key for my F36 (435 GC). I had previously used this key fob in the car when I first got it as I mixed up the fobs. So I had the seats adjusted prviosily and think I adjusted the seat and saved it into the seat position memory. What surprised me when I got with the second key fob, was that the seat was further back and when I started the car, it moved up 2-3". This is either happening because: 1. My coding worked and it somehow bound to the second fob 2. My coding worked, and it's somehow related to the 1 and 2 seat position memories 3. The car by default comes with easy entry enabled shifting between memory 1 and 2 and it's just not happening with my fob because the seat memories are the exact same between 1 and 2. I'm skeptical the answer is #3. My guess is that it's #2. I'm planning on doing some more experimenting tomorrow on this but wanted to post a msg to get a convo started on this and potentially get help from other F36 owners to determine if coding does work or there is some other explanation. Last edited by bobbydigital; 06-01-2015 at 12:31 AM.. |
05-31-2015, 06:39 AM | #2 | |
Rep 50
It's working on F30... your problem is that your seat position is too much on the back so easy seat can't work since seat is already at it "maximum". This maximum position can be coded although you have to play with : EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS EAH_VERFAHRWEG_SLV_PHYS |
05-31-2015, 10:10 AM | #3 | |
Rep 498
Why do you think this works for my second key fob and not primary? |
05-31-2015, 12:46 PM | #4 | |
Rep 50
Or try to code others value as describe on the thread you already visit |
05-31-2015, 08:03 PM | #5 |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
I was checking the SM module for several cars and have concluded...
Vehicles produced before November 2013 DO NOT have the option of enabling easy access Modus_FA_SLV regardless of I-Step level. Vehicles produced after November 2013 HAVE the option of enabling easy access. |
05-31-2015, 08:24 PM | #6 | ||
Rep 498
Are some coding values saved somehow per key fob? Meaning if I coded easy seat entey while using one key fob, would it be set only for that one and not both fobs? |
06-01-2015, 10:42 AM | #7 |
Rep 1,573
you can assign different profiles to the 2 keys. For example one profile for me, one profile for my wife.
on my key/profile, memory 1 is my memory seat on my wifes key/profile, memory 1 is her seat memory do you think that could have been the case? you used the second key and it switched into that keys memory settings?
2015i Cadillac Escalade ESV
06-01-2015, 10:43 AM | #8 | |
Rep 498
06-01-2015, 01:40 PM | #9 |
Rep 50
06-17-2015, 12:05 AM | #10 |
Rep 906
My car is a October 2013 build, but has F020-14-07-503.
Was able to code SM2/3000/EINAUSSTIEGSHILFE -> Modus_FA_SLV No luck getting it to work. However, there are separate entries that I also enabled...with no luck: SM2/3000/EASY_ENTRY -> aktiv SM2/3000/EASY_ENTRY_TTB -> aktiv Wish I could get this to work. EDIT: Nevermind. It works. The feature only works when the engine is started and door is closed.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 06-21-2015 at 09:40 AM.. |
06-17-2015, 12:43 PM | #11 |
BMW Fanatic
331
Rep 1,076
So this works if you have different memories saved?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
07-03-2015, 07:29 PM | #12 | |
MVP
Rep 32
Drives: BMW F30 XDrive
Does the seat auto move back? Do you have to have Memory buttons configures specific way? Please explain further. Thanks
-2015 328i XDrive Sport-Black Sapphire Metallic | Leather Dakota Black/Red highlight
-ZSL | 7AC | ZCW | ZDA | ZDB | ZDH | ZLP | ZPP | ZTP | 688 | 8S4 |
07-04-2015, 12:33 PM | #13 | |
Rep 906
Easy Entry started working after a engine on/off cycle. The logic I've noticed is that the movement is triggered by certain events: Easy Entry (ingress): Engine on, doors closed within 10-15 seconds of engine start Easy Entry (egress): Engine off The period right after coding is when you will catch the system in a corner case, where the seat is in driving position already and no movement is necessary. I think you need to cycle the engine (AKA drive it around the block) to trigger egress before Easy Entry actually kicks in.
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 07-05-2015 at 12:43 PM.. Reason: Corrected egress steps |
07-04-2015, 04:36 PM | #14 | |
MVP
Rep 32
1. Which memory should be the egress (furthest back) setting? Memory 1 or 2 2. Under Settings Door locks do you have a check in "Last seat position auto" box? 3.Did you code anything else besides EINAUSSTIEGSHILFE -to-Modus_FA_SLV? (When I coded it the memory on my seats didn't reset. I changed them anyway, but it didn't help.) Thanks again.
07-04-2015, 07:56 PM | #15 | |
Rep 906
2. Yes, I have that setting enabled. 3. Yes. I also coded two other options in my previous post. Not sure if that did the trick though, since I coded all three in the same session.
2020 i3 Rex: Capparis White, Giga World |
07-05-2015, 12:20 PM | #16 | |
MVP
Rep 32
SM2>3012 EAH_SHUTZFREIRAUM_HINTEN_SLV_PHYS Changed from 00, 65 to 00,3C (letting it move back much further) I also adjusted the below code for the front clearance SM2>3012 EAH_VERFAHRWEG_SLV_PHYS Changed from 00, 3C to 00, 28. Now it seems to work all the time as i want. The values I changed are hex and can be anything that suits the driver. Thanks for your help on this! Another great feature!
08-02-2015, 09:58 AM | #17 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
I have F30 with July 13 build date and current I-Step is F020-14-11-502. I initially coded just the one item: SM2 > 3000 > EINAUSSTIEGSHILFE > from nicht_aktiv to Modus_FA_SLV. No Joy! Will try the other two items you mentioned, though it looks like from the comments that it doesn't apply to F30??? Will post my results Thank you very much
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
08-03-2015, 11:38 PM | #18 |
Rep 1,035
Works great for me! I LOVE this new feature!!! I'm always bumpin' into the freaking steering wheel on the way in and out - no more!!!
2014 F30 328i m-sport (production date: 08/19/2013) - for me, I just changed these 3: FDL Coding: SM2 -> 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV SM2 -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 SM2-> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C Note: this last value (EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS) could unintentionally disable this feature if your seat encroaches within this many mm from the rear end of the rail. Some suspect this is a safety thing to protect the knees of your passenger in the rear seat. By default this value is 0x64 (100mm). If this feature doesn't work, change this value to something smaller like i did - e.g. 0x3c (60mm) - it allows your seat to go back further and still keep this cool feature iDrive: - under Settings ->Doors/lock: "Last seat position automatic" box is checked New Behavior: Turn off the engine and open the door: Seat automatically slides back a few inches, allowing easy exit Turn on engine : Seat automatically slides forward a few inches, getting your seat into driver's position I didn't mess with key FOBs or memory seat settings at all. Whatever i had just seemed to work as is. I didn't have to drive around the block, or leave the garage, or go to a car wash (lol ) or anything. As soon as the coding was done, all i had to do was turn off engine and open the door, or just turn on engine Note: I don't have 'FRM' ECU on my car for the power-adjustment steering wheel either, so i can't code that on my F30. My steering wheel can't move like that Othewise, it would be nice for the steering wheel to also get outta the way when i'm getting into my car. I'm thinking that's only available for the 5-series and up?? Last edited by squidlyboy; 08-04-2015 at 08:29 AM.. |
09-02-2015, 12:32 PM | #19 | |
Rep 1,479
Works like a champ!! I coded exactly as you suggested, but would like it to go back a little further. Unfortunately, even with Google Translate, I can't figure out what the values represent Ideas? Thanks
Al
09-02-2015, 12:44 PM | #20 | |
Rep 1,035
I haven't tried any other values, as the 4cm is fine for me, but from that other thread:
I would like the seat to move more forward when I start the engine, but haven't been able to figure that out. I tried setting the memory seat position thinking it works by going back to M#1 position when the engine starts, but it doesn't appear to. |
09-02-2015, 07:41 PM | #21 | |
Rep 1,479
I have 2014 F30 with a build date of 7/13. Coded all three items in this thread and Easy Access works like a champ |
09-04-2015, 06:03 AM | #22 |
Rep 303
I had the exact same thing as the OP happen- could never get this to work, gave up, then used my spare key on accident and all of a sudden it worked. When I adjusted my seat to my liking, it stopped working. However, I only moved my set up/forward to get closer to the steering wheel (since I like to sit fairly close)- why would the seat travel limits stop it from working? I'll code the additional lines in that people have found to help, but I'm not sure I understand why those settings would fix my problem.
