08-25-2013, 10:44 PM | #4445 |
Rep 1,980
Drives: 2020 G20 320i M Sport
Just noticed that there's now psdzdata 50.3 and Esys 3.23.4 - do I need a new token to be able to use the newer version of Esys or will the current one still be good for that?
08-25-2013, 10:47 PM | #4446 | |
Rep 40,959
However, if you already have 3.22.5, there is no reason at all to update to 3.23.4. You will gain nothing.
08-26-2013, 12:06 AM | #4447 | |
Rep 31
I'll check with the new FW after BMW update with 6NR option. If necessary I'll ask to you for new psdzdata. bye |
08-26-2013, 02:49 AM | #4448 |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
Hi all!
Does anybody know is it possible to change info in serviсe logbook in the fob with E-SYS? Last edited by avgor123; 08-26-2013 at 04:46 AM.. |
08-26-2013, 05:48 AM | #4449 | |||
Rep 40,959
08-26-2013, 11:36 AM | #4451 |
Rep 40,959
PM sent.
08-26-2013, 03:36 PM | #4455 |
Rep 40,959
PM sent.
08-26-2013, 03:38 PM | #4456 |
Rep 40,959
PM sent.
08-26-2013, 03:39 PM | #4457 |
Rep 40,959
You have to post an email or wait until you can receive PM's.
08-26-2013, 04:02 PM | #4458 | |
Rep 9
08-26-2013, 04:05 PM | #4459 | |
Rep 40,959
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. This will encode an entire ECU with all the parameters needed to support every option in your Vehicle Order. You can VO Code the entire car one module at a time, or you could use Ctrl-Right-Click above and select multiple ECU's to Encode, or you could even Right-Click at the Top of your SVT where your VIN is showing, and encode the entire SVT (all ECU's). If you try and encode DME Module, or the entire SVT (which includes the DME module), the car can not be running during the encoding process.
08-26-2013, 10:32 PM | #4460 |
Rep 109
Does TCM_LOGIC_R_OFF_DOOR = aktiv disable FH_TUERAUF_STOP_MAUT = nicht_aktiv?
i.e. If the car is coded to turn off the radio and navigation when the door is open, will it also stop the window up/down regardless the coding? |
08-27-2013, 05:53 AM | #4461 | |
Rep 49
Eg: 6NK -> only HU_NBT, etc |
08-27-2013, 06:29 AM | #4462 |
Rep 40,959
No. You just have to make an Educated Guess.
08-27-2013, 09:45 AM | #4463 |
Rep 1,044
It's time up re-code my favorite options because the dealer has updated the car. (BTW, whatever level they used really improved ASS. Some -- not all -- stops are imperceptable. And re-starts are amazingly smooth.)
Could someone review for me the best way to update an older working Windows system (PSdZData 48.3 with ESys 3.18.4) to 50.3 and 3.23.4? I searched this thread, but it's so large I couldn't find the posts that I think describe a process of simply re-installing ESys (and getting a new token, of course) and overlaying the entire psdzdata folder. Would that still work?
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
08-27-2013, 11:40 AM | #4465 | |
Rep 40,959
08-27-2013, 11:44 AM | #4466 |
Rep 40,959
Time's up. PM's sent.
