06-14-2021, 07:03 PM | #89 | |
Rep 7,629
06-14-2021, 07:11 PM | #90 | |
Rep 4,208
Mods: Yes.
06-14-2021, 07:49 PM | #91 | ||
Rep 7,629
John first posted about it, then others followed up. For example: Quote:
06-15-2021, 07:30 AM | #92 | ||
Rep 4,208
F87source - Can you confirm.
Mods: Yes.
04-25-2024, 12:02 PM | #93 |
Rep 12
Thread bump but running e85 MHD stage 1 tune on a 15 x3 n55 with the pwg. Runs great and pulls about a 4.5 0-60.
Tbh car feels better than stock running Costco 92. Stock I had some minor start up shake and small idle variation. That’s gone running e85. Stock fuel system, stock everything. Added the burbles on oem setting, very fun! This tune is very attractive to me in MN with abundant e85 access at about $2.50 a gallon. Less boost on the turbo means I don’t really need to worry about the charge pipe too. I have an ARM Motorsport charge pipe on hand but I don’t see any reason to install it unless it breaks. Figure I can limp it home and install it if needed, any long trips I’ll just bring the pipe with and have a nearby shop install it. Fairly minor mpg drop that is more than offset with premium costing north of $3.50. |
04-25-2024, 07:27 PM | #94 | |
Rep 7,629
BTW i would consider replacing CP preventatively. If it blows you can damage the MAP sensor or something else, or suck pieces of plastic into the engine |
04-26-2024, 02:59 PM | #95 | |
Rep 12
I will update again on a full wot run |
thejeremyman94389.00 |
04-30-2024, 02:02 PM | #96 | |
Rep 12
Car is running great no issues. |
05-01-2024, 10:58 PM | #97 |
Rep 7,629
05-02-2024, 10:58 AM | #98 |
Rep 12
05-02-2024, 11:45 AM | #99 |
1303
Rep 3,553
Timing at idle and part throttle driving will be all over the place. From negative to positive 40 degrees. That info tells you nothing.. you need to do a log at wot post the link.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
05-07-2024, 11:13 AM | #100 |
Rep 12
05-07-2024, 11:35 AM | #101 |
Rep 7,629
If you log 4th gear pull as described here: https://f30.bimmerpost.com/forums/sh....php?t=1732327
Or something like a 3-4-5 (space permitting), we want to see how it behaves at WOT given its the only maps for full E85 with stock HPFP. So main things would be boost and timing targets, HPFP pressure, etc. |
