BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > LED Fogs + 50w Brake LEDs
      08-12-2015, 05:46 PM   #67
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      09-03-2015, 03:53 AM   #68
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
can you tell me the coding done for LED fog please ?
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
      09-03-2015, 04:04 AM   #69
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Hey,
Firstly: Do you have an LED driver included in your foglight setup? If you do then you don't need to code any of the voltages, because the LED driver automatically handles the task of voltage adjustment.
      09-03-2015, 03:28 PM   #70
rustyminded
248
Drives: BMW 328i
Originally Posted by nickhelou View Post
Hey,
Hey, it's not my car but it's oem led not sure if there is driver but saw in forum someone installed it and had to code it
      09-03-2015, 03:29 PM   #71
rustyminded
248
Drives: BMW 328i
I got it thanks a lot
      09-03-2015, 04:28 PM   #72
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Alright, glad to help I guess haha
      09-06-2015, 05:38 AM   #73
rustyminded
248
Drives: BMW 328i
Hey bro do you know if there is Cree LED in USA and where is it sold ?
      09-06-2015, 06:22 AM   #74
rustyminded
248
Drives: BMW 328i
ok someone asked me to get him LED signals rear and Fog lights, so I thought it's time to go cree LED. I will get him those and tell me your opinion
Fog: what's the color, xenon like 4300k ?
http://www.horizonleds.co.uk/cree-le...og-light-bulbs
Signal Red: 50watt is too much ?
http://www.horizonleds.co.uk/cree-le...cree-led-bulbs
      09-06-2015, 04:12 PM   #75
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Hey,
Regarding the fog lights, I believe you are on the right track if you want to change the color tone, and regarding strength, these are pretty strong, not overkill. However, it is worth mentioning that I have a headlight kit in my fog lights, so the intensity won't be as strong. The 50W turn signals too are a very good choice, not overkill. If you can hold on for a while, I placed an order for my friend's E63 630Ci. I ordered him front + side + rear turn signals as well as front fog lights. Once I install I will instantly snap pictures and post them in hopes of helping you and others when it comes to bulb swaps.
      09-07-2015, 04:23 AM   #76
rustyminded
248
Drives: BMW 328i
Hey,
Regarding the fog lights, I believe you are on the right track if you want to change the color tone, and regarding strength, these are pretty strong, not overkill. However, it is worth mentioning that I have a headlight kit in my fog lights, so the intensity won't be as strong. The 50W turn signals too are a very good choice, not overkill. If you can hold on for a while, I placed an order for my friend E63 630Ci. I ordered him front + side + rear turn signals as well as front fog lights. Once I install I will instantly snap pictures and post them in hopes of helping you and others when it comes to bulb swaps.
great I will be waiting, do you know any dealler in USA or trusted source to buy from. much easier for me to get from U.S
      09-07-2015, 04:24 AM   #77
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Hey,
Bimmian, but they're slightly more expensive, and they don't actually tell you bulb ratings.
      09-07-2015, 05:10 AM   #78
rustyminded
248
Drives: BMW 328i
Ouch they are, do I need anything else with that Fog LED ?
      09-07-2015, 05:22 AM   #79
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
For my fog lights, I had to get a CanBus connector because the car would keep adjust the voltage, in which one bulb turns off and one stays on, or both don't work. You might not need this since you are getting the normal bulbs / not the headlight LED kit, but better be safe than sorry, in which you'd have to wait for another shipment.
Note: If you are getting the headlight LED kit, you will still need the CanBus connectors but you wouldn't need to code any voltage changes in the car. The LED driver sorts that out.
      09-07-2015, 07:13 AM   #80
kitster
Drives: G31 M Sport
Originally Posted by thatf30guy View Post
Was just noticing that the stock xenon bulbs look rather yellow in comparison to the 2500 lumen LEDs...makes me want to change out my xenon bulbs for something a little whiter
I've passed many other cars with xenons and it defo looks like the stock xenon isn't as white as those fitted to mercs.
      09-08-2015, 06:29 AM   #81
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
I'll check what type is fitted on my friend's new C class and will confirm which bulb manufacturer they use.
      09-08-2015, 12:33 PM   #82
rustyminded
248
Drives: BMW 328i
Hey man I've checked on and found this, tell me do I need canbus with it and coding
100watt LED and 15watt working power this is confusing to me
and is 5000k pure white as they say ?
http://www.ebay.com/itm/2x-5000K-H7-...b33072&vxp=mtr
      09-08-2015, 04:02 PM   #83
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Alright so the 100 watt probably stands for equivalent incandescent bulb rating, in which, the amount of light that it gives you is equal to that of a 100 watt incandescent bulb. The actual rating is 15 watts. Therefore, it gives you 100 watt incandescent lighting whilst using 15 watts of power only. I wouldn't recommend you go with these though, they don't seem to high of a quality. 5000k = Pure White
      09-08-2015, 04:05 PM   #84
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
I checked my friend's Merc. He has LEDs fitted to his car. As far as I know, new C classes are either Halogen or LED, which explains why they are whiter than our Xenons.
      09-09-2015, 11:18 AM   #85
rustyminded
248
Drives: BMW 328i
ahh ok well I keep looking I will put some links please check them for me they seem to be CREE LED but not sure if they are any good
sorry to bother but I don't know what what to look for exactly high is Lumens or watts
http://www.ebay.com/itm/2pcs-Xenon-W...item3f4401f2fd
http://www.ebay.com/itm/2pcs-Bright-...item418ca8860c
http://www.ebay.com/itm/2x-HID-White...item2343a81e9e
http://www.ebay.com/itm/2x-CREE-XBD-...item418dd03252
http://www.ebay.com/itm/2x-H8-5000K-...item419c366cb8
http://www.ebay.com/itm/CREE-LED-KIT...item20fb064ef5
      09-09-2015, 11:57 AM   #86
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
This is the only one that seems decent quality wise IMO.
If you are looking for these types of bulbs, you should check out Horizon's for the sake of warranty. Never had any experience with these types of bulbs, however, I would go with Horizon in case they burn out, they can replace them for you and not end up being a waste of money.
http://www.horizonleds.co.uk/cree-le...e-cone-led-45w
      09-10-2015, 06:42 AM   #87
rustyminded
248
Drives: BMW 328i
ok I've made very good search and came up with these, they are identical as on Horizon LED
I want to get the 80 but not sure if it needs resistor.
80w
http://www.ebay.com/itm/2x-H8-H11-80...57a5be&vxp=mtr
50w
http://www.ebay.com/itm/281793686712...%3AMEBIDX%3AIT
45w
      09-10-2015, 06:44 AM   #88
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
80w
50w
45w
It might need the resistor, and it might not. If you want try it out without the CanBus connectors first, if your lights function normally, then you don't need them. It's a trial and error, as each bulbs have a different design and CanBus characteristics.
